Heat from right rear wheel
Hi: I recently acquired a one-owner clean-Carfax 2002 AWD RX300 with 222K miles. For past 9 years car had been maintained by a conscientious independent mechanic. New brakes installed just before it was traded in on a 2019 RX450H. Yesterday I drove 150 miles at highway speed. Stopped to get coffee and as I walked around the car became aware of heat coming from the right rear. Wheel was too hot to touch; all other wheels felt fine. No squeaks. Parking brake not mistakenly engaged. 300K miles of experience with two other RX and this never happened to me before. Likely cause? Logic suggests dragging brake pad due to error in installation or defective caliper; parking brake out of adjustment; wheel hub bearing. Suggestions as to how to rule possibilities in and out? TIA.
Parking brake adjuster may be too tight. Check if the wheel is binding.
Back off the parking brake adjuster if necessary
https://www.clublexus.com/forums/rx-...ml#post8243386
Do you have a temperature sensor? Bearing would show the middle of wheel honest and brake drag would be the clipper and parking brake would be the drum. All would cause drag. Also best time to check would be after short drive in the morning Every should be cold except the source of friction.
Salim
Salim
Most likely a seized caliper. In my experience with my rx the rubber guide pin boots That came with the new pads were too tight and stopped the pads from retracting.. a wheel bearing would be growling at you if its making that much heat. Parking brakes not likely. Remove the wheel and check pad wear. Is there more brake dust on that wheel?
I have removed the right rear wheel. Nothing is conspicuously irregular; the wheel is not 'frozen' due, for instance, a faulty parking brake. However, it has been a while since I have changed rear brake pads on an RX. I have removed the lower caliper bolt; does the caliper simply swing upwards around the upper bolt? Or does that bolt also have to be removed, and if so, how? Is there an allen head bolt hidden behind a rubber dust seal? TIA.
One sign was the caliper piston seemed unusually hard to retract.
2002tii
GX - 1st Gen (2003-2009)
Sep 29, 2014 05:36 AM
