Blue Smoke after Knock Sensor R/R
Old Nov 23, 2019 | 05:34 PM
fastek's Avatar
fastek
Default Blue Smoke after Knock Sensor R/R
Replaced knock sensors, bypass hose and harness in my 2000 RX300 and am now getting excessive blue smoke pouring out of the tailpipe 2 days after getting everything back together.
I also replaced the plugs, PVC valve and the front valve cover gasket. I used Beck Arnley gaskets if that's any help.
Damn I'm gonna hate tearing this down again if I have to .......
Anyone have suggestions on what this might be ?
Old Nov 24, 2019 | 08:01 AM
Fit1too's Avatar
Fit1too
PCV valve? Do you still have the old one? You could put it back in and see if the blue smoke stops.
Old Nov 25, 2019 | 08:00 AM
salimshah's Avatar
salimshah
25 Year Member
The sensors just bolt into the block, so they should not be the reason.
I would check the plumbing again. At least one member connected the coolant to the vacuum line. But that should not give you blue smoke.
Maybe some cleaner got into the intake? or a gasket did not sit right causing an oil passage to the cylinder.
Salim
joegreen
Mar 17, 2016 10:05 PM
dalbert02
Jun 12, 2015 10:46 AM
NINmh
16
Oct 3, 2010 01:25 AM
Eric00GS3
Jan 17, 2008 10:37 AM
Anzial
Nov 1, 2005 06:04 PM
