torque values....
Old Oct 16, 2019 | 02:53 PM
Stigedis's Avatar
Stigedis
10th Gear
Default torque values....
Sorry in advance. Been beating my head trying to perform searches for some torque values. Found some but not even sure they are accurate.
I replaced rear struts and sway bar links and will replace rotors and pads front and rear.
found these values.
3 nuts top or rear struts 47 ft. Lbs
strut to knuckle nuts 156 ft. Lbs
sway bar links 29 ft. Lbs (not even sure how to torque with goofy hex bolt center)
found nothing for calipers mounting or slide.
how wheel lug torque
can anyone conform above values, provide other values or point me in the right direction..
TIA
Old Oct 16, 2019 | 03:31 PM
ricco750's Avatar
ricco750
Per my Haynes Manual: Strut Upper Mounting Bolts, 59 ft-lbs. Strut to Knuckle, 155 ft-lbs. Stabilizer Bar Link to Strut, 29 ft-lbs. Caliper Mounting Bolts: Front 20 ft-lbs, Rear (2003 and earlier), Upper 20 ft-lbs, Lower 14 ft-lbs...2004 and later, 32 ft-lbs. Caliper bracket mounting bolts, front 77 ft-lbs, rear (2003 and earlier) 34 ft-lbs, and (2004 and later) 58 ft-lbs. Wheel lug nut 76 ft-lbs.
Old Oct 16, 2019 | 04:34 PM
Stigedis's Avatar
Stigedis
10th Gear
thank you!!!
JAB
Jan 4, 2017 08:19 AM
gtstcactus
13
Jan 16, 2014 09:04 PM
azednalcm
Mar 2, 2009 05:53 PM
MellonC00
Apr 22, 2008 04:16 PM
onlylexus8
Feb 27, 2006 02:01 PM
