Safety hatch
Old Sep 2, 2019 | 09:02 AM
Naplescapt's Avatar
Naplescapt
Default Safety hatch
Hi everyone, I’m brand new here and am at a loss. My son somehow broke, and or bent the rod that releases the safety latch on the hood. I’ve looked for info on this but only found if the cable is broke and not the safety release. I can get some access to it by popping the hood but I don’t know which way I should try to move the latch?? Left, right, forward or back? Any help would be great because the battery is dead and I can’t charge it!. Thank you in advance!
Old Sep 2, 2019 | 03:57 PM
salimshah's Avatar
salimshah
25 Year Member
If the second release is working properly, one just has to lift it up [reduce the distance between the flat and the hood]. Since the primary release has disengaged the first lock you should have a play in the hood. That should allow you to visually see and if the catch is bent maybe it can be levered back or a coat hanger wire/screw driver can be used to release the secondary catch.
Salim
Old Sep 2, 2019 | 07:02 PM
carguy07's Avatar
carguy07
Push it toward the driver's side.
Old Sep 2, 2019 | 08:33 PM
salimshah's Avatar
salimshah
25 Year Member
You are ever so helpful by posting a picture.
So the hook needs to be pushed towards the driver side or the release lever?
Salim
Old Sep 2, 2019 | 11:13 PM
carguy07's Avatar
carguy07
It releases by moving toward the driver's side, but the rods will pivot up to move it that way.
Old Sep 3, 2019 | 04:49 AM
Naplescapt's Avatar
Naplescapt
Thank you everyone! I will try it out ASAP!
Old Sep 3, 2019 | 11:16 AM
salimshah's Avatar
salimshah
25 Year Member
Thank you. I stand corrected.
Salim
Old Oct 5, 2019 | 05:08 AM
Naplescapt's Avatar
Naplescapt
Sorry about the late response to the thread, but I did get the latch open by using a very large screwdriver and pushing down through the grill. Thanks for all the help guys!. I got one more for you guys ,,,, I need a new key made for my 2001 RX. It basically fell apart. Does anyone do them online?
Old Oct 5, 2019 | 06:00 AM
Lexmus's Avatar
Lexmus
I have ordered a replacement key shell from ebay with the key cut to my vehicle. They key has worked for five years. You just swap out the guts of the old key into the new one, including the small black chip.
The ebay seller I used no longer sells RX300 keys. Check out this one:
https://www.ebay.com/itm/BLADE-CUT-by-PHOTO-2-KEY-SHELLS-to-REPAIR-BROKEN-REMOTE-FOB-KEY-for-LEXUS/152647332601?
They have separate listings for one or two keys and by photo or keycode. Either way, make sure you send your key information to them within the time alotted per the listing so it is cut before they mail it out.
jdanielca
Sep 10, 2024 10:30 AM
GsLex02
GS - 1st Gen (1993-1997)
Jul 6, 2024 05:11 AM
jethro121
Apr 17, 2017 05:07 AM
olmytsi
Nov 7, 2014 04:38 AM
t70 supra
May 23, 2008 11:17 AM
