Tie Rod Ends - need advice
Old Sep 3, 2019 | 12:16 PM
JAB's Avatar
JAB
Default Tie Rod Ends - need advice
One of the outer tie rod ends on our 2003 RX broke and I need to get a replacement asap. Rock Auto indicates that they are interchangeable Lleft vs. Right and the most expensive one they sell is $28. The dealer claims they are different Left vs. Right, and the price is $135 each. I can't reconcile these two sources. Help! What say those of you who have had to replace an outer tie rod end.
Old Sep 3, 2019 | 12:43 PM
copperny's Avatar
copperny
updated part number 45046 -29255 tie rod end for left or right side, at one time left and right hand separate numbers.
Old Sep 3, 2019 | 12:54 PM
JAB's Avatar
JAB
thanks; appreciate it
Old Sep 3, 2019 | 03:23 PM
ricco750's Avatar
ricco750
Smile
Originally Posted by JAB
One of the outer tie rod ends on our 2003 RX broke and I need to get a replacement asap..
How exciting was it when it broke?
Old Sep 3, 2019 | 04:42 PM
salimshah's Avatar
salimshah
25 Year Member
Usually it is not exiting ,,, scary yes, but with 1 front under steering control and two in the rear wanting to go straight, the 4th predominantly provides a substantial drag. whith both front connected and no stearing can be exiting.
Salim
Old Sep 3, 2019 | 05:25 PM
JAB's Avatar
JAB
I was not in the car at the time. Car was in a relatively minor accident. Perhaps it broke first, caused driver to lose control, and hit car in next lane? I don't know. I've simply never heard of a tie-rod end breaking, certainly not without major impact.
Old Sep 3, 2019 | 06:01 PM
copperny's Avatar
copperny
personally after an impact like that, check the inner tie rod that it is not bent. Tie rods do fail the stud breaks out from the socket. Have your vehicle professionally aligned the equipment should report back to the tech if parts are bent. P.S. get ends that have grease fittings.
velani
Oct 11, 2024 06:00 PM
Gears12
Suspension and Brakes
24
Oct 16, 2012 07:25 PM
peterwho
Jun 21, 2010 09:22 PM
CantSeeMe
Feb 11, 2008 01:41 PM
