Key Programming 2001 RX300
Old May 16, 2019 | 04:26 PM
NYCGeordie's Avatar
NYCGeordie
10th Gear
Default Key Programming 2001 RX300
Have tried to program new key but isn't working. I'm assuming it's because the driver's door actuator isn't working. Can someone confirm or is there a way I can program without the actuator working?
Old May 17, 2019 | 05:04 AM
Mauser's Avatar
Mauser
Are you trying to program the key to start the car or just unlock it? If you are programming to start you can use Techstream. If programming to unlock and the actuator isnt working you can have someone move that lock manually.
Old May 17, 2019 | 05:11 AM
NYCGeordie's Avatar
NYCGeordie
10th Gear
Thanks for the reply. Looking to start car. What is Techstream?
Old May 17, 2019 | 05:20 AM
Mauser's Avatar
Mauser
If you are trying to start the car door locks shouldnt matter. Techstream is the diagnostic software for Toyota.
Here is more on programming to start:
https://www.clublexus.com/forums/rx-...for-99-rx.html
Old May 17, 2019 | 04:30 PM
NYCGeordie's Avatar
NYCGeordie
10th Gear
Thumbs up
Many thanks Mauser. Instructions worked a charm. I'm assuming the remote programming instructions didn't work because not all of the locking activators are working.
Phil01
Apr 8, 2019 05:08 PM
arosnes
Apr 21, 2018 05:41 PM
zyumin
Sep 28, 2016 12:35 PM
fireguy596
May 11, 2015 04:12 PM
modifyd
Feb 12, 2006 08:14 AM
