View Full Version : Maintenance
- 155,000 mile service - multiple issues - HELP!
- LX470 Electrical Problem
- Glue on windshield - suggestions to clean?
- Bumper Repair
- Passed Smog with new O2 Sensors - sweet
- Emergency STUCK in PARK
- Dirty Fuel Injectors
- Brake fluid change?
- help, need a link!
- 1999 Lexus es300 - Overdrive Issue
- Anyone taking fall ASE test in November? or re-test?
- What to Do When Your Car Reaches 100k Miles
- 0w20?
- Tranny fluid switch
- 93 ls400 cluster lights and gas gauge
- 2004 LS430 90/100k Service List
- AC repair...what would you do?
- VSC and Engine lights on
- 97 es300, p0141
- stalls while driving
- IS 250 is making noise
- damaged door seals
- Spark plugs different brand
- oil pressure light 92' ES300
- Gas filter
- ES250 Starting issues
- Fenders
- struts and springs
- window switch "reset"
- Do any friends know this scan tool for Toyota?
- 200 ES300 Rear subwoofer replacement - help needed
- how to remove windshield washer reservoir
- erratic power window
- Tire Llight Question
- A/C compressor out on 2GS...
- diagnosing power window problems, where do I start?
- tarnished horn logo
- Need assists with Upper Control Arm question?
- air conditioner low pressure service plug
- IS300 maintenance comparable to?
- Any ideas as to what is causing this??
- Rust removal on control arms
- Best oil choice for a older gs400 with a slow RMS leak
- 2005 LS430 PCV valve, where is it hiding?
- Daizen = polygraphite, Prothane = polyurethane?
- 2010 lexus is250 crashed help!!
- seat issue help!!!!!
- Oil leak??
- DIY poor mans oil analysis
- Issues registering non-CA Lexus in CA?
- OD in tranny stopped working,knock sensor related?
- P0135 gs430 2nd Gen v8
- '92-'96 ES300 Ashtray/cup holder
- replace o2 sensor or not?
- Shop Recommendation in Dallas, TX
- Respectable Houston Shop
- IS 250 Engine Noise
- Could replacing an Axel throw off an alignment?
- Manual AWD 3gr-FSE
- 2002 Camry Brake lights not working, except the middle
- Japanese Made Air Filter?
- Any potential issues with storing an open bottle of oil for a few months?
- air snorkel on 05 LS430- quick question
- Lexus Oil Change
- door locks
- IS250 at 97K?what should I maintenance?
- How much for maintanence?
- My SC400's new engine noise? Videos with Sound inside
- Toyota Red Coolant Equivalents??
- need help with my 5 speed sc300
- GS300 Coolant Drain/Flush
- Speedo and tach issues
- Castro edge vs Mobil 1 synthetic
- Tools
- 1993 ls 400
- 2000,rx300
- crankpulley
- 2003 LS 430 starting problem
- 93 sc400 rough idle
- 2003 ls 430
- need a body part!
- Do I need an alignment?
- Help !! Water under the seats.
- How long do break pads last?
- 03 GS w/ "Heavy door"
- Helpp guys DTC 13
- TRansmission Flush
- Lexus 10K Miles Synthetic Oil Change Interval - Is it Official?
- Need fuses
- Dash lights on after having new shocks installed????
- minor leaks
- MAF Cleaning
- Please help me identify this pulley (RX330/ES330)
- Best tips for maintaining car engine
- Anybody know the wheel order for bleeding brakes on a gs400?
- 98 gs400 passenger door
- Replacing sparkplug on Lexus 2001 GS300
- Need to add a little coolant (red)?
- rear differentail
- RPM gauge rises but it doesnt push to its potential.
- 2008 RX400h Brake Fluid Change
- What does a blinking seat belt light mean?
- Oil and Filter Change $135.00 RX 330
- online parts store
- Is my IS getting old? check engine light went on twice this week
- Pinion seal leaking
- IS300 Stiff problem MPG goes to 80
- Transmission Fluid removal question
- what throtle cable do buy for my q45tb on my front facing manifold
- Independent Mechanic in ND?
- 2002 GS300 - Need help identifying this part!
- 2002 GS430 Timing Belt + Water Pump Charge
- Looking for online vendor for Lexus Air filter
- Independent Lexus Mechanics in Birmingham, AL and/or Jackson, MS?
- 2005 LS 430 driver's door speaker cover replacement/repair
- My ac light is blinking GS300 2004
- My driver side door lock is not functioning
- DIY Gone wrong - Knock Sensor and Coolant Gasket Question - Need Help
- Independent Lexus Service in WA State?
- 99 rx300 running lights are out. How do i fix them
- nothing electrical works
- cant pull codes for some reason
- Replacing High Mounted Stop Light Bulb
- no exccelaration
- 2004 RX 330 amp vs battery problem
- Need some help please!! Any one!!
- Mobile 1 Dextron 3 ATF vs Dextron VI?
- where is the thermostat on my lexus gs300
- 1994 lexus gs300 overheating
- Lexus service in Austin, TX????
- 2008 RX400h AWD - 30k maintenance
- lx 470 pwr steering fluid leak
- 2004 SC430 Creaking / Rattle Noise
- Help!!! Any help would be appreciated!
- GS400 Oil Change
- How do I replace my side door mirror?
- DIY questions - Starter repair for a GS400
- problem on fill up the tank
- Sewell Lexus Online wtf?
- Car hard to start - 2nd GS400 - advice needed
- SC300 - Annoyed by high cold idle
- New Timing Belt for '93 LS400 - What else?
- Need help from a toyota employee...
- M4 relay
- GS300 won't start - fuel filter?
- Please help, car shakes, jerks
- !!! Need help fast gs 400 making knocking sound did run perfect ???????????? ??
- 97 ES300 Misfire problem...need help please!
- code 1349 fixed :)
- Please help: Need to replace window on 2004 RX330
- bent rim?
- Toyota approves extended OCI (with their 0w20 synthetic)
- 3M Headlight Protector removal
- Spark Plug question (non lexus)
- checked and cleaned my vvti filter on my 01 430 today
- Cold weather items
- 1999 RX300 Stalls when idle
- Diesel in the gas tank... Help!!
- Purolator PL20195 PureONE oil filter
- Automatic car wash under cold weather
- ES300 tail light fuse
- Brake pad question
- changed my plugs and guess what i found
- Should these be replaced?
- Car won't start
- Engine Clean
- gs430 vvti filter?
- Water pooling in rear on passenger side
- any lexus techs?
- Extended Warranties - need advise
- Engine Coolant Drain Plug
- Oil pumps comparision - which one to choose?
- driving with engine oil filler cap off
- 2001 gs430 check engine light with code p0136
- Best spark plug for my 2001 gs430
- We can service your Lexus in MN!
- Block Heater Install
- 2004 LS430 timing belt change time?
- New Lexus Employee
- NEW GUY and need help and advice.
- New piston rings - which brand should I choose?
- ABS sensor resistance value
- crank shaft sensor location
- Switching oil grades for different seasons
- High mileage oils
- Switching back and forth with synthetic oil
- How long can you store/hold oil for?
- 98 GS300 Cranks but wont start?
- Problem with lighting under gear shift
- replaced maf but now new problem
- Calling out all Brakes Experts
- Rotor Resurfacing/How do I remove the rotors?
- fish tailing
- Problem with Lexus Platinum Warranty. Any advice ? PLEASE HELP !
- Oil Maintenance Light on for 2IS
- fuel induction
- Toyota Soarer (SC chassis) Power to Fuel Pump
- 1992 sc400
- Need help with sc400
- car won't start/turn over
- rotors inspection
- Looking for a quality floor jack
- gs300 blinking gas light
- 12V roadside jump starters
- VSC off light
- Problem Starting the car (Start Button)
- 92 Sc300 overheating and sputering
- 2004 RX 330 Timing Belt
- Performing your own maintenance, keeping records, warranty issues
- DIY - What tools do I need to change tires?
- Alternator & Batteries
- 93 sc300 maintenance questions, from oil to timing belt
- Any Harm Waiting a While to Replace 02 Sensor
- Corossion on positive terminal
- 100k mile service
- Aftermarket air cabin filter
- Gasoline 87 or 91?
- Lucas products????
- Heater display discolor
- Lexus lubrication service - what type of grease?
- Repairing fuel/brake lines using flare tool
- Disposing car fluids
- How to remove cylinder heads withouth messing with timing belt
- Cracking/ ticking noise sc300 help!
- Ball joint tool
- 1999 RX300, 1315 Diagnostic Code
- Brake pad change question
- wiring a swap
- P1349 Code on 99 GS400
- has anybody changed the battery terminal on your Lexus???
- Brake pads ES 350
- w58 tranny fluid
- RX350 Transmission Oil Change DIY?
- 99 GS3 running lean, opinions?
- Question about oil change
- intake help!!
- SC wants to die after i start it
- Winterizing Your Car 101
- Do we still have a Lexus tech on the forum?
- looking for good repair shop/mech in the Boston, S.Shore area
- oil filter for 1jzgte???
- SC400 wont start every time
- Brake Fuses keeping burning up!
- Oil leak!!
- IS 250 30k Service Help
- can i just boost it? no rebuild necessary?
- Sc400 won't start
- Need help with a dashboard indicator light
- HELP cant figure this one out!!!
- Vacuum Diagram for 1993 Sc400 images/pictures needed..
