2004 LS430 90/100k Service List
I see varying schedules out there and varying replacement and inspection items too.
Based on the owner's manual and what I've found with some searches, here's the list I've come up with, although I do have some questions about add'l items I haven't found an answer to. I normally replace or perform the services with a "?" in front of them at this interval, but I can't find any info. on them. Any suggestions?
WHAT NEEDS TO BE DONE
T-belt
Wtr. Pmp.
Air Filter
Trans Fluid @ 60k
Diff Fluid
Replace Coolant with Toyota Super Long Life @ 100k
Replace with Motul @ 30k
Spark Plugs @ 120k
Valve Clearance @ 60k
?PWS FLUID
?FUEL FILTER
?IDLER
?TENSIONER
?CAM SEALS
?CRANK SEALS
?VLV CVR GSKTS
LOOK OVER
BJs & Dust Covers
Full Nut & Bolt
Steering linkage & Boots
Brake Lines
CV Boots
Exh. Leaks
Re-Tq D/S flange bolts
Thanks in advance.
T-belt
Wtr. Pmp.
Air Filter
Trans Fluid @ 60k
Diff Fluid
Spark Plugs @ 120k
?PWS FLUID
?FUEL FILTER
?IDLER
?TENSIONER
?CAM SEALS
?CRANK SEALS
?VLV CVR GSKTS
LOOK OVER
BJs & Dust Covers
Full Nut & Bolt
Brake Lines
CV Boots
Exh. Leaks
Thanks in advance.
?PWS FLUID - when dirty or working on ps pump or r&p
?FUEL FILTER - ?
?IDLER - if noisey, when doing timing belt
?TENSIONER - see idler
?CAM SEALS - when doing timing belt
?CRANK SEALS - when doing timing belt
?VLV CVR GSKTS - if leaking, also replace pcv, grommet & hose
?FUEL FILTER - ?
