door locks
Old Jul 12, 2010 | 09:08 AM
robertmark's Avatar
robertmark
Default door locks
Just suddenly my drivers door lock does not respond to the key fob. The other doors work correctly, but just the drivers side does not respond. It does work manually. Is it a fuse or something? Or does it require maintenance from dealer. The model is an 02 gs 300. I hope someone has a fix for this. Thank you
Last edited by robertmark; Jul 12, 2010 at 09:11 AM. Reason: did not include car year and model
Old Jul 12, 2010 | 10:09 AM
GSteg's Avatar
GSteg
The door lock actuators are out. It's a common issue on the 98-05 GS300/400/430. Search for a DIY in the 2GS forum. New actuator will cost you $200, but a DIY will be less than $20 if you're up for the task.
Old Jul 12, 2010 | 10:32 AM
robertmark's Avatar
robertmark
Default door lock
Thanks for the solution. But I can't find this 20 dollar part anywhere in the web site. Where am I not looking? There seems to be no direct link to parts and the search comes up with nothing
TrueGS300
RX - 1st Gen (1999-2003)
Mar 9, 2019 10:40 AM
Bocatrip
Nov 15, 2018 05:22 AM
pmaximus
May 24, 2016 10:58 AM
Vlad_Stein
Feb 8, 2010 09:25 AM
JPHol
Dec 20, 2009 09:18 AM
