98LS Rear Subwoofer removal
Hey guys i just got a system installed and i want to remove the rear sub so i can get more air into the cabin, i took out the 2 bolts that are visible but 2 more are hidden, how do i remove those????
Thanks,
Aaron
Thanks,
Aaron
3UZ-FEEEE
Thanks,
Aaron
Thanks,
Aaron
To remove the seat back, you have to take off the headrests, (to remove those 2 bolts) then open up the center console, and remove bolts from behind there... that should give you enough access to tilt the seat back.
The Screws dont budge even with wd-40 so I still didnt get it done but do you think i should do it anyways???? The whole back seat is like bulletproof and all there is is that 1 little whole, will it make a diff or should i leave it in.
Thanks,
Aaron
Thanks,
Aaron
3UZ-FEEEE
Thanks,
Aaron
Thanks,
Aaron
BahHumBug
u have to remove the entire rear seat, both bottom and back in order to get the rear deck off, so you can acess the screws.
despite the generation gap this tutorial applies almost unchanged to your car.
http://www.lexls.com/tutorials/audio/subwoofer.html
There is also a quick way of doing it , atleast i did another way.
If you pop up the sub cover then use a wrench and all 4 bolts then you can lift it out of the hole
jpv7774
03-18-19 01:25 PM
