View Full Version : Suspension and Brakes
- **Brake rotors choice?**
- front strut bar for 1st gen gs3
- Recommendations for Camber
- Front Seats
- tire wobbles at 60mph??
- upgraded steering
- Tein S-tech Springs
- is alignment needed?
- Daizen Lowering Springs
- When you lower your car, why does the drivers side sit a little lower? maybe .25"
- Great New Tires On My Gs
- Daizen sway bars..opinion(s)
- What's up with the new GS brake pad design?
- Bilstein Sports and L-tuned Shocks: Pics side by side
- L-tuned Springs: the end of the speculation
- Camber kit for gs400?????
- GS430 Strut Tower Bar - Keep the Cover!
- L-Tuned Suspension+ Alignment Issues..Help!!
- trd lcb, front rear sways, stb installed and...
- how low till you need camber adjustment
- Are these any good?
- tomorrow is the install.
- Got my APEXi WS coilovers installed ... My thoughts and feelings
- Newbie question on sways, shocks, and braces
- Camber kits for gs 300
- help w/ rear Daizen sway bar installation
- Do the new Gold LS430 fit the GS300/430?
- Brakes making noise
- Adding New Springs -- Alignment Needed?
- EBC Greenstuff upgrade - need to resurface rotors?
- Difference in stock suspensions
- tein HA'S
- curious install $ control bar, front and rear sways
- Do I need to take off my TRD STB to remove the engine cover?
- how low is low?
- Brake Pads
- Ohlins coilovers?
- APEXi World Sport Coilovers - Thoughts n' Feelings
- Does anybody have HKS LS on there car?
- shock+springs shop near Germantow MD
- somebody please help (handling issues)
- ***removing brake calipers***
- Brake Bleeding Tool Recommendation?
- apexi coilovers?
- backward rotors?
- Shaking and noise in my '99 GS300
- tein flex
- jsut installed the suspension...
- guys w/ 19's h&r springs vs. eibach/ltuned
- daizen sway bars
- ** New Tom's RAcing suspension item**
- Front Upper Strut Bar?
- wanna pics 18's lowered ltuned/eibach
- Supra TT Brake Conversion
- ATTN: GS'swith 19" wheels
- Shim & Fitting Kit Installation for SupraTT Calipers
- HKS LS Coilover height?
- I need new brake pads
- Brakes Install
- Help!!! Where to get good price on Apexi coilovers
- My lexus dealer says that my Tom's RLCB or 6-piece kit won't fit on my car!! Help!!
- Installing L-Tuned Steering ECU
- For those of you with Tein CS and 19s
- Anti-Roll Bar materials
- HKS Coilover VS Tein Coilover
- GS Front Brakes Diagram?
- Just ordered my new suspension!
- Help with funny squeaking/scraping sound....
- tein flex or cs
- Tein CS Impressions
- Vibration
- TEIN CS assessment
- Ltuned suspension
- LTuned Steering Ecu
- Need opinions about my next mod...brakes
- JIC suspension unit?
- tom's suspension parts for a first gen gs?
- Taking off the front and rear bumper?
- Adjusting my TEIN CS coilovers
- A review of Tom's F&R STB, F&R LCB, and 6-piece suspension kit, plus questions!
- trd lower brace
- TRD race sways + Teins = Video
- coilover spring rates
- EDFC location
- readjusted the daizens
- Need help on install rear brake pads
- Replacing Stock Rotors with Slotted and Drilled
- TRD vs Daizen Sway Bars reviews – VERY LONG
- Question about this type of lowering
- Daizen Sways
- Daizen vs. TRD - Subjective Debate & Experience
- L-Tuned Steering ECU?
- Describe how 20's ride
- L-Tuned & tires for GS430: results
- Tein HA
- L-Sportline Suspension, need new shocks, l-tuned?
- So What Are The ACTUAL Differences - Daizen vs. TRD?
- Help...Anyone ever heard of Beck Arnley Brakes?
- L-tuned installation cost
- Choice of Brake Rotor and Pad for GS4
- Will Shocks & Springs Alone Decrease Body Roll?
- Are Beck Arnley original Lexus Pads?
- Warped Rotors, replaced under warrenty?
- Cross drilled rotors - question???
- Quick question...Sways?????
- Camber Issues (help)??????????????
- Daizens WOW WOW!!!!!!!!!!!!!!!!
- Anyone know where I can get Lexus Brake Pads?
- Busted Sway Bar Bracket
- EDFC Install Project: GS400
- Daizen Sways feedback here......
- How does your car feel on big wheels and a different suspension?
- My new toys came in today!! (Stoptech brakes)
- daizen sways coming
- Bilsteins and TRD Sways install?
- Slotted Drilled Rotors
- Rotors warped
- Alignment settings...
- Brake Shuttering?
- upkeep on coilovers
- alignment problems with coilovers?
- Does the Tein CS Rust?
- Just had my TEINs serviced -Impressions
- JIC or TEIN?
- Second mod of June - installed H&R 25 mm spacers
- H&R Spacers
- Anyone tried to use Tein Flex without pillowball upper?
- Wheel Spacers
- proper spots to use floorjack on gs400
- L-tuned - raise front?
- Looking at H&R springs...
- Tanabe Sustec Pro S-0C Coilovers
- Trd Sways
- which mod??
- Firestone or NTB?
- Sways before Strut bars?
- TEIN Coilovers, which one rides the best!!!
- What's your opinion on the best value in a handling upgrade?
- TRD Sway bars - Stocks Bushings???
- Rear-end ducking
- Trd Front Lcb And Tom's Rear Lcb Combination?
- L-Tuned Springs on SportDesign
- Bilstein Sports
- lowest drop?
- What would be the best combo for me?
- Brake Issues - need some help
- Superior Brake pads for mainly spirited street use?
- Rmm Stb
- RaceConcepts.net?
- C/D rear stock size rotors - Where to buy?
- Applying the brake when braking.....
- got apex coilovers today
- Installed rear UGO STB myself, driving impressions and PICS ADDED
- is is possible for big brakes to be (aesthetically) too big?
- ugo strut bar
- How Do I Bleed The Brakes?
- Tein CS and JDM 18's installed (pics) what spacers?
- Bilstein PSS - Detailed Impressions
- For members with Eibach/Bilstein
- 355mm (14") vs. 322mm (13") brakes...
- goodrich brake lines
- Review (more for noobs and fence sitters): TRD and TOMS
- Master Cylinder Problems?
- Tom's or TRD strut bar???
- L-Tuned Shocks & Springs on GS300
- Braking System - How Proportioned?
- eibach prokit spring specs question
- Jic Majic Sf-1 Info???
- Supra TT brake upgrade question
- Daizen Control Arm Bushings 4 GS?
- l tuned steering ecu problem?
- Rotora brake package?
- Rubbing after new shock installl .. WHY?
- ltuned noise
- INSTALLING COILOVERS!!!! question
- Coilover Installation question
- Supra Brakes Impact On Stock System
- Please help: Bradi stock rotors as good as Brembo?
- First impressions: Eibach / Bilstein combo
- Spring/shock&wheel/tire Combo
- spacers
- will putting on spacer effect steering feeling or handling?
- Wheel bearing noise??
- Suspension issues
- Stock Suspension KYB?
- Tom's 6-piece suspension brace kit? What does it do!?!???
- GS430 should I force the Steering ECU?
- front brake wear more on pass
- Wear and tear on Teins
- Need help regarding my calipers
- steering ecu, does it make much of a difference?
- Want to upgrade my suspension now.
- Espelir vs. L-tuned springs
- Creaking sound from front right strut ?
- I-Rotors any good?
- Just had the TRD Front STB and Cusco Rear STB installed, but don't feel the change?
- BILSTEIN n TEIN
- What spring is the *Smoothest* of them all?
- Any Pics of Your Ride With Painted Calipers?
- Question Regarding Eibach Springs
- camber kit for gs 400
- Coilovers !
- Brake rotors
- Help!! Tein Flex rattling
- For those with TEIN Coils
- Powder Coat
- HKS LS vs Tein CS w/EDFC questions
- Brake Pads Poll???
- Current brake setup just not working out
- HKS hiper coilovers? any good?
- Inexpensive fix to body roll - Daizen polyurethane sway bushings
- L-Tuned Springs/Shocks
- Steering wheel weird feel
- I can hear squeez sound from suspension when i make a U turn.
- Which spring will slam the most??
- Steering Feel
- Which Are The Best Brakes?
- TOM Rear Lower Suspension Brace
- Big brakes and dust shield
- Bilstein PSS coilover vs Tein HA coilover
- question about coilovers with 20's
- Spring / Shocks Combo?
- how long should i wait to get new tires
- ss brakelines
- Mechanically Challenged Suspension Questions
- Quick brake question...
- AP/Brembo Owner Please
- Bleeding My Brakes
- How long did it take for your springs to settle ?
- Stock Calipers pics painted in red (I know), black and silver
- Endless brake pads
- L-tuned suspension rattle
- Pictures of my Tom Rear STB install
- Please Help!!!
- Stoptech Brake
- Tein HA revisited
- TRD LCB Install??
- pros+cons of upper mounts
- Flex Settings???/
- Sway Bar Diameter Question
- Rotors
- Lower Ball joint prob.
- where to buy steering ECU?
- Tom's Post Brace Review
- Tom's Post Install, Part II -- Bye Bye Resonators
- So why doesn't Lexus put strut tower braces and chassis braces on from the factory?
- Race Tech or Power-Slot
- 19 wheels void any warranties?
- '01 GS430 L-Tuned
