- Jdm trans not shifting right
- Memory seats not working
- Decent and cheap roof rack cross bar replacement
- Exterior fashion items
- HL swap Halogen to LED
- Transmission problem
- Floor mats/liners
- My "New" Car (Part 2)
- 2000 RX300 Instrument Panel dead
- Discovered Lightweight Crank Pulley still available for our engines
- CEL monitor codes
- Brake light flashing and continous beeping
- alternator's 12v+ nut size
- Spark plug change. How much?
- Interchangeable body parts
- So I'm doing my oil change, and this fell out
- removing oil pressure sending unit
- 2001 lexus rx300
- My "New" Car
- Car Idling Rough after Timing Belt Change - Fault Codes
- Shifting Issues after Knock sensor change
- P0325 even after knock sensor replacement and bypass
- Corroded Battery Cables
- 2002 lexus RX300 will not drive when in gear
- Replacement bulb in 2000 RX300 headlight assembly
- 2000 RX300 loss of power
- tried to fix antenna, now no radio or drivetrain?
- Broken ash tray - possible fix without console disassembly?
- Only 1 radiator fan turns on with AC
- new cel codes to decipher P0301 p0303 p0304 p0305 p0420 p1300
- Srs dtc b0113 rx300
- Check engine and VSC light
- Trans guy blames RX300 ECU for CEL
- Recommendation for a Jump N Carry battery charger
- New rear rotors and pads ,NOW SEEMS LIKE PARKING BRAKE ON!!!
- Loud knocking noise on cold start
- Po770 transmisission
- In-Depth Specs of the AWD System
- Is there a Oil/Maintenance Reminder for the 2000 RX300
- Mouse nest in cabin air filter/HVAC not working now
- RX300 Front seats leather repair, help !!
- lock actuator
- Hissing Noise at High RPMs
- Please help. Rx300 going to kill me.
- P0370 & no overdrive... Knock sensor?
- engine oil change interval
- 2000 RX300 Key Fob Programming?
- 99 RX300 Low beams not working, high beams seem dim
- CEL codes P0301, P0303, P0305 need help with fixing.
- swap 99 rx300 transmission into 2000 rx 300
- End of an era - goodbye
- First time trying to change O2 sensor (P0155)
- Leaking freon
- Denso vs Bosch A/F sensor (bank 2 sensor 1)
- Cant find rear clunk noise
- Driver Seat Belt Light is OFF
- HID Bulb Replacement
- Timing tensioner pulley bolt.. thread size/pitch?
- Radio Antenna for 2002 RX 300
- shifting problem
- worth switching to synthetic at 250k miles?
- I decide to check the cabin air filter . . .
- minor differences in exterior aesthetics
- 2000 Lexus RX300 Bolts??
- 99 RX300 No Starter Signal
- Lexus smoking and fuel consumption above normal
- Gurgling Noise
- HVAC hoses
- Liftgate/trunk no longer locks
- Transmission shifts funny
- Rear Door latch sticks in up position
- Valve cover sealant - where to apply it?
- Heated Seat Switch Wiring
- What could be wrong?
- Another OEM transmission bites the dust
- Rattle can for bumper cladding
- 2000 rx300
- AF Sensors
- Possible 2001 RX alternator problems?
- 1999 rx300 not shifting into 4th gear and OD
- stuttering after replacing read o2 and MAF
- RX 300 steering wheel
- Stupid question: Should I fill my tires with PSI rated on the door or the wheel?
- Lamp Failure Sensor
- EVAP Monitior Drive Cycle and a Whistle Noise???
- Secret cupholder?
- 2001 RX 300 Motorized Antenna Problems
- Air door actuator
- Check engine light and VSC light due to exhaust leak?
- RX300 Brake Pads Replacement Cost
- Specific directions for oi pan removal/replacement?
- 1 of 2 remote control can lock/panic, but cannot consistently unlock doors
- 2nd transmission rebuild
- Lost only key for 2000 lexus rx300
- Tail Gate Only Stays Open Above a Certain Temp
- Top Tail Light Replacement
- 2001 RX300 Shocks (Struts)
- P0330, VSC and ABS
- Fuel Tank overfill check valve?
- 2002 RX300 - Low Miles - Will not shift to high gear - High RPM
- Timing belt kits
- New User Engine Error Codes.
- Vibration at idle in every gear but neutral.
- VVT Failure?
- Second opinion sorted on wheel fitment.
- Transmission options - Used, Used Japanese, Reman, Rebuild
- Brake lights not working
- How do you remove the hood squirter nozzles?
- PO442 & Texas Emission test
- Radio - sound issue. Keeps going ON and OFF
- Front License Plate Install
- Gen 4 navigation upgrade complete, but curious
- ez pass transponder placing for 2012 rx350
- K40 UN3000 found in my ‘01 RX300
- RX300: DIY Liftgate Lift support replacement write-up
- Exhaust leak in center pipe in front of muffler diagnose by dealer
- VVT Sensor
- Where are the other two servo's under the shifter?
- Wanting to change valve cover seals
- AC/Heater Blower - Need Relay Location
- Rear Lift support strut replacement part?
- Spark Plugs - to change or not to change?
- P0171 P0330 P1150 - 2000 RX300 2WD - Suggestions Please
- 2000 lexus rx300 cranks to long before it starts
- Help, Error Codes, low gas mileage, lazy acceleration
- Door unlock FOB options
- RMS Question
- my lexus stalls out on starting
- -rx-300-tail-light-indicator
- Right or left wheel locks up at speed in turns, stop when vsc comes on
- OBD2 Scanner
- Power loss
- 2001 RX300 dies after 30-45m
- OEM 50/50 Coolant mixed with Red- Flush?
- Braking noise -- bad ABS parts?
- 1999 Lexus Rx300 cigarette lighter relay location
- RX300 R & R OEM Subwoofer questions
- 99 RX300 Multiple Code Issue Help
- hello one and all
- Horn chirp when unlocking tailgate with key (randomly)
- Intermittent electrical ac, temp gage, MPG
- 2001 lexus rx ecu removal and reinstall DIY
- Alignment after rear struts?
- 2001 RX300 AWD Parking Brake Cable Adjustment Question
- Rx300 Slip in 1st and reverse
- Oil leak after oil change service
- No LCD
- Severe Shaking and Steering Wheel Vibration
- Fueling Problems
- Transmission Issues 3rd==>OD and 2nd==>1st
- CR2 12V relay
- a/c noise
- Where can I buy the EVAPORATOR Temperature Sensor
- Disable Limp Mode 99 Lexus RX300
- Help Needed : Air conditioning problems
- Part number of the 10mm VVT (OCV) bolt?
- 1999 rx300--AC light
- Anyone Towing with high mileage RX??
- Transmission Drain Plug Tightening Torque Spec and Gasket questions
- VSC & TRAC OFF lights on, but no CEL?
- How to replace front brake caliper???
- Front right axle
- Is my RX "Trade-in-able" despite its age?
- Speaker Replacement Recommendations
- Is this the oil used in the oil change thread?
- Engine Immobilizer
- Parts diagram and/or numbers for Catalytic converters
- Check Engine Light and VSC light on
- Installing a new Radio
- Battery Drain
- aftermarket radio
- A quick rear wiper arm / motor question!
- odbc ii scanner
- '99 RX300 won't start, single click and then the electrical system dies
- Radio-theft deterrent design concerns
- Keyless entry compatibility
- '01 RX300 A/C Compressor - HELP
- Successful engine pull from top
- Hi I’m New
- How to Fix Rust Around Your Wheel Wells:
- Front Plastic Splash guard Pan Delete - ?
- How do I tell if it's my transmission or transfer case
- Transmission or front axles?
- drivers door window and central locking not working
- 2000 lexus rx300
- Rear end swaying left & right
- DTC's thrown...
- Flickering Lights and Transmission Stuttering: Related?
- Alarm goes off for no reason
- Flashing CEL, engine slightly rough
- Possible issues after timing belt
- Terrible vibration issue
- Loud Popping Noise and White Smoke from Underneath the Hood
- Semi clogged catalytic converter
- transmission grounds rx
- How do I disconnect the antenna power
- Clicking Noise by Middle Counsel of Car
- fabuloususa.com now a redirected site.
- 2001 rx 300 won't shift into overdrive
- P0125, P1155 and possible P0171
- timing belt
- No LED light when lock & unnlock buttons are pushed
- No LED light when lock & unnlock button is pushed
- Thermostat
- 00 RX300 AWD starts and then cuts off
- Going to drain tranny fluid. Just want to be 100% sure
- 99 RX300 mechanical issues
- Should I. 2003 rx300 with 126,000 miles???
- Anti theft was set after battery change tried all basic tricks
- Rx300 p1663
- Whining at 30-40mph
- 2002 Rx 300 headlight sensor and battery indicator stay on
- Lexus RX300 (2002) transmission issue
- VVT Solenoid is Stuck
- IACV question
- New Speakers are distorting
- Confusion on Bank 2 Sensor 1: is it "Mass Air Flow" or "Air/Fuel Ratio" sensor?
- Knock Sensors-Need Help
- Car heater issues - Need help
- Driving steep grades with large elevation gains
- How hard is it to change AIC valve?
- 2000 RX300 Code PO325 after replacing both knock sensors and harness
- What to know if my 2000/2001 lexus RX300 is a 4WD
- Transmission in limp mode. Knock sensor code.
- horsepower thread?
- Is there a DIY for changing front valve cover?
- Stutter on every shift with dim bottom light upon acceleration
- Wiring a Auto-Dimming Mirror
- What's the real difference between the Denso OEM filters?
- replacing lower control arm and ball joints - what else?
- Shift Solenoid Mechanical Function Testing
- 99 lexus Rx 300 not getting over 40 mph
- fuel gauge not working
- lexus RX300 not moving
- Oil leaking onto the TOP of the transmission housing
- rx300 high idle speed
- Lost wallet card and key fob for a 2001 Lexus RX-300. Can I bypass?
- Does this plug look okay?
- what is German Castrol
- Cost of replacement catalytic Converter for 1999 RX300?
- Removal of interior trim panel?
- Interchangeable transmissions
- AWD or FWD transmissions: Which is the weak one?
- Transmission failure at 175,000 miles and solution.
- back firing out the intake and rough idle???
- Windshield Washer Motor Replacement 2000 Lexus RX 300
- Transmission Failure
- Lexus rx300 gear jerking
- acceleration
