I started the car and I wanted to seat the memory seating, but it won’t work. Anyone know why there’s an issue setting and using the memory? I hear no beeps.
My lumbar supports doesn’t work either. But I can still move the seat manually.
There are some conditions one has to follow to set the position. Shifter in Park - foot on brake etc. Please check the owners manual.
Next thong to check would be the fuses.
They are not beeping, you do not have power to them. Lumbar does not work, you do not have power to it. It's that simple. There are nasty little buggers called fusible links that are past fuses and in the wiring... total pain to locate blown one and have it replaced. You need to check voltage supply to the seat and memory buttons module.
