HVAC hoses
Vacuum is not used to modulate vents in RX. They are controlled by servo ... [electric motor that pushes/pulls various rods/cams.]
Please search on "MODE" ... if you take the auto out, you should be able to control the air flow by the mode setting. Also dont confuse it with the air mix servo [temp].
Salim
Salim
jack6942 (07-16-18)
