DTC's thrown...
DTC's thrown...
I took my 01 RX300 with 286K miles to the dealership to have the codes read. It only came up with one P0171. The service mgr showed me on his computer that in his database from techs reporting to a subscription database that on that particular code, out of 194 cases reported 181 times it had been the MAF sensor needing replacement. Sounded like pretty good odds to me and a Denso MAF cleared the code. After driving a few miles my CEL came back on. This time when I pulled the codes it triggered multiple codes: P0174, P0300, P0306 and P0136. I haven't driven the vehicle for a couple of years, but less than 1K miles prior to parking it I replaced the knock sensors and wiring harness, plugs, ignition coils, MAF sensor, timing belt and water pump, the variable timing solenoids and bank 1 and 2 O2 sensors.
With the rig idling I did spray starting fluid around all the places where I could possibly be losing vacuum with no discernible change in RPMs. The vehicle is running fine, but I need to get to the bottom of this.
Does anyone have any thoughts on what system/component(s) would cause all these codes to trigger at once? Thank you for any help you can provide.
I also replaced the IACV...Regarding the misfire codes: I can detect no misfire or misfire related performance issues even when accelerating hard...
Multiple codes...
Your question did remind me though that I made a 600+ mi trip to WA and back to pick up a tow dolly last August. Thanks so much for jumping in.
BTW, I loved your tutorial on the downstream 02 sensor replacement and have one on the way. A starting point on the rest of it would be great.
Get a bluetooth OBDII reader and torque app for your android phone, reset the codes, and see which one comes back first.
Report short and long term fuel trims and MAF reading.
Were the parts you replaced all OEM or Denso?
BlacBeaute
11-28-11 11:18 PM
