Srs dtc b0113 rx300
Old Aug 15, 2018 | 01:49 PM
ejdossary's Avatar
ejdossary
Default Srs dtc b0113 rx300
I had a bad driver seat Buckle. The Buckle light was OFF. Replaced the Buckle with new one from Lexus. Seat Buckle light came on fine. At the same time I had my Airbag light Flashing. I suspected that my Buckle was the cause of my problem. However, after checking the DTC from my INNOVA 3150b, I found a trouble code "B0113" past and current reported on my Scanner. Cleared the code and 10 days later I the Airbag Flashing again. The B0113 code was annotated on the scanner as "Short in Side Squib (RH) Circuit (to +B). i need help in locating the short and where the Side Squib (RH) in located on 2002 RX300. Thanks for the help in advance.
Sincerely,
EJDossary, EE
Old Aug 23, 2018 | 10:54 AM
ejdossary's Avatar
ejdossary
My RX300 Airbag Flashing light had a DTC = B0113 (Short in Side Squib (RH) before and after replacing the drivers seat Buckle. I reset the this code the first time. 10 days later the Flashing light returned. I reset it again to make sure the the problem is NOT present. 8 days later the Flashing Airbag Light came back on AGAIN !! Help does any on have any idea where the source of this malfunction. All I could think of is probably a connector issue at passenger front seat. That could be wiring short, sensor problem, or seat belt issue. I would be very thankful if someone has had experienced the same malfunction in their Lexus RX300 to reply. I really do not want to tear the passenger seat location to troubleshoot the problem if a member experienced that same.
Thanks, EJDossary, EE
Old May 19, 2019 | 08:04 PM
ejdossary's Avatar
ejdossary
Help, anyone having problems with Flashing Airbag on 2002 RX300 Code B0113 RH Airbag Squib B+ short??
I reset the code and the Flashing Airbag still comes on. Check yellow cable. Seems to be fine !! Any ideas??
Regards, EJDossary, EE
Old May 20, 2019 | 05:46 AM
salimshah's Avatar
salimshah
25 Year Member
Seems like no one else has run into this issue.
Only suggestion I have is to expand your search to include other models of Lexus in CL or check Toyota boards. If you do find an answer, please followup and post here .. just incase some one in the future has to follow your footsteps.
The only cautionary note I remember associated with airbag sensor is not to insert to turn the ignition key to run with the battery removed. Since no work should be performed with the battery installed, I always put away the key as long as I am working on the vehicle. If by chance you have done this , then narrow down your search to this particular case.
Salim
Old May 20, 2019 | 08:37 AM
maxSteel's Avatar
maxSteel
Salim
The "Supplemental Restraint" manual actually says the SRS system has a backup power source and you must wait at least 90 seconds after disconnecting the battery and turning ignition to lock before starting to work on it.
I've never worked on the airbags. I don't like the idea much.
Old Apr 18, 2020 | 11:30 AM
ejdossary's Avatar
ejdossary
Still struggling with Airbag Code B0113. I have Airbag simulator plugged into the yellow connector instead of the Side Airbag itself.
Once I clear the Code with my Scanner, the B0113 Code is displayed again. I replace the Airbag yellow connector and even
that did not solve my problem ?? Anyone have the same issue, please reply to this thread. I am beginning to believe my problem
lies with the Side Sensor itself for the RH Squib issue. I will tackle the RH passenger sensor next in hope that will put the problem to BED !!
Best Health Wishes, EJ Dossary, EE
Old Apr 20, 2020 | 07:50 PM
Margate330's Avatar
Margate330
Ok so I see you are an EE so I assume you are fluent and able to read schematics and use a meter well?
If so I have some info on this I can send.
What is suspicious is you replaced the seatbelt buckle and this code appeared immediately after if I understand correctly? Please confirm.
If so I would suspect a distured connector/wire/harness that is internittently shorted to B+(+12vdc) as the code suggests and rule out the Airbag Center Assembly ECU or failed sensor for now.
Seat must come out to inspect wiring and Techstream is advised to continue further because you will want to check everything airbag related.
As others have said this is delicate work and I've heard being clumsy with a meter and probing things that shouldn't can also set off airbags- battery must be unhooked for a while.
rhythms57
Jan 27, 2021 05:07 PM
Demon9059
Apr 20, 2020 01:42 PM
PhilTyler
Jun 21, 2017 09:04 AM
davidyal
Jul 31, 2012 02:35 PM
Grimpy
Feb 11, 2003 10:30 AM
