Second opinion sorted on wheel fitment.
I have found a set of second hand Rays wheels 5 x 114.3 8 inch wide 2x +18 and 2x +37 offset.
Wanting to run the +18 on the rear and +37 on the front.
I believe I will be able to use 255 55 r18 all round of not will stick to 235 55 r18.
Is this an ideal choice seems to me to perhaps work?
I realise I will need new nuts which is the the most trusted brand of nuts?
A quick response would be appreciated as don't think these will last long so want to jump in but be making right decision.
Rear at + 18 with 235/55/r18 i think it will allow wide tire but the front might hinder this.Inner Clearance:
Original 16 inch 6.5 inches 35 mm.
Present 17 inch 6.5 inches 35 mm.
New 18 inch 8.0 inches 18 mm.
Inner Clearance:
2.05mm less
Outer Position:
extend by 36.05mm
Diameter difference:
0.33" (1.16%)
Front at + 37 so much less clearance than rear as whet we usually all look at due to the shocks.
New 18 inch 8.0 inches 37 mm.
Inner Clearance:
21.05mm less
Outer Position:
extend by 17.05mm
0.33" (1.16%)
So what do you think of this fitment. I am limited to this for registration the maximum i can fit without expensive safety checks (engineered) is is 18 inch so looking for my best fitment. Otherwise I will keep looking for 18 inch rx350 wheels with 35 all round offset.
Experts eg lexmex salim chime in please.
Inner Clearance:
2.05mm less
Outer Position:
extend by 36.05mm
0.33" (1.16%)
Inner Clearance:
21.05mm less
Outer Position:
extend by 17.05mm
0.33" (1.16%)
Total change of mind just ordered hyper black 19 inch F Sport style (+35) 2-3 weeks delivery my limitations were 25mm wider and 8% diam increase overall which allows 235/55/r19 being a 7.5 inch wheel.
