- Acura MDX Projector Vs TSX Projector
- Rewiring signals to Fog/parking lights.
- retrofit question
- HID recommendations?
- Does anyone know where?????????/
- How big is the wedge bulb hole in the 2GS headlight?
- Do I need shrouds?
- am stuck on which to pick;RX330 retrofit or gs400 oem hid?
- Does anyone have pix. of
- Just finished my first mod
- LS430 HID question
- Luminics VS Nokya Hyper yellow
- am so confused on my next mod(HIDS), please clarify
- Clear Bumper Lens 4 Rx330
- Audi Retrofit
- LS430 lighting questions
- IS350 D4S bulb
- Has anyone use these?
- 2000 RX300 retrofit kit where to buy?
- will this work for hid retro on es
- HELP with HID installation
- side view mirrors...
- Aftermarket HID kit...
- Will AFS still work?
- does any one have pix of ????????????
- Burnt A/C Control lights
- My 4300K hids
- SC 300 fog lights
- which lights will work in my interior
- Xenon Depot Ballast Failure After Only 15 Months
- Please help me choose (need pics)
- HIR's 2GS
- HID installed now having a HEADLIGHT problem!!!!! help
- DIY Sanding light lenses
- TSX retrofit on SC300 custom template
- Fog light mod in So Cal-HELP
- Arizona Members
- will these work?????????
- 2000 ls400 hid question
- LED's in the foglight?
- which Lexus models have the license plate LEDs?
- Polarg comparison to OEM; thx rominl!
- Trouble with retro fit?
- HID question
- Polarg bulbs
- Conneticut Members - question
- Install 3000k HID fog
- 1995 sc300 lisc. plate bulb help
- LED size for map lights and visors for GS
- HELP for the mechanically challenged
- Question about Kit and Ballasts
- SC300 fog light question
- Does anyone have pics of 4300K installed?
- HID Installation on 2007 Lexus ES350
- Difference between HID and Xenon
- Which HIDs look best on a Black IS 350? I NEED YOUR OPINION!
- Need help with?
- Re: Experiences with Kaixen or Prolumen??
- 5k HID fogs with Sylvania silverstar low beams pics
- Best place to get quality HIDs?
- yellow fogs or white
- RX Projectors
- Xenon kit with 2000 rx300, do I have to worry about DRL?
- Are these reals?
- Can someone help me match these lights
- What is the factory light output of rx300 hids?
- Denso 4300k HID kit or McCullock 6000k HID Kit?
- HID bulbs going bad?
- my low beams look like tunnel vision
- which color goes better with the dog?
- Power/ECT, heated seats, vsc BULB number
- Side marker lamp replacement
- after market hid kits on when high beaming
- will there be any negative outcomes if i use 10,000k bulbs in a oem hids?
- 01 GS300 DRL = 50% high beam or parking light?
- loosing high beam or fog functinality
- GS Headlight Condensation
- Whattayaknow?! Sylvania Silverstar burnt out...
- 35w vs. 55w HIDS
- Found these on ebay
- DRLs disabled Possible...
- GS400 HID turning purple? 3 questions
- Does anyone know if nonworking tailights in sc300 is common?
- Light Question GS400
- How to get HID Xenon Lights on my 94 lex es300?
- simple led mod
- Removing stock HID bulbs-LS430
- Cool Blue
- PIAA Tera
- Everything you wanted to know about HID bulbs
- Ballast location
- Finding a retrofitter
- how many used a relay with your hid conversion???
- How long until new OEM bulbs and ballasts turn more blue/white?
- Which JDM LED Tail lights are good on ebay for 01 GS430?
- LED Bulbs For The Bumper Lights
- High beams as regular headlights.. question!? :)
- How to install HID fog lights
- High Beam Bulbs
- HID color shift...
- My headlights have a HID hack job
- why are 6500k bulbs cheaper than 6000k?
- 6000k Hid VS 8000K Hid
- Need some help with lighting.
- Smoked Out Headlights???
- Burnt out HID bulb or failing ballast?
- Polarg M4's or 5 LED for License Plate Lights?
- To Retro or not to retro...
- Silverstars?
- Needle in dash wont light up?
- sc400 fog lights replacement
- will HID's in stock projectors blind oncoming traffic?
- where was it determined that flashing your HID's is bad?
- i dunno what i did to my HIDs, so lemme explain
- HID lighting
- H.I.D. troubles
- Gs Headlight Question
- Damage other than blown fuse ???
- 1997 Hid Headlamps
- high beam bulb replacement is350
- How Replace headlight bulbs-2004 LX470
- HID System
- Wtb - D2s Bulbs
- Pre-95 SC fog light bulb retrofit?
- Retrofit My 1995 GS300
- Hid Question
- Interior: Polarg vs. LED
- Replacing Rx300 Headlight Unit
- I know HID flashing is bad, but HOW bad is a few times?
- Interior lighting: COLOR CHALLENGE
- who can make me brackets for sc400 hids
- Wiring harness for SC400 9005 conversion
- Taillight Problem
- Map lights Gs400...
- Phillps 6000k
- HID Conversion question
- Blue Fogs
- 50w Hid Kits?
- Need help on replacing bulbs for GS400
- HID Fog Lights in RX330
- Quick HID question
- D2S HID bulbs
- interior led
- GE Nighthawk headlights
- 7000k vs. 8500k H7's for 97 ES?
- 9005 hb3 vs 9005xs
- Bulb out on McCulloch HID kit
- Light bulb condoms/cover
- Which HID Color???
- Question on fog lamps....
- What exactly is W5W bulb ?
- Silverstar ultras
- I need Advice with HID's
- hid right side problem please advise!
- 3rd brake light conflict w/spoiler LED brake light?
- Are all manufacturer HID the same K rating?
- recommended retrofitters?
- Different Bulbs?
- Awesome Conversion Kit
- aftermarket HIDs?? good or bad
- Side mirror lights
- Oh my freaking wedge bulbs
- HID had a problem today, what was wrong with it?
- Whats with the cheap $100-$150 HID kits on ebay?
- sc300 hid kit question
- changing the hid bulbs in 2007 is250
- LS460 - How To Change Parking and Fog Bulbs to Match the Xenon
- Interior Lighting Opions needed...
- OEM ballast w/ rebased d2r on..
- interior lights for 99 GS400
- Please help bulbs size!!!!!!!!!
- Retrofit:(D2R/S) Denso/Koito Vs. Hella & other Ballasts
- need help with HID upgrade
- 92 sc400 lighting electrical problems HELP!!!
- Audi A6 hids..
- daytime running lights for sc300
- Help On Head Lights Auto Adjustment!!!
- Is there a fuse for the Night-time Running Lights (wedge bulbs)?
- what shall i do with my inner headlights ?
- aftermarket lighting 1994 sc400
- Fog Lights
- Replacement High beam light
- Hid Bulb Handling
- Bi-Xenon
- Couple of HID Questions...
- Relay and Wiring Harness Question
- leds
- HID Conversion Pics! NEW
- Are my GS lights stock?
- Sylvania Silverstar - Silver Tipped and Non
- 6000K vs 6500k
- Ebay HID kit rocks!!!!
- Xenondepot kit rocks!!!!
- Question about SC400 dome/map light bulbs
- Do i have to get a kit?
- light bulb info. help...
- GS350 Door Sill Lights
- putting led in tranny shifter console
- Bad light of headlights of a passing light on mine Lexus SC 300.
- vanity mirror light
- Need Help please.. H1 HID Conversion question
- Dilemma
- HID Retrofit Company
- Is this the correct cutoff for the 2GS????
- HID kit for RX350
- Lazy Light
- Q: HID conversion kit for SC?
- Video of 3 different HID kit temps - one GS
- LED for kickboard
- Climate Control LED Change
- noob question
- Is there anyone who sell Inner both tail lamp for ES300 2005 model?
- Headlight questions for is350
- Life expectancy of LEDs?
- NEW Silverstars ULTRA
- Green tint headlamp?
- GS Non-HID to HID Conversion
- GS fog lights?
- Are there any red 7440 LED bulbs that's bright enough?(for tail/brake light)
- 99 LS400 Foglight gremlins...
- noob
- yellow ion fog lights? sc300
- need some advice on Gs400 melting FOG plugs
- is300 headlight question!
- MPH needle below 0 mph
- Need help finding place to buy d4s bulb
- LS 400 RCR Lights
- Instrument repair
- G Miguel & Carson Toyota
- Sc300 HID'ers!!
- Concensus for stock headlight bulbs/LS400
- Looking for 9006 HID kit, is this the best one i can get ?
- HID question
- LX470 Retrofit + Boosted Ballast
- Noob Question: Gauge cluster fix
- LX470 LED makeover
- Color cut-off 07 IS350
- Bad lighting
- Q45 Retrofit completed. Pix Inside!
- new lexus models w/ pure white license plate bulbs??
- 6000K vs 8000K for low beams
- 2nd Gen Gs300 Taillight LED
- Do Casper Shields work for PNP HID kits ?
- INTERIOR LIGHT LENSES SAME FOR ALL GSs
- DRL/High Beam Halogen Bulb
- Stange problem/occurance
- hid in 92-96 ES?
- LS430 Tail Light Lens ....Help
- My PIAA Xtreme White Plus Review
