View Full Version : Lighting
- so i just bought some ls460 projectors
- adding Xenon
- 2nd gen gs3 projector headlight retro???
- Hella blue sucks
- Where to buy genuine D4S Phillips bulbs???
- 96 ES300 LED instrument cluster - Factory dimmer still work?
- HID on LS 400 1993
- HID fog light kits plug and play?
- SC300 headlight bulbs
- retro which one?
- Hid ?
- lexus is250 2g fog light hid help
- 1996 ES300 - Display bulbs behind climate control
- Mercedes 2003 C240 Low beam bulbs
- Replacement D2R bulbs
- 7440 turn signal bulbs for cleared/aftermarket tail light dilema
- These light any good?
- 2IS Headlight problem (AFS) with HID..
- Dash & Interior Lights
- Increasing Headlight "Throw"?
- 96 ES300 - Sylvania 9005/9006
- help, hid flicker and not
- Looking To Do A Full LED Interior Conversion
- 99 RX300 HID Mod ( LB / fogs )
- Need help from Gauge Cluster Gods
- Burnt GS Fogs
- what do u guys think??
- remote fog light help
- HID KIT Installation in Vancouver, BC anyone?
- Luminics Titanium White H11 Krypton Series
- IS250/350 license plate lights
- GS 400 OEM HID Out, What To Do??
- GS300 Rear tail light question.
- Brake Lights
- LED Dome Light
- Changing to xenon 6500k?
- Headlights Question
- Xenon warranty?
- Fog lights aiming
- Tinting the headlights
- DIY Undercar LED lighting?
- ****Where to by LS 430 projectors*****
- Blue Drl
- M45 Projectors, Any Good?
- Brights that work with HIDs?
- 9006 LED, anyone tried yet?
- 1993 Sc400 Foggy Headlight
- cut off line new tsx retro yay or nay?
- tsx retro and deline headlights failure
- Anyone used purple LED's?
- SC400 Retrofit
- Bulbs gets really hot?
- LED tape / strip...flexible
- bulbs for the sc300 95
- LS 430 Conversion Questions??
- daytime lights
- 3rd brake light
- 2001 ES300 HID Temp?
- 2IS HID Fog Relay with Xtreme Kit
- 6000K HID changing color??? WTF!
- Blub question, please help
- 6000k replacement bulbs?
- After market cd player blub replacement?
- daytime and driving lights
- Whats a good parking light to match 6k HIDs?
- Buy new Headlights or Retrofit?
- Front turn signal bulb replacement
- HID compatability
- HID doesn't come on sometimes.
- What type of HID bulbs...?
- SC300 guage rebuild?
- Lexus Is 250 Fog Lights
- Headlight project question
- ls430 projectors or ls460 projectors???
- whats better???
- yellow or clear?
- LED foglights bulbs
- LH Low beam fuse keep popping.
- Changing colors of climate and nak Lights
- Thought all HID's were easy to install!
- Adjustment for self leveling HL's
- POST PICS of yellow DRL's anyone got them?
- hid fog light problems! =(
- hid retrofit questons
- 2003 LS430 looking to retrofit 2004+ projectors
- Turning Signal Question
- XenonDepot vs. MobileHID for 6000k
- LED Bulbs or Hyper Whites?
- Headlight projector measurement
- help new bulbs 90 ls400
- It has begun.... SC400 meet TSX & Yellow Fogs!!!
- Any 6500k or 7500k pic?
- 2GS, which is more yellow?
- Does 3000k HID look greenish? Is this normal?
- Hid Kit
- Is it safe to run HID's without wiring harness?
- Anyone do a retrofit on an ISX50 yet?
- Wiring independant hid foglights
- Sc300 Horrible Light Output!?? Even after Retrofitting!
- 194 led bulbs
- Headlight Connector Corrosion
- lexus auto leveling motors in action.
- Where to Purchase LEDs From?
- DIY: Fix for fogging 2GS headlights :)
- drivers side hid head light fogging up
- light for gear indicator is not working
- Looking for 3000K Golden Yellow Bulbs..
- HID fog lights not working???
- HELP: Weird Cut-Off...
- Adjusting Low Beam
- Glare
- Is Vleds on this forum?
- My hid ballast is blowing fuses!?!?
- HID Brights??
- Which Ebay HID seller?
- tried to swap HID kit to another car -- no longer working. help!
- What are the best non HID bulbs: 9006, 9005, 9004, H3......
- SC400 Trunk Lights - Comparison with SUPERBRIGHTLEDS.COM bulb
- Need help finding part (and lesson learned)
- hid help..
- Another sc300 w/ tsx projector retrofit
- 2GS wedge bulb question
- HID's What Are My Options?
- taking apart headlights on a 98 LS
- Hi From Www.clublexus.eu (spain), Questions About Bi-xenon
- Looking for someone to do projector retro
- LS430 projectors
- Matsu****a twin ballast VS Phillips ballast
- Day, Low/ High Beams Is350
- Reverse LED's
- Custom LED project
- HID for Sc300, Bought 1 from Ebay >_<
- HID fog lights
- HID fog lights install Q's on an SC300/400
- Ok LED run down 2nd gen GS
- HIDS in Reverse??
- gt hid???
- 98 gs4 Will there be a problem with d2c bulb
- HID retrofit, 2LS?
- are bosch hit kits ne good???
- ordering HID bulb
- Looking For New Lighting 3g Gs!!!
- Frustrated!!! Need help on ballast connector!!!
- Xenon Lights and Headlamp Washers
- Same Side Projectors!
- Another GS Full LED interior + LPs + Front Markers - Mucho Pics
- Any1 has 10K or 12K HIDs on their Fogs?
- ES 350 Bi-Xenon
- Red-out Vinyl Tails...Pics inside
- Diy head light restore didnt Turn out so good!
- Quick Newbie Question
- Aristo Retrofit: Before and After - - Pictures!
- Best 6000k d2r bulb and where to Buy
- HID kit Help??
- Raybrig r109 same as discontinued r166?
- Gs clear Fog light
- LED Turn Signals/DRL's - GX 470 (2008)
- Just so I got this straight
- Climate control light - lextech question
- Another question about HID bowls into a non HID GS300
- Bi-xenon
- GS400 Yellow Output....
- Ls430 List Of Replacement Leds
- change the color of the red speedo and tach needles
- How do you get at
- License plate bulb question.
- Changing The Hazard Swithc Bulb
- Matching low beam/hid fog lights
- Daylight running and driving lights
- V-leds Hid White 3w Cree Drl 9005
- --Headlight Retro--
- Anyone have a pix of MobileHID 6000k?
- Best method to clean my healight lenses
- Question about HID cutoff line
- Headlight Bulbs
- Do you know this HID kit brand?
- Jrt?
- fogs - H3 vs 9006
- Hyper White = Yellow?
- Just wandering
- Clear marker in headlight cluster
- HID's Don't always come on
- Gonna be installing Demon Eye kit from AAC
- Yellow Led for DRL
- how did he get the dash lights in red/blue
- eAutoWorks.com delivery time
- Both fog lights are out, but they still work?
- Important Question
- 3000k hid fog lights aghhhh.
- Can you fix the display lights yourself?
- head lights high beam and halogen
- Questions on going to HIDs in a non HID 99 GS
- Dash Lighting PLEASE HELP
- HID bowl in non HID GS housing
- headlights and fogs
- HID question
- Replacement cluter bulbs locally?
- Open Casting Call!
- Need the right size led dome light..
- 2nd gen ES300 front door lights
- Which headlights are in my car??
- GS430 Interior light upgrade
- TSX retrofit light pattern photos..
- Are high power LEDs worth the $?
- LED highbeam/DRL
- aligning retrofit.
- How To: Replace Xenon Bulb- 3GS (applies to most Lexus with factory HID)
- Ebay Xenon Kit
- what color temperatura should I use with LS430 projectors on GS 03
- Need Help Fast Those Who Have Done Retrofit
- One bulb brighter than other?
- Headlight focus
- HI everyone!! this is my baby with full blue 9-leds interior
- demon eye kit for 01-03 ls 430?
- 01-03 ls 430 retrofit with 04-06 ls 430 projectors?
- anyone here in toronto that does headlight retrofits?
- Light Bulb Question
- Flank leds for license plate anyone?
- pictures of complete interior LED on 99 gs300
- fx35 retrofit into 97 Lexus ES300 headlight project...
- Dull Q45
- Tinted/smoked tailights
- new headlights opinion
- Black inteiror guys: what color are your interior lights?
- '01 es300 fogs on '98?
- how to tell difference
- Dash/center consul lights HELP!
- Hid's
- Anyone ever used RX330 projectors for GS3 retro?
- 99 gs300 retro tsx projector or xenondepot housing with phillips hid kit?
- Halo projector headlights w/HID kit from ebay?? Anyone know this brand?
- 99 gs300 lighting upgrade questions
- HID light bulbs at Lextasy?
- 08 IS250 visor bulbs...
- TSX into an SC300 *Lots of pictures*
- Good source / proce for 97+ sc fogs?
- Taillights w/ cracked lens
- ls460 fog light bulbs.
- Best place to get h3 HID yellow fogs?
- Interior light problems
- 6000k installation
- Fogs?!
- HID Conversion Advice.
- Need Help : How do you change driver's side headlight bulb IS250
- Mounting HID's
- Yellow Fogs?
- HID lights, where to buy?
- Polishing glass headlights (low beam) Lexus SС 300.
- Lightintg question!!!!
