PDA
View Full Version : Lighting
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22
  1. PIAA extreme whites
  2. Would a 98 GS HID's fit a 93 SC300?
  3. HID GS headlights '00 vs '04
  4. HID advice
  5. Headlight leveling for ES300
  6. Headlight Condensation
  7. Drivers Side Turn Signal
  8. Drivers Side Turn Signal
  9. DIY HID conversion for LS43 foglights
  10. H3 bulb in a H3C housing
  11. How many of you guys have built a relay harness for HID?
  12. daytime running lights on a 98 gs400
  13. need to know about fog light Lensce
  14. Retrofit FULL HID conversion and LED fogs coming in 2 weeks!
  15. Daytime runnig lights
  16. Need help w/ HID/Xenon conversion & yellow fogs
  17. gs headlight question
  18. adjusting level of your headlights beam
  19. lights level
  20. Ground Switching
  21. Swapping Interior bulbs....How do I remove protective covers?
  22. ? Foglight swap
  23. 9004 or H4??
  24. PIAA for Driving/High Beams
  25. Driving Light
  26. Lexus GS Auto Leveling
  27. Illsion-Lighting
  28. Anyone lookin for q45 headlight mod??
  29. Hi beam wedge bulbs...
  30. My SC300 projects a V-pattern :(
  31. Brighter brake lights?
  32. question about bulb size
  33. HIDs from 2004 GS430 into 2000 GS3 non-hid
  34. When to Change HID Blulbs
  35. SC300 DRLs
  36. Fogs Lights for Dummies
  37. 98 GS Lower Rear Brake Bulb??
  38. projector retrofit
  39. Lighting ?
  40. changing side marker and fog light
  41. 10,000K upgrade...
  42. side marker question
  43. FOG LIGHTS>>Continued
  44. 2000 ES300 HID Q's
  45. FOG LIGHTS no like yellow!
  46. Will RX330 projectors fit in a 92 SC300 housing?
  47. can i convert my '94 LS400 to HID Xenons?
  48. Audi/BMW/Mercedes Bi-Xenon Retrofit into non-HID '98 GS? Help me out here
  49. projectors for GS?
  50. Do HID's degrade?
  51. Hid's
  52. k2 bulb
  53. Passing inspection with aftermarket HID's?
  54. part # for hid harness plug?
  55. HIDs for a no HID GS3 which way to go?
  56. 111,000 miles and haven't blown a light bulb- Is something wrong with my Lexus?
  57. HLC IS300 HID headlight Leveling Computer Controller advice?
  58. 4100K vs 6000K (PICS PLEASE)
  59. ECE worth the upgrade from E39 projectors
  60. ANyone know how to hook up a new switch for fog lights?
  61. Where to buy 4100k?
  62. Are PIAA bulbs worth it?
  63. HID ? (did search)
  64. D-speed clear corners problems
  65. Headlamps on my '95 ES300
  66. D2R HID Ebay-Anyone have any experience with these
  67. retro-fit???????????
  68. Converting cornering lights into fog lights?
  69. '96 ES300 HID's
  70. Position Of Low Beams
  71. Replace headlight bulbs
  72. Cleared turn signal
  73. Head Lights
  74. Fog/Driving LIght Bulb Replacement
  75. Headlights
  76. Hoen bulbs
  77. Closest 9006 bulb to HID color
  78. Which HID should I get???
  79. Wiring 3rd brake light
  80. tail light doesn't work, brake light does??
  81. Fog/Driving Light Bulb Replacement
  82. Worth adding an HID kit? Or just make sure my next car comes with HID?
  83. Who to buy from: Xenonfactory.com vs. jus4bulbs@yahoo.com
  84. Polarg vs. PIAA LED
  85. Replacing corner parking bulbs with LED's???
  86. HID install???
  87. *please Help*...
  88. want HID's for non-HID GS
  89. Nice Retrofit!!!
  90. JDM Clear Fog Lights, What bulb to use??
  91. HID's is it worth the money? check it out
  92. Clear Tails and Bumpers
  93. How To Remove GS Inner Taillights?
  94. HID Gurus only....
  95. What is happening ?
  96. need advice on HID catz ,have u had them?
  97. 1st gen. low beam bulbs STUCK.
  98. 1st gen. ES300 low beams.
  99. Hid Kit (one bulb not working)
  100. Adjusting light output height on SC400
  101. keyless entry rewire
  102. How do i rewire the fogs for 93' SC
  103. Quick Question (Fog Lights)
  104. Daytime Running Lights
  105. ballast
  106. Another headlight question.
  107. headlight alignment
  108. HIDs
  109. HID kits
  110. Sylvania lights
  111. headlight problem....
  112. Question 95-96 tailights wiring?
  113. What peint for tails...
  114. Help With Some lIghting Please!!
  115. HID problem
  116. Please don't retrofit HID like this
  117. pixs of a philps6000k kit on a 97SC
  118. headlight leveling
  119. 93 yellow fog light color replacement
  120. Replace tail light bulb on RX 300
  121. Silverstars: Excellent!
  122. HID Kit LX 470
  123. LED Headlights
  124. HID instalation
  125. hella HID
  126. Fog lights 55w = ***w of output?
  127. HID Kit H4
  128. H3 fog lights that match HID's for the SC
  129. Help putting clear bumper lights in an IS
  130. Weird bixenons
  131. 96 ES300 clean out headlight domes
  132. 1995 LS400 lighting info?
  133. PIAA or Sylvania?
  134. Sylvania Life Expectancy?!?!?
  135. Strange problem with Sylvania Silverstars
  136. HID Retrofit Question for 1997 SC400
  137. What blubs to replace factory HID on 98 GS400?
  138. Lighting HID Projector Chart
  139. GX with Demon Eyes
  140. rx300 stock HID system
  141. DRL questions
  142. HID's sales
  143. can you use oem d2s bulb instead of oem d2r bulbs?
  144. Interior bulbs
  145. Excellent
  146. For those with STOCK HID cars......got a question
  147. is there a difference lexus / phillips balast?
  148. Piaa Super Plasma Gt-x (h-278)
  149. d2r and d2s which one do i need?
  150. HID bulb replacement
  151. Retrofit headlight alignment WITHOUT mounting
  152. Fog Lights
  153. HIDs installatoin in my RX300!
  154. 2 Questions
  155. Lx-470 bulbs pattern?????????
  156. HID Ban, I'm confused...
  157. Piaa bulb problem on '98 es300
  158. Aftermarket HID Cutoff on SC
  159. rx 330 foglights suck
  160. Whats best for first gen es3?
  161. HID for a 95 ES300
  162. RX300 OEM HID Aim/Adjustment
  163. one side dimmer
  164. Brightest non-HID bulbs available
  165. Taking aprat headlamp for es300?
  166. Got me some HID's!
  167. GS's come with Sylvania's?
  168. Best place to buy HID kits
  169. retrofit on a SC400
  170. Ignition lighting upgrade
  171. what year is this from?
  172. Turnsignal Mirror
  173. H11 Bulbs
  174. Aftermarket HID problem concerning replacement ballasts
  175. Clear foglights
  176. Replacement DRL Bulbs
  177. Upgrading lows and fogs?
  178. Brighter Reverse lights?
  179. Gen 2 GS series black housing
  180. what bulbs do my ls400 take?
  181. Question for members w/ Aftermarket HIDs
  182. Installing Silverstar headlights
  183. HID and Yellow Fogs for 98 ES300?
  184. HID changing colors?
  185. Wiring HIDs
  186. More 9006J bulb woes
  187. Does anyone made a custom headlight for the 92-96 ES300/Windom?
  188. Sylvania Silverstars
  189. HID Lights Banned? Vote to Save
  190. BEHOLD...a Damn Good Retrofit!!!
  191. HID's illegal?
  192. SilverStar Signal Lighting (European Diadem comparible)
  193. Headlight Assemby
  194. H11 Hid Kit
  195. LX 470 HID Kits
  196. Website with Silverstars: $26 (AR)
  197. How Can I Get My New Foglamps to Work...
  198. ES300 yellow fogs not bright as it should be
  199. Tail light bulb
  200. Razo premium Super White vs. Sylvania Silverstars
  201. Question about headlights
  202. HID's on the RX300
  203. 6000K From MisterJung
  204. Close to deciding on HID
  205. Left signal lights don't work
  206. Hook ups with HIDs??
  207. Junction Produce Bulbs
  208. Auto Couture illumination Entry Door Kit
  209. How do i know if i have HID's?
  210. 8000k Ds2 head lights installed WOW
  211. Sorry for the double post but I've read the FAQ's and did a search. Can u help?
  212. Footwell lights on a GS400??
  213. stock HID color?
  214. Harness upgrade?
  215. SC 300-400 HID Conversion
  216. Switching Factory Hid to Nissan Factory Hid
  217. 6000K 9006 Xenon HID Conversion Kit BlueWhite - Is that good ?
  218. Phillips Ultinon 6000K
  219. RX300 interior green to white LED conversion
  220. RED LED for inner Tail Lights (help)
  221. 6000k
  222. Help! Why don't the Silverstars fit??
  223. clear side markers at horsepowerfreaks.com
  224. 6000k or 8000k
  225. what size are the parking light bulbs?
  226. 6000k hid fogs
  227. 00 and up taillights
  228. People With HID Foglights
  229. highbeam adjustment for SC 400
  230. Silver Signal bulb?
  231. Help finding HID bulb with this style plug.
  232. factory spoiler LEDs went out again!
  233. Help Hid Guys
  234. Can a 9004 based headlight be converted to HID?
  235. need help
  236. Hids and projectors?
  237. Matching Fog Lights with Factory HID's
  238. who makes the brightest 1157 bulb style amber LEDs? where can I get them? Thanks!
  239. Bulb Number of 2000 ES300
  240. Fog Light Problem
  241. Can someone help me with this
  242. Fog Lights
  243. what are the best bulbs to get for hid look
  244. HID Lighting on GX470
  245. High-Wattaged Ballast
  246. Where to get light bulbs?
  247. Has anyone tried H9's in their GX470
  248. HID for Fog Light(s)
  249. hid for fog lights
  250. DRL - on a 97?
