Sponsored by: CARiD
HID had a problem today, what was wrong with it?
Old Dec 13, 2006 | 06:50 PM
kgh31386's Avatar
kgh31386
Default HID had a problem today, what was wrong with it?
Today when I got out of the car, my right side bulb was a different color. It looked like a halogen bulb. But I turned them off and turned them back on a few minutes later and it was fine. and it was fine driving home, what could that be? It's a philips 6000k kit
Old Dec 13, 2006 | 08:33 PM
rominl's Avatar
rominl
exclusive matchup
monitor it and see if it happens again. maybe a bulb is going out
Old Dec 13, 2006 | 08:42 PM
lexusls430's Avatar
lexusls430
^^Might be the bulb like he said. But if it was going bad it would turn pinkish. Just be on the look out for a few days.
Old Dec 13, 2006 | 09:09 PM
cliffud's Avatar
cliffud
Former Vendor
if you bought them from xenondepot, i think they offer a 1 year warranty. good luck.
Old Dec 13, 2006 | 09:21 PM
kgh31386's Avatar
kgh31386
nope got 'em from kwimports
Old Dec 13, 2006 | 09:48 PM
cliffud's Avatar
cliffud
Former Vendor
well, if you replace the bulb, spend the extra cash and replace both - otherwise one will be a diff temp or have a diff warm up period than the other - it may drive you bonkers.
i know it would me.
Old Dec 13, 2006 | 11:15 PM
kgh31386's Avatar
kgh31386
yea if i do replace them i'll do both. it did it again tonight out of the 3 times i used it
Old Dec 14, 2006 | 02:09 PM
LXotic's Avatar
LXotic
then it means it's time to replace,replace,replace!!
Old Dec 14, 2006 | 11:22 PM
kgh31386's Avatar
kgh31386
i think i might have found the problem. i switched the bulbs and the same side was acting up. so it has to be the ballast. i took it out and found some water sitting on it. i blew it out with air and what not for a while and it was fixed most of today. but acted up again one time tonight. i might have to get another philips ballast
Old Dec 15, 2006 | 06:51 AM
cliffud's Avatar
cliffud
Former Vendor
was the water stuck in the plastic housing? if so, sounds like a problematic issue since it affected someone else here earlier this month.
if i were still running my xenondepot kit, i would take my plastic casings off my philips ballasts. i think by doing this, if water were to ever splash onto it, the water would just run off instead of getting trapped in the housing and sitting stagnant.
Old Dec 15, 2006 | 09:54 AM
kgh31386's Avatar
kgh31386
how do i take the plastic covering off?
Old Dec 15, 2006 | 09:59 AM
cliffud's Avatar
cliffud
Former Vendor
there are tabs on the sides that you need to use a flat head screwdriver to bend and release the plastic casing.
I'll try to take photos tonight of my plastic housing. I took out my philips kit a long time ago but just recently removed the housing to compare the ballast inside.
Old Dec 15, 2006 | 11:05 AM
kgh31386's Avatar
kgh31386
k i got them off, im gonna blow some air all over it today and hope it works. if not, can i buy one of your philips ballasts you have laying around if you do have any laying around?
apdimitri
May 12, 2012 02:11 AM
TXES350
Mar 12, 2011 07:46 PM
jewel
Jul 29, 2009 09:10 AM
kschawaii
Lighting
14
Jan 28, 2009 11:27 PM
ISCjonny
Dec 22, 2007 05:32 AM
