PDA
View Full Version : Lighting
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. Question FOGS
  2. LuxuryMods.com First Ever FX-R Retrofit into a 2GS
  3. Headlight help
  4. Side mirror auto tint problem
  5. HIDs HELP!
  6. 55watt Heat Question -HID experts chime in please
  7. how to make puddle lights stay on longer
  8. D4S 5000k or 5500k HID bulbs
  9. BMW 2008 7 series retrofit to SCX00?
  10. Trying to retro fit lens
  11. LS430 vs Ls460 Retrofit for 2GS
  12. Opinion!
  13. HID Problems
  14. LED exterior & interior bulbs - do they last life of car?
  15. anyone put led in the back up lights? isx50
  16. 1999 gs400
  17. 74/T5 LED mini wedge bulbs
  18. whole left side rear lights aren't working. how do you take off the assembly?
  19. led in city lights?
  20. Where can I buy old school red bulbs for my clear inners?
  21. anyone used DDM TUNING for HID
  22. head light comes on..then goes off!
  23. 1 of my puddle lights went out..time for som led's what ones to get?
  24. 9005 vs. 9006
  25. License Plate Light SC 1st gen help!
  26. hid question
  27. Perfect Color Match with 3000K FogLight
  28. 04 ES330 headlight bulb size?
  29. 2nd Gen GS HID
  30. Xenon light ballast
  31. 07 is350 fog-high-low beams on all at the same time!
  32. HID problem?
  33. D4S to D2S
  34. Epoxy for retro
  35. Advice on what to do with these X5 headlights
  36. 1999 gs300 foglights
  37. led 9005 or 9006 on is350
  38. Matching halogen bulbs / LEDs to 8000k HID headlights
  39. Use the Member Marketplace Classifieds for FS and WTB Posts Please
  40. Where can I get yellow LED bulbs?
  41. Hid recommendations!
  42. problem with LED for DRL
  43. I want 3gs lights in my 2g
  44. Interior LED's Are Not Bright
  45. XenonDepot bulbs not that great
  46. 92 es 300 projectors
  47. Length of 04-06 LS430 Projector?
  48. IS 250 Courtesy Lights Replacement
  49. H.I.D troubles really confused
  50. Problem with gear shift lighting GS430
  51. LED Auxiliary Bulbs
  52. BA9S LED flank for map light?
  53. need advice! SO i guess i got a second chance. pics
  54. need help with HID
  55. ...help on 2nd gs 3rd break light
  56. Help with Lexus SC300 License Plate Lights
  57. ???Can 04-06_LS430_tail-lights_fit-01-03???
  58. Need help with Xenon Depot item.
  59. Hid drl
  60. xenondepot review with pics
  61. Is 250 foglight problem
  62. looking for a light combo for my sc4
  63. Auto Leveling
  64. LS GS IS HID Top and Bottom 8k 6k 3k
  65. yellow fogs: HID vs. Halogen
  66. DRL's stay on
  67. IS250 Lighting Problem
  68. Rear Turn Signal Color
  69. 3k, 6k or 8k HID Fogs?
  70. Brake lights on GS300
  71. anyone ever ordered from Auto-Electronic Supply?
  72. Another Q45 retrofit into 2GS w/ New Projector Brackets!
  73. 2006 GS 430 Front Headlamp Replacement (Dealer Holdup?)
  74. HELP: OEM HID for IS250 Flicker....
  75. Wedge Bulbs?
  76. Beware of off brands
  77. Where Can I Buy 6" or 160mm Pure White Cold Cathode Tubes
  78. How to connect Denso Ballast to battery on non-HID 2GS headlight ??
  79. IS250 conversion to Bi-Xenon
  80. 05-06 ES 330 Projector Lenses
  81. how to make bi-xenon feature work on a 2gs?
  82. I need help
  83. Load resistors. which ones?
  84. Does anyone know?
  85. RX330 Brake light
  86. HELP: Changing the Wedge on the 3GS
  87. 2 GS issue - headlight levelling no longer working. How to fix this?
  88. Reverse Lights Come On When Braking
  89. HID Headlight flickering
  90. Putting OEM GS HIDs into a OEM non-HID GS
  91. best hid/retrofit for SC300/400
  92. SuperbrightLEDs.com
  93. High Powered LED's
  94. HID Retrofit for RX350
  95. 08 IS250 projector lens swap?
  96. How to replace reverse light in RX 330?
  97. whats up need help trying to wire my fogs!
  98. whats up need help trying wire my fogs!
  99. Change 1157 bulbs to H3 set up for fogs
  100. Help!!!! Water in HID head light
  101. Halogen headlight cuts off while driving but works when turned off and on
  102. left fog light out on my 95 sc3 - need help troubleshooting
  103. 1998-2005 GS fog light disassembly
  104. Climate control bulb part # (gs300)
  105. HID Lights Problem
  106. Rebased d2r bulbs to 9006?
  107. HID, Fog light result! take a look guys
  108. Clear side marker lights
  109. 2Gs Stock HID bulb replacement
  110. Console light goes away in cold or when i turn the headlights.
  111. 6000K vs. 8000K HID
  112. SC300 no dash lights?
  113. Speedometer not working any idea??
  114. Puddle Lights
  115. will h11 bulbs work with '07 2is w/ oem hid
  116. Steve @ XenonDepot
  117. Xenon Depot.....A++ on Customer Service
  118. High beam headlight problem
  119. GX Halo Headlights
  120. Daytime Running Lights Install
  121. 194 CCFL bulbs
  122. I do not recommend using 272-1092 bulbs from radio shack for replacing climate bulbs
  123. What else do I need to install HID kit on non-HID headlight ?
  124. FUSE keeps going out
  125. Question about d4s bulb failing
  126. Newb LED question
  127. 2006 Lexus GS DRL
  128. cheapest HID online?
  129. 95 es300 output difference
  130. changing light behind radio console?
  131. HID relay
  132. Closed out
  133. Anyone install an HID kit on a GX yet?
  134. HID/fog upgrade on 09 ISX50?
  135. SC400 Headlight bulb size + Q's
  136. HID's flickering....after a month??
  137. 92 SC300 Cornering lights to Fog lights
  138. D4s to d2s swap including ballasts - possible?
  139. 2GS help!
  140. IS350 check VSC light on
  141. 92 SC400 opening headlights opinions please
  142. Stock HID projector mods on ISx50?
  143. HID fogs blowing fuse using stock wires
  144. reverse light change to LED help IS250awd
  145. Odd gauge needle problem
  146. Replacement HID bulbs?
  147. IS350 halogen to hid question
  148. How to change headlight for GS 350???
  149. Philips 42402
  150. DRL Pics PIAA Intense White?
  151. LED/HID Upgraded with IS350 and GS430
  152. LED Update (V-LEDs)
  153. 1999 ES300 Backup Light
  154. HID lighting for LX-570
  155. mobile hid
  156. dash lighting
  157. ES LED Conversion
  158. IS 250 HID for High Beam?
  159. LED help
  160. Hid kit for fog light
  161. lexus gs hid bowls for retrofit ?
  162. HID Glare on ES300
  163. Which Headlights?
  164. HID Help!!!
  165. Are these really philips kits ???
  166. help
  167. HELP needed ASAP! HID fog install trouble.
  168. Anyone done trailer wiring on their sc or other lexus car.
  169. Lexus should make better...
  170. Xtreme vs. volt hid kit???
  171. Color of 3000K HIDs?
  172. How to install a relay - HIDEXTRA.com
  173. 97 SC400 Tail light bulbs
  174. turn signal bulb number???
  175. LED Foglights
  176. D2S, D4S, D2R, are they all the same???
  177. where to buy repalcement parts for my hid kit??
  178. Retrofit LED Turn Signals
  179. Help with sc300 foglight clean (opinions needed)
  180. 05 lx470 hid
  181. HELP! HID BULB fitment issue
  182. noob type question part two
  183. Upgrading lights for "Project Cheapskate"
  184. help hid bulb blew in headlight
  185. MTEC HID install - 2010 RX350
  186. found these sc300 headlights on cincity.com
  187. Headlight fuse blows when lights are in auto mode.
  188. cluster lights
  189. LS 430 tail light lens
  190. Bad ballast?
  191. Gas Needle
  192. Fog Light Fuse?
  193. Help Broken HID bulb (Fog)
  194. Brightest light w/ stock headlights?
  195. LS430 retrofit on OEM HID equipped GS?
  196. A quick question about HID bulbs
  197. Will new HID bulbs help improve brightness?
  198. HID kit , whats good out there?
  199. How do you wire LED turn signal bulbs so they dont hyper blink?
  200. City Light DRL's Not Functioning After LED Swap?
  201. HIDEXTRA.com HID Review
  202. Violet color HIDs on LS430 for Show??
  203. High Beam projector retrofit Q's?
  204. Lighting Wiring Advice Needed!!!
  205. SC300/SC400 LED lighting (Interior)
  206. Fog Light help
  207. help on my DRL 99 sc300
  208. What color HIDs should I get?
  209. Stuck on what to get ..
  210. New Interior LED's by Xenon Depot for the 2IS dome lights!!
  211. 2is back headlight cover question
  212. HID bulb failure
  213. Dome LED replacement fade blink question.
  214. Help Please. Which one should I get?
  215. ne1 know...what is a european H11 bulb?
  216. does lexus make hid/afs for all their cars?
  217. Where to buy Garax HID Bulbs?
  218. LED Yellow Fogs
  219. 4300k SC300 PNP vs. TSX with Philips 85122
  220. Relay Diagram?
  221. Using Volt Kit with or without Relays?
  222. $1,500 a piece for headlight assemblys???
  223. Just Another LS430 retrofit into 2GS
  224. MTEC Bulbs?
  225. Converting cornering lights to Daytime running lights problem...help
  226. I'm baffled and I ca't figure it out
  227. one of my hid blew out.
  228. what is the lightbulb size for shifter 98 gs4
  229. H3 Bulbs Compare to 9006 bulbs (HID)
  230. Garax bulbs or....
  231. Need help: Replacing a lowbeam headlight bulb on a '96 ES300
  232. GS 400 Dash light "icon" lit up?
  233. Is it normal.......?
  234. Guess what i got for $129 =]
  235. LED Brake Light Replacment
  236. hid headlights kits (w/pictures)
  237. 96 es300 Coach edition headlight Kit
  238. Need help broke HID bulb base
  239. HID's on Stock Cars w/o Housings
  240. 99 GS HIDs dim compared to newer cars HALOGENS
  241. Help with installing resistors
  242. Wanna convert to HID
  243. Help! One of my low beams (hid)went out on my F
  244. GS Projector Headlights
  245. What does Caddy DTS use for its back-up lights?
  246. What is the lumen output of Polarg M4's?
  247. Aftermarket HID issues - advice needed
  248. 2GS Puddle Light Install - DIY - Helpful tips.
  249. Puddle lights...help!!!!!
  250. 2GS leveling motors, left and right interchangeable???
