Sponsored by: CARiD
Life expectancy of LEDs?
Old Nov 10, 2006 | 08:37 PM
CO-LS400's Avatar
CO-LS400
Default Life expectancy of LEDs?
I put LEDS on my bumper lights.. (2000 LS 400 Clear corners)
They BOTH are now dead.. its only been 4 months
Is this normal.. I thought LEDS lasted a long time.????
Old Nov 10, 2006 | 09:57 PM
EXE.UCF10's Avatar
EXE.UCF10
VIP|EXEstyle セルシオ
Generally, they do last a long time...longer than your regular bulbs. But for that to happen it all comes down to the quality of the LEDs and how/where they've been assembled. From my experience, I've noticed certain types of LED bulbs burn out a lot faster than others and some last for years and years.
For example, this oval wide angle lens LED has lasted me for years:
http://superlumination.com/images/au..._oval_w_wm.jpg
Whereas, this 5-LED matrix bulb lasts about a couple of months before the smaller side LEDs start burning out:
http://superlumination.com/images/au...atrix_w_wm.jpg
tcheung87's Avatar
tcheung87
What brand LEDs did you buy? Try a reputable brand if you've been buying off eBay because I've been using PIAA LED for over 2 years and they are bright as the day I installed them. Good luck.
Old Nov 11, 2006 | 07:32 AM
CO-LS400's Avatar
CO-LS400
I don't know what brand they are ?? I got them from
http://autolumination.com/906.htm
Old Nov 11, 2006 | 07:34 AM
CO-LS400's Avatar
CO-LS400
I installed them at the same exact time.. and it seems like they both went out at the same exact time.. Maybe its the fuse??
I'll figure it out today
Old Nov 11, 2006 | 08:18 AM
Lexucan's Avatar
Lexucan
Lexucanafer
The likelihood that both LEDs would burn out at exactly the same time is very slim. I'd bet on it being a fuse problem.
Old Nov 11, 2006 | 10:31 AM
CO-LS400's Avatar
CO-LS400
Just checked the fuses.
LEDS ARE DEAD
Not a fuse problem. They only lasted 4 months.. Will try another type of LED
Old Nov 11, 2006 | 07:06 PM
tcheung87's Avatar
tcheung87
LEDS ARE DEAD
Yeah, there goes my second guess since the fuses are fine. If you need size 168/194 then I'd go with PIAA definitely.
Old Nov 24, 2006 | 05:11 PM
Jasbmo's Avatar
Jasbmo
how do the oval wide angle lens compare to stock halogen in regards to angle and lighting?
thanks,
jasbmo
RU514
Jun 19, 2015 05:36 PM
MEP7557
RX - 3rd Gen (2010-2015)
29
Dec 12, 2014 01:19 PM
ahmed24
Sep 1, 2010 02:43 PM
SilverAWD
Oct 1, 2006 03:00 PM
FunGuy
Lighting
Sep 27, 2005 05:57 PM
