Sponsored by: CARiD
Relay and Wiring Harness Question
Old Nov 30, 2006 | 05:48 PM
IronCobra's Avatar
IronCobra
Default Relay and Wiring Harness Question
Hey guys, as most of you know I recently installed my HID Conversion kit in my Jaguar X-type. I am 100% satisfied with the kit but I do have some technical questions.
The kit I installed in my SC300 came with a wiring kit and relay. Unfortunatily my X-type's kit did not.
I made my own wiring hardness and I just wanted to make sure I used the correct wiring specs and fuses.
Here is what I currently have created.
Parts:
-2 Bosch SPST Relays
-2 15amp 14AWG Inline Blade Fuse holders
-12AWG 14" Power Cable splits into 2 14AWG wires to Fuses (Relay PIN 30)
-12AWG 5' Cable going into passanger Xenon Ballast (Relay PIN 87)
-12AWG 2' Cable going into Drive Xenon Ballast (Relay PIN 87)
-12AWG 5' Cable going to factory Passanger headlight Wiring as Switched Input (Relay PIN 85)
-12AWG 2' Cable going to factory Driver headlight Wiring as Switched Input (Relay PIN 85)
Now my question. Is a SINGLE 12AWG Power cable enough to power the Entire kit without possible failure from overload?
Old Nov 30, 2006 | 06:09 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
it should be, id run a 10AWG just to be safe though. could also throw in another fuse/CB if u felt like it.
Old Nov 30, 2006 | 06:25 PM
IronCobra's Avatar
IronCobra
another fuse? I already have 2 15amp fuses (1 per relay)
Old Nov 30, 2006 | 06:51 PM
PureDrifter
BahHumBug
CL Folding 100,000
oops, missed that i did
carry on in that case
Flea7
CT 200h Model (2011-2017)
Nov 16, 2014 08:44 PM
Sup2jzgte
Lighting
May 4, 2009 06:29 PM
HoustonIS
Sep 30, 2008 04:53 AM
inwood
Nov 27, 2007 06:39 AM
techsc400
Lighting
Oct 16, 2005 06:55 PM
