- Rewiring of fog lights
- headlight aim question again.
- d.i.y for tail light bulb replacement?
- RX330 Lighting
- what HID projector is best for GS?
- 90 LS fuse blows when lights turned on?
- Hid
- headlights
- signal bulbs
- fog HID conversion woes
- Fixing Foggy Headlights
- do fogs stay on even after key is out on GS 98+?
- SC300 Nokya "Arctic White"
- Yellow Wedge Bulbs(PIAA) to match fogs......
- LED bulbs flash more frequent
- Removing Passenger Side Tail on 1st Gen
- Which Silverstar??
- PIAA corners: poor quality
- **check out this awesome lighting diy***
- 7443 to 7440?
- :thumbup: ***Check this*** :thumbup: Wicked cool
- Q: HID Housing swap to NON-HID GS
- couple HID questions...
- my fog light mod (thanks too BananaGS)
- interior door dome light led pics.
- Cold Cathode Climate Control
- which Bulb to choose for doom light??i want SOFT yellow color
- HID Bulb Color Bananza!!! Sticky This Please!!!!
- clear orange turn light?
- Removing fog lights
- Trunk Light for SC400
- HID question - SORRY!!
- anyone has the LED bulb model # for the doom light ? where when you use remote to tur
- brightest h3 bulb ....
- Has anyone rewired their DRL to light up the turn signal bulb like the GX470?
- Do Canadain-spec Lexus use full-brightness high beam as Daytime Running Lights?
- small feet area bulbs?
- es300 wire harness melt 100 watt bulbs low beam?
- Need help with Pos-Neg?
- Foglight bulb removal
- Can HID ballasts be repaired?
- GS housing replacement
- Yellow HID Foglights
- Help
- HID question
- replacing low beam bulbs...
- Which map and dome lights for SC?
- After-market HID problem
- lefty loosey, righty tighty.... learning the hard way
- How to replace stock fog lightson IS300 ??
- Fog light adjustments (For GS)
- Taillight burnt but not.... help?!?!?!
- QUESTION: oem HID on non HID housing
- Intellexual HID FAQ
- Bare HID housings for GS. Where to buy 6000K philips bulbs/ballasts??
- My New HID's
- Replacing standard headlight bulbs with HID
- Center Light M4 replacement
- 6000k HID Installation Video Back Online
- How do I replace 98 GS300 fog light?
- Power window switch lights
- searched: is there anything yellower then the piaa ions?
- a little help!
- Piaa Wedge Bulbs: LED or Miniature??
- HID in fog lamps, blowing fuse
- IS300 Bulbs
- 2 light indicator help
- Help Please!
- In case you missed it, 3rd LED option.
- Center Lights
- Help Removing Headlight on SC400
- Turn Signal Bulb Number?
- converting the 92-94 sc's cornering light 1157's to 97+ foglight H3's
- HID reflector pic required
- whats a good bulb
- bulb fit
- Who has the best HID kit
- Anyone try SPP's 50W ballast?
- Are Hella halogen any good?
- Piaa replacement
- any experience with LED bulbs?
- hid from hidfactory.com?
- HID color combo Poll and analysis
- Where can i find a replacement hid bulb
- what its worth ???
- How would i go about geting this look?
- aiming headlights
- foglight harness?
- Retrofitting vs plug n play HIDs
- Retrofit tools
- Retrofit Tools
- Is your headlight bright when its raining.
- Fog light question....help please
- HID question
- GS lighting help...
- anybody here ever get hid from global premier
- hid kit
- Where can I get new Headlights ?
- New Razos
- driver side light dim
- park lights
- HID Conversion in 94 ES400 Possible?
- I love this retrofit!!!!
- how do you know when you HID is going out?
- Housing Color?
- Please HELP!!!!! (Melted light recepticle)
- My '98 ES Stock HID Mod!!!!!!
- Slight Haze in headlamps
- I Just found out the hard way!!!
- want HID?
- retrofit problem: housing
- foglight went out
- Headlight Help ? (frustrated)
- H3 Foglight Bulb Recommendations SC300
- H-I-D help please
- H-I-D help please
- Clear bumper lights f/LS400 95-97
- Need Adjustment!
- Need help w/ hid install on gs. Plug does not match up.
- HID Retro Blues
- good place to get replacement HID bulbs?
- Break light
- HID aiming and leveling question
- GS430 Fogs
- LEDs
- ballast question ?
- How do I change the high mount stop bulbs?
- Fuse Relay
- Headlight Relay
- HIDs on SC?
- Jus Installed my HID
- Projector Expert!
- Those dimmed headlights!
- I'm sooo gonna do this.....
- Turn Signals.......Benz style
- GS Spoiler LEDs out?
- lighting
- Adapter rings
- help with PIAA PIAA!!!!!!!!!!
- rear pillar light bulb size
- license plate lights
- Need help with HID's
- Checkout this retro!!!
- I need HID's...wooohooo
- diy for hid headlight install?
- lighting FAQ -- READ THIS FIRST!
- Piaa extreme white plus ?
- Headlight reassembly: Add glue?
- SC300 headlight guts
- HID refit
- Fog Lights on sc400
- GS400 HID Lense Question
- Wiring of OEM Deck Spoiler on 99 GS3
- Light Bulbs Ls 400
- Driver's side HID out
- GS Clear Tail Light
- HID suggestions for 97 sc 300
- Recent Nissan HID law-suit has me worried
- Who has Philips 6000K Unitinon D2R's in stock?
- OEM HID Bulb
- GS430 OEM D2R to 6000K D2S~
- Fog lights for HID version - 2000 vs 2004
- Need HID bulb suggestions for 98 GS400
- headlight change
- if you take your IS or GS Yellow fog lights apart...
- Uh...is my headlight bulb close to being burnt out?
- Hid
- HID Ballasts
- headlights and tail lights
- Footwell light bulbs
- HID housings VS. NON HID housings??
- Hid's For A 97 Es300
- HID Lights?
- What HIDs are good for an SC retrofit?
- Rewired my fog lights ...
- corner lens condensation...
- Tail light mod and dash warning light
- rominl or HID gurus help! Lexus says my "Converters" are blown!
- '96 ES300 HID Retro Complete
- 6000k vs 8000k anybody w/pics/what is better
- Can you mix and match hid kit for gs hid headlights.
- question about full retrofit HID (projectors, etc)
- Any way to get fogs brighter without getting HIDs for theM?
- mood lights
- Buying Sylvania Silverstars for High Beams
- Replacing 98 GS wedge in hi-beam and rear parking light later today
- Daytime Running Lights
- Taiwan Philips 6000K kit
- For 2nd gen. GS - How to disable DRL when only Parking lights are ON?
- wtb 9006 hid bulbs
- Changing HID bulb on 02 SC430
- Questions on HID kit install on 2000 GS 300
- About to purchase 9006 hid kit and got some questions....
- light problem
- Lexus / Toyota HIDS
- ES330 HID retrofit..possible?
- GS 2nd gen LED TAILIGHTS ???
- PIAA extreme whites
- Would a 98 GS HID's fit a 93 SC300?
- HID GS headlights '00 vs '04
- HID advice
- Headlight leveling for ES300
- Headlight Condensation
- Drivers Side Turn Signal
- DIY HID conversion for LS43 foglights
- H3 bulb in a H3C housing
- How many of you guys have built a relay harness for HID?
- daytime running lights on a 98 gs400
- need to know about fog light Lensce
- Retrofit FULL HID conversion and LED fogs coming in 2 weeks!
- Daytime runnig lights
- Need help w/ HID/Xenon conversion & yellow fogs
- gs headlight question
- adjusting level of your headlights beam
- lights level
- Ground Switching
- Swapping Interior bulbs....How do I remove protective covers?
- ? Foglight swap
- 9004 or H4??
- PIAA for Driving/High Beams
- Driving Light
- Lexus GS Auto Leveling
- Illsion-Lighting
- Anyone lookin for q45 headlight mod??
- Hi beam wedge bulbs...
- My SC300 projects a V-pattern :(
- Brighter brake lights?
- question about bulb size
- HIDs from 2004 GS430 into 2000 GS3 non-hid
- When to Change HID Blulbs
- SC300 DRLs
- Fogs Lights for Dummies
- 98 GS Lower Rear Brake Bulb??
- projector retrofit
- Lighting ?
- changing side marker and fog light
- 10,000K upgrade...
- side marker question
- FOG LIGHTS>>Continued
- 2000 ES300 HID Q's
- FOG LIGHTS no like yellow!
- Will RX330 projectors fit in a 92 SC300 housing?
- can i convert my '94 LS400 to HID Xenons?
- Audi/BMW/Mercedes Bi-Xenon Retrofit into non-HID '98 GS? Help me out here
- projectors for GS?
- Do HID's degrade?
- Hid's
- k2 bulb
- Passing inspection with aftermarket HID's?
