- 94 es300 headlights
- Help please!!! Has anyone open their headlight unit 02 ls430
- hid on high beam instead of low
- Lights wont shut off
- aftermarket hid longevity factors
- 2002 LS430 LED mirror cover upgrade
- D4S bulb to match HIDExtra 5000k kit?
- reviews for HID nation
- DDM Tuning disappointment
- Heeeeelp hids issue
- @@@ Help tail light issues @@@
- Low beam HID 8000k on GS 350
- Heads up!! Lighting sale!!
- CREE Q5 Backup Bulb
- HID headlights burning yellowish White
- LS/GS 460/430 etc.. Headlamp Retro-fitters beware..
- LED Puddle Lights
- Does AFS work for right turns?
- Ballast under warranty?
- HID install for 2000 LX470 help needed
- Burn smell from HID bulb
- Cut-off line
- LED Lighting - Courtesy of LuxuryMods.com
- Used IS350 with hid kit
- Headlight advice needed
- Best HID replacement bulb?
- Whats the Best HIDS kit?
- Putco Bulb
- hello question
- H7 Bulb powered by Car Battery
- installation help!! IS350 (Garax 6k/8k)
- WTB: Driver's side fog light housing
- HID conversion bulb goes out sometimes
- Enable DRL help !
- Gs350-gs460 06-08 drl
- Changing left side headlight connector
- How to replace lights for 1997 SC300
- Is250 fog light retrofit using mini h1
- Halo lights
- DDM HID question
- gauge cluster and key ring lighting
- what seem to be the problem..
- halo kits
- LED Recommendations
- Need help connecting Audi-esque LEDs
- headlight problem
- H11 bulb to 9006 socket
- Fog Lights
- gated shifter bulbs out 2nd gs300
- Phillips HID's
- 6500k/5000k Xtreme Digital HID pictures pls
- has anyone fitted 3rd gen hid's into 2nd gen housing?
- DRL not working with LEDs.
- need suggestion for brightest 921 bulb for back-ups
- bright white bulbs w/out blue film?
- Yellow HID Fog people..need vendor recommendation please
- headlight clear bra. Clear? Durable? xpel ?
- Ballast inside headlamp, is it ok?
- Need to find these fogs cant find anywhere help!
- 07 IS250 headlight issues
- Im back!!!!
- Headlamp adjustment 2001 ES 300
- Use responsibly
- are H3 bulbs better then D2R and 9006?
- Fog Lights Halogen
- "Super White" Halogens for 2nd Generation GS
- HID went from red to not working
- piaa super cobalt hid bulb 6600k
- HID kit with-out any drilling ??
- New Here (question about lighting)
- IS250 8K Low, 6K LED, 6K Fog
- Slim Ballast vs Non-slim
- retrofit
- Is350 6k low beam 6k hid fog
- need help install relay harness and DRL light module
- Advice on HID Fogs?
- Climate Control Lights
- HID Kit Wire Relay..is it needed?
- New LS460's Coming With 6K Bulbs???
- Gx 460
- How many splices can you make from one power source?
- 92-95 ES300 Clear Lenses
- Your advise please re. plastic fog light covers
- How Long Does It Take for chemical to react D4S 8K??
- Show off your cut-off line thread
- Illuminated Door Sill ES350
- Looking for some advice
- SC400 Demon Eyes?
- LED Resistors??
- 92 SC Sun Visor Bulb
- LED turn signals for an IS-F
- Window switch light
- anyone running a 50 or 55 watt ballast in ur isx50
- Help in ES-330 headlamp alignment
- cargym.com d4s ultinon's
- Philips 6000k ultinon d4s
- HID Bulbs - changing "from good to new"?
- Good WHITE 128/192 to match 5000k/5500k HIDs?
- I did it guys!(Bottom lighting strips)
- Which HiD temp?
- HID foglights
- ?? about hid bulbs
- LED light bar on GX470
- The pitfalls of Lifetime warranties - Buyer Beware
- Anybody used Mercedes projectors?
- Angel Eyes
- Unhappy with VLEDS!
- My LED & HID Conversion (Pics)
- Need help on HIDExtra kit
- Installing LED strips.
- Help with Wiring
- sc 400 99 tail lights on a 92 not working properly
- Interesting article about Auto LEDs
- To all you retro fit MASTERS!
- Problem with foglights/ turning signal. Ebay HID kit...
- fog light mod
- Audi Style LED DRL's
- Hids from ddm tuning problems?
- Blue Cluster LED's
- 05 Lexus ES330 Headlights
- SC400: 92 fog light on 95 car?
- Will H1's fit H4's?
- new headlamps and hid's for 93 sc300?
- isx50 fog light projectors...what projectors to use?
- Brigthes LIghtBUlB ??
- Looking for projectors
- gauge cluster
- help!!! new hid will not work
- Flickering HID lights vs. Solid HID kits
- Something Kinda Funky Going On....
- 1997 SC400 Will these tail lights fit and does anyone have them?
- 3m?
- Great deals on MTEC D4S/D4R bulbs
- Great deals on MTEC D2S/DR bulbs
- Toggle switch help
- Post subject: 2006 Lexus GS300 bi-xenon retro OEM IS350 swap
- Need a dealer who will turn of DRLs
- 2010 GX 460 Wiring Diagram
- Great Deal on Garax
- rear tail light not working, and I know bulbs are good
- 2010 ES350 HID question/option !!!
- 01-05 GS Series LED mirror covers
- Help me with my taillights please. Name your price!
- Anyone know who has the deepest golden yellow 3000k hid bulbs?
- upgrading lights
- new hids
- ES350 interior ambiant lights
- eBay HID conversion kit quality
- Onex HID KIT
- 3rd es300 projectors?
- Interior Bulb Replacement?
- Help please ... LED brakelight out
- 2000 Ford Mustang LED lights
- V-LED's new 9005 2x 28 LED DRL
- black housing???
- Need a retrofit installation estimate!
- Need 1156 led!
- HID question
- 92 sc300, cornering lights > hids = light cut out!
- Few questions about headlights - 2001 ES 300 HID lights
- Load resistors and electronic flashers
- they just shut off! =(
- Es 350 - 2007
- HID Running Lights Minor fabrication
- Lights for speakers
- Type of Relay Harness Problem
- which vleds for gs300 sidemarkers?
- Looking for LED Info...
- Need Help HID 1999 ES300...
- HID bulbs help! one side is purple/dimmer/discolored
- Right HID low beam out
- headlights
- what HIDextra kit matches these ultras? (pics!)
- before/after sylvnia silverstar ultra halogen bulbs
- LEDs & HIDs! just random pics of stuff i installed
- Aftermarket HID problem on ES 350 (ES350)
- projector glass
- high beam/ DRL question!
- Left Fog Light Out
- [DISCOUNT INSIDE] Halo Aftermarketing Lighting Special. Cool Customer Colors! D4S HID
- Trying to register on HIDPlanet... Need Help!!!
- Fog Light Kit around flushing?
- best HID's
- Clear ome fogs for yellow???
- 1998 GS300 LED Install Need Wire Guide.
- fog lights
- HID: bulbs or ballasts problem for IS250
- HID Flickering On Startup Only
- Xenon/HID Light keeps turning off!!
- Brightest Parking/City Led
- 2.5W SMD LEDs
- Footwell Lighting?
- Drl's
- Head lights need adustment
- trade clear foglights for yellows (2000gs300)
- 1156 LEDs !!!
- Anyone recommend a shop that can upgrade my lights?
- Meter pointer lights
- Relays and harnesses for HID retrofit?
- LED bulbs is it PLUG n PLAY? or mods needed?? HELP
- Hid is-f
- Head light issue
- Stand Alone Fog procedure same on most Lexus models?
- DDM Tuning HID vs Volt HID for 2002 LX470
- Educate me on LED's
- 06 GS 300 - Head Lights go out
- Ok to mount ballast to battery?
- Headlight and Fog light Bulb question
- Projection issues! HELP!!
- Xenondepot XtremeHID 6500K kit pics
- Fog lights mod???
- IS-F fog lights
- rebased philips ultinons for fogs
- is250 5000k bulbs
- Disabling drl????
- DRL Bulb
- LuxuryMods.com - DIY HID Retrofitting for 98-05 GS300/GS400/GS430
- SC3/4 Retrofit bracket
- hid kit
- RX330 light assembly needed!
- H3 HID kit for 96 gs300 trouble
- Retrofit FX35 Projectors. Which shroud to use?
- Puddle lights on a 2gs...
- Quick HID Conversion Question! Plz Help!
- How to replace the dash bulbs on a 96 es300?
- How to disable the DRL? 01-05 GS430
- Need lighting help!
- Finally got it Done!
- help! honda fit hid kit
- Angel/demon/halo headlights
- LuxuryMods.com - Infiniti M35/M45 Retrofit into 2GS
- 2010 GX460 with HID kit from XenonDepot.com
- 35w or 55w HID kit?
- Backseat Courtesy Light Issue for a '93 LS
- 2010 RX350 Fog Lights
- Customize Any Headlights!
- '95 SC300 fog light issue
- My S2K's Flicker > Your Flicker
- Is there a retrofit with Q projectors???
- parking lights question
- 96 gs300 fog lights not working
- GX460 - Electronic Flasher - LED turn signals
- Dome light question
- RX Hatch Light won't stay on
- hid kit?
- Lextasy.com Halo lights?
- New HID bulb Flickers, turns off? Possible problem?
- 5000k, 5500k, or 6000k
- iJDMTOY.COM??
- Clarification on DRL's 3GS
