- ECU problem California Emission
- for anyone brave enough, a 1gz swap!!
- Tips on installing door lock actuator
- usdm gte
- got a few ?s need ur expert help
- 1jz fuel management....not finding good info
- oil level sensor leak....
- SC400 Power Steering Pump Replacement Costs?
- Tail lights help
- transmission question
- injectors
- need help.. quick question.. radiator..
- I dare you to figure this one out.
- SC400 single turbo project planning
- Crank Pulley Bolt torque
- What makes an SC400 sound like this - Videos with sound
- Water pump replacement questions
- 1jz soarer stalling when hot
- Engine Brackets to Motor Mount Question (1jz>SC)
- Radio gets power, but no sound....:-(
- LSD-Unit MK.IV possible to install in ´97 SC400 Diff?
- Need info... 2JZ-GTE in my 1JZ-GTE Soarer.
- Will a Soarer SMIC and piping work on a 2JZGTE SC?
- How to: Starter removal and installation SC300 *Pics*
- 92 sc300 with 1jzgte a/c issue
- 92 sc300, alternator plug question
- code 41 and now a code 12?
- 2jzge-t with vvti head/tt cams/and no distributor
- dropped a socket down the timing cover area :( FML
- Weird problem with power steering going on/off
- Airconditioner moldy smell
- LSD or other?
- MKIII W58 Swap in SC400?
- E85?? E85 users
- Steering Rack Fitting Size?
- Wiring issue? Gauges, turn sig, steering tilt.. not working
- WTB: Door Lock Assembly
- Roll cage options?
- Fastest Stock Framed SC300 (no tube chassis or ford rear ect)
- Changing the clock lol!
- boost guage stop working?
- 92 sc400 tranny swap
- SC300 aftermarket ATF
- 1uz R154
- 1jz Throttle Body Question
- aristo transmission problem
- 1jz OE part numbers to add
- 2JZGTE Stumble when throttle open
- I feel like a huge noob
- 1JZ AC PROBLEMS! Newb needs advice!!
- Steering Rack
- Misfire Under load
- Blitz Nur Spec R, too loud?
- w58 clutch help
- Oxygen sensors changing interval
- Ding remover kits?
- No Idea what so ever
- BB or JB?
- Exhaust question(anyone here "mikeahowski"?)
- In with the GTE
- Will an MK4 Supra N/A ECU also work in an SC300?
- question for the w58 guys
- Help me decide what exhaust to get.
- 30-40LS transmission vs 30-40LE transmission
- OD Light Code
- Wondering about my 1jz tranny
- Cat problems
- Need help identifiing a wire harness plug on sc300
- I need an ECU for '92 SC300 !!
- hard accel lag???
- 98-00 SC400 5spd auto 1st & 2nd Gear Dash lights problem DIY
- Any noticeable gains for a na sc400 w/ intake+exhaust on a tune?
- PPE Engineering in Arizona looking for test car
- 95-97 SC3 1JZ swap starting/3K issue solved!
- torque converter install
- BoostCreep
- SC 400 - electrical problem
- 99/vvti + Supra LSD/3.76 = FUN!
- This part: WTF is it called?
- boost issue?
- overdrive thump or clunk please help!!!!!!!
- All a/c vents not blowing same temperature
- Transmission issues caused by AC??
- alarm issue or door pins?
- which ems - BPU 1jzgte
- SC400 + 1JZ + 1JZ AC compressor = Need your help!
- 300 to 400 diff swap - benefits?
- SC300 Tuning Options Help!
- for the 1jz VVTI guys... downpipe?
- na-t building beginning
- Oil Pressure light when I brake. 1jz...... HELP
- Tranny leak
- Rattling on Start-Up
- Determining VBand Clamp Size
- 1995 sc300 engine mount question (need part number)
- Remote key to 1997 SC300
- Cat removal?
- Driveing Home but ended walking 3 miles.
- Alternator help
- 1jz swap progress.pic...what plugs is this?
- High mileage and BHG
- Car overheats with a/c on?
- ac fitments????
- help auto tranny wont engage
- Rear Main Oil Seal Issue
- sc300 not starting please help me
- power steering back flow?
- Help with Sputtering and hesitation.
- Differential swap on a stock 92-97 SC400
- 99% there
- compression/gas mileage
- 5-speed ECU/check engine light issue
- MK4 Mishimoto on SC300 Fan Shrout Problems
- documentation of a bad ecu
- question about NA-T
- Dual "in tank" Bosch 044 fitment???
- smell so strong raw gas with (CHECK ENGINE LIGHT)
- 2 ?s need help on. fuel realted
- Skyrocketing temperature needle.
- Power steering: constant noise
- injectors stuck open?
- fuel ecu prob !!!
- changing exhaust cam on a vvti 2jz?
- finished the build!!! :D
- How much was your last Timing Belt, Water Pump
- Squires Turbo install questions
- 1JZ Not start (no fuel?) help me out. *long*
- Should i buy?
- 2JZGTE Overheat/Oil dip stick
- single turbo 1j guys, IAC Valve....?
- VVT-i or Non
- Driveshaft options for LSD from supra auto TT??
- running lights won't turn off!
- Tachometer not working on my 1jz sc300
- Need Wire Pinouts for Broken Plctic Connector on 92 SC400 A/T
- 1jz/2jz compatibility questions?
- Aem ems 1101 cal problem (crank sensor settings)
- Relocated wireing harness, now car wont start
- Help with exhaust system!!
- Power Steering Pump : OE or rebuilt non-Toyota brand?
- sc300 tune up 97
- Need some help quick: Transmission removal
- 1JZ build questions / performance / maintenance. ALL ANSWERED
- BOV 2jz-ge question
- gas in the oil??
- Stock Exhaust?
- WTF? I need HELP.SC300
- What machine work to have done?
- 1jz stock motor mount length
- injector resistor please help!!!
- Amsoil Severe Gear for Supra TT LSD
- replacing clutch
- W58 tripod shifter- What piece am I missing?
- Let's just pretend I touched the inside of the MAF...
- HELP! Pressure plate wont engage!?? y?
- BFIing in progress... Help!
- tach only works when cold
- SC300 2jzgte swap???
- Who has a 1jz mated to SC400 tranny?
- Transmission feed/return
- LSX swap in progress.....
- Guys, do you think this would work on the '97 SC?
- Heater Control Valve
- torque converter lock up questions..
- Anyone know about fuel gauge ohms in our cars? and aftermarket fuel gauges
- Labor cost for transmission swap.
- Transmission hard shifting and doesn't downshift
- Who has the upgraded alternator?
- I need a link for manual shift boot/plate purchase
- JZZ30 soarer 1JZ VVTI motor swap on ebay
- Apexi Panel filter
- 1uz questions, swaps, and opinions
- Is it good to put a Intake on Sc300
- Coolant leak, Bucking/jerking, low idle, Intake gasket leak? Help?
- same side intercooler pipping?
- gte & ge interchageabilities
- TRD Strut bar for MKIV fits SC300 / SC400 / Soarer?
- New Black Carpet for less than $100? Elbow Grease Needed...
- Vibrations When 5spd swap w58 help.
- 1jzgte headgasket
- 2jz tt mounts on 1j sc...question
- idle issue and car not accelerating
- someone in Mi that can a do engine swap
- Exhaust flow
- Just swapped and having electrical issues(Help!)
- 95 lexus sc300 auto
- TT Break Lines questions..
- SC300 Tech Help needed - Alternator Plug routing
- How can I tell which transmission is with my 1jz?"
- How Do I adjust Idle sc400?
- Serpentine belt noise
- Sc400 Auto To Manual help?
- help
- Symptoms of failed timing belt?
- Code 12 on a 93 SC400??
- The holy bible
- FM Intercooler size for 97+ front bumper
- She stunk, smoked, then died....
- Using a VVTi ECU on a nonVVTi motor
- Need help with rack&pinion actuator/solenoid
- I replaced my ECU today, now my torque/acceleration is drastically slower, wtf??
- Quick question!!
- How to remove O2 Sensor
- Vibrations when 5spd swap Help plz
- Removing lower oil pan on VVT-i SC300? Any tips?
- spdrcr771's 98 SC430 1.3UZFE
- xspower or driftmotion turbo kit?
- Driveshaft installed - now won't Shift gears (1jz/R154)
- Greddy Emanage Ultimate on VVT-i
- Info on m/t pcm
- Turbo Compressor Chipping?
- First trip to the strip, ran some 10s :)
- Alternator replacement/Help please
- Engine Dies on Startup
- Na-T
- T4 housing for a t3 sc61 instead of t3/t4 adaptor?
- Catalytic converter question
- 1jz after market coil packs
- Diesel oil in a non-diesel engine, anything i should know?
- Look what the Boost Stork left at my door
- interested in turbos
- T67 auto?
- Help me identify these sensors? 99 SC300 VVTi
- Tranny and Clutch q's
- HELP : my SC300 start fine but dies after 10mins
- rear diff replaced and still sounds bad
- Free spinning/whistling sound when at slow speed?
- Noob questions about going turbo
- soarer 1jzgte goal 300rwhp
- soarer 1jzgte trans
- SC400 general performance mods
- Shift Solenoid
- W58 noise.. PPL chime in..
- Patriot Exhaust SC300 Headers?
- heat shield vs. turbo blanket
- Need Some Advice
- Transmission light flashes... Searched and want opinion
- Tutorial: Front Wheel Bearing Replacement
- Help needed!!!
- Bogging under Acceleration when warm
- jdm supra 6speed swaps
- To anyone with an LSD
- Big brake kit?
- Vacuum and emanage problem?
- Turbo Exhaust Quietest one?
- Diff Swap!
- Questioning of general rule about weight reduction
