- New tires for 2010 premium edition?
- 12V battery at 10.35V reading from my multi-meter
- Oil pressure light and engine coolant temp
- Jury rigging a quarter panel?
- How two major recalls ruined my HS250h
- Crank battery dead?
- Auto dimming mirrors don’t dim anymore
- HVAC Lights
- New HS owner questions
- New Owner
- Tire Recommendation
- tire pressure sensor resetting/replacement
- Pcs system and autoparts
- poor gas mileage
- replacing map lights
- 18 inch HS250h wheel value
- Has Anyone Blacked Out Their Grill?
- Hard ride - how to make softer ride
- Satellite Traffic activation
- Blind spot monitor
- 120k service - kind of expensive?
- midle east maps
- Hs250h rear speed sensor?
- shocks and struts
- Engine Air Filter
- Michelin tires for 18 wheels
- Filter
- Trunk Latch Compatibility
- front seat cooling
- TPSM Reset Switch
- Low Beam Headlamp & Wire Harnesses Replacement - Dealer Has 3 Month Backlog
- OEM Panasonic 12V Battery ?
- Effect of speed on mpg
- Hard shake on start
- 2010 HS250H or 2011 HS250H
- Anyone here ride shares their HS?
- 2010 HS 250h Purchase
- Parking Assist Sensor Error - Back Issue
- Post-recall for the 2010 HS
- Now there's a problem with headlights?
- Headlights on 2010 HS 250h
- ATF for CVT
- P0012 code
- paint fade on rear spoiler?
- 12V battery: any point to using battery tender?
- safety connect failure message
- Looking for back running lights on the trunk lid.Driverside
- Anyone looking for low-mileage, pristine 2010?
- 12 volt batterey
- Is Navigation with NavTraffic option as good as Waze?
- air conditioning condenser leaked over to Electronics
- My 2010 has never gotten the gas milage 35mpg as stated in manual
- Need Accessories
- Vehicle Information on Vin #JTHBB1BA9A2010108
- Latch on trunk of Lexus HS 250h won't lock
- Help: Headlamp system check
- Best tire option?
- battery for my key remote
- Toyota Avensis coilovers exact same as HS250h?
- Worth buying 2011 HS 250h now?
- Assorted questions about HS purchased from non-lexus dealer
- LED DRL Mod *need inputs*
- HS250h iPod implementation
- Extended Warranty for 2010 HS 250H Model
- why do i have two different tire sizes on my lexus hs 250h
- Safety Recall HLE (H2E) 2010 HS 250h Hybrid Vehicle Transaxle Replacement
- 2010-2012 hs250h headlight compatibility
- New Engine Install
- Intermediate steering shaft rattle 2010 HS
- Service your brakes
- Gas mileage dropping
- Bad service advice
- Is it worth buying 2010 Hs250h model
- Thoughts on the new LC500h?
- Heads up Unit
- Alot of hassle to replace factory speakers?
- HS250 Outside Temperature sensor
- 2010 HS 250h front exhaust pipe rusted off
- Update Naviagation System
- lost key fob
- Wind Deflectors
- Fog light not in place anymore?
- Trying to buy a HS250/Dealership question..am I wrong?
- Uh-Oh....battery issues?
- Anyone replace brakes yet?
- Cruise control
- Shark fin antenna
- Enform dropping e-destination?
- Headlights not working
- Excessive engine oil consumption
- 2013 Front grille to replace 2010 front Grille?
- rear cut needed
- Finally getting my first HS
- Wood Steering Wheel
- 2011 HS 250h Accelleration after braking - PROBLEM
- Lexus Hybrid Fever
- 18" wheel going to 17" wheel
- When you trade the HS250 what will you buy?
- Test-drove my first 250h: Thoughts and questions
- when should I get an alignment
- Happy new year!
- New fuel pump = lower MPG's....
- New Owner Here!
- Time to depart
- Considering hs 250h: some maintenance questions
- Help me !! Urgent....
- New to forums with modified HS hybrid! (Intro + pics)
- Replacing Heated seat module control
- Hs250h performance upgrade ?
- Getting 26 MPG for my Lexus, is that MPG normal ?
- Mouse hunt is over!
- Used HS 250h a good buy now over ES 300h?
- Break caliper seized
- Check your spare tire pressure...
- Just bought my 3rd HS250H
- HS 250H 2011 replace low beam bulb
- HS250H Head Light /Dim Light
- Seat track problem
- Would I be happy with HS coming from 2008 Prius?
- highest mileage HS 250h out there???? any problems???
- 2011 HS250H - What would you recommend - LED Lights
- Trunk Repair
- Touring vs. Premium
- HS audio vs Highlander JBL system
- part # for the key fob glove
- Little Lipstick for the HS...
- No Audio Whatsoever!!
- HS250H How to remove Radio Unit
- Pic of your HS 250h Right NOW!
- Changing License plate bulbs in HS25Oh
- Gah! My first door dings
- My #StealthHS
- HS 250 Dead Battery, Had To Jump Twice In One Day
- Hi there clutchless
- Manifold Dichotomy...
- Lexus hs250h auto folding
- HS250H brake job?
- Engine cover clip
- crackling
- Fuel Pump and Wire Harness Replacement
- Depreciation
- time to replace 12v battery?
- 90k mile service
- Fuel injector cleaner messes up MPG computer?
- OEM Factory DVD Video with Navigation
- Aftermarket Pioneer Double Din
- both headlights out at once
- Help Identifying Part
- Warranty just about up!
- Just purchased 2011 HS ... few questions
- Mesh Grill??
- 2010 Lexus 250h Remote Starter Installation
- interior lights not working when door opens
- Loud rattle behind glove box
- Upcoming 60k Service
- day/night auto switch of screen
- Hi there
- Which Fuse protects the USB Port?
- Thinking buying 2011 HS
- Car will sit for 3 months
- HS250 Vs ES350
- How does the hs drive in snow?
- light in truck?
- Replace HS250 OEM battery with what aftermarket battery???
- Anti-lock brakes not working?
- HS is liking the fall weather
- Announced Today - Excess Oil Consumption
- Great Depreciation!
- Prius battery life
- Rear LED tail lights (LED) burnt?
- Here we go again.
- 12V battery replacement on my HS250h
- Whistling noise after car shut down
- Hybrid Drive Battery Life
- 10 speaker vs. 15 speaker?
- 2010 HS250H - Hybrid system check which leads to a fuel pump issue
- Remote Windows/Down
- Hybrid Coolant Servicing
- Struts/Shocks for HS250H
- HVAC whirring sound?
- Calibrate
- Rotor / Pad Recommendations
- Unlocking trunk
- E85?
- Spark Plugs
- Sewall Parts
- Heated steering wheel?
- Driver/Passenger side view mirrors
- Considering the HS - What to look out for
- Lexus HS250H driver's Mirror problem
- Higher wattage low beams
- Changing the fuse - cig lighter adapter in center console
- LED side mirror turn signals
- Condensation in Headlights
- Navigation Nanny Override?
- Auto Door Lock Settings
- Oil Change Service light
- Blindspot Monitor Mirrors
- Newby Struggling with Backup Camera
- Change Your Transmission Fluid NOW!!!
- Frequency of Oil Change
- Is the Lexus 250h based on the Toyota Prius
- Installing Lexus OEM and aftermarket remote starter
- Happy Holidays!
- Battery Dead
- Caller ID (name is not showing)
- Power mode - what does it do?
- front defroster
- Osram Night Breaker Plus low beam bulbs
- lexus hs250h air bag problems
- 2012 HS250H chrome door handles?
- Navigation data update
- Intuitive Parking Assist Settings Adjustment?
- HID & Led Foglight installed (Morimoto's)
- Oil Change 5k or 10k with Toyota Oil Change Service
- How to disable the route "trail" from the nav.
- parking brake
- hs 250 accessories
- Dashcam's and Installation..
- Oil change video
- ECO mode
- heating and cooling seats
- MPG Calculation
- HS future maintenance and parts cost
- 20K miles Premium 2010 for $25 K ?
- newbie
- In cabin air filter replacement
- Key fob battery
- Lighting Upgrades
- Lexus HS250h at least 2010 or Ford Fusion Electric
- 60K service done
- Low mpg !
- Rear motor/fan sound?
- Newbie questions
- 18 inch Wheel Questions
- Disable DRL
- Blower motor
- Need help removing rock chips off my lexus hs asap!!!
- Push Button Starting
- Middle east Maps
- Rear View Mirror
- Clicking sound when turning the steering wheel and seats?!
- 12v Battery
- New owner of HS 250h (well not technically the owner)
- 18" Lexus HS Wheels with 6 tires
- LEDs - Flasher Relay help - AIRMAN?
- 250HS Ride not Lexus-Like
- Parking Assist Retrofit
- O2 Sensor
- Help! My seats are peeling!
