HS 250h Model (2010-2012)
OEM Panasonic 12V Battery ?
Old Feb 18, 2018 | 02:14 PM
noku's Avatar
noku
Default OEM Panasonic 12V Battery ?
Regarding the OEM 12V Panasonic SD55D23R battery....does it come with the hose vent connector piece already installed on the battery or do I need to reuse the old piece? FYI, first battery change on my '10 HS250h w/ approximately 64k on the odometer. Dealership seems like my only option since Hawaii not a place to find rare items like this battery. Has anyone compared the price difference between a Lexus/Toyota dealer?
Old Feb 18, 2018 | 07:14 PM
hnlaj's Avatar
hnlaj
Servco Lexus is your ONLY option, in Hawaii at least. It was around $460 I think..
Old Feb 19, 2018 | 09:23 AM
noku's Avatar
noku
Mahalo brah, don't think Lexus Parts Dept opens today but will try and see a friend who has a business account with them and see what his price will be. Hope that the new one lasts for another 8 yrs
Old Feb 20, 2018 | 09:02 PM
noku's Avatar
noku
Got my new battery today from my buddy who ordered from Servco Lexus here in Honolulu. Listed at $416.57, discounted to $312.43 plus wholesale tax $1.56, total $313.99. Lucky for me. FYI, new battery does not come with that plastic overflow elbow or hose. I'm pretty sure (haven't tried it yet) you only need to pull off the elbow from the old battery.
Old Feb 21, 2018 | 02:27 PM
noku's Avatar
noku
Another item I've learned. The plastic elbow is not just pressed into the hole, I'm pretty sure it locks into place. The battery end of the piece has maybe 3 or 4 grooves around the end section circumventing the tube and also what appears to be an ear perpendicular to the piece. Normally you will find the elbow facing the 3 o'clock position when already installed on the battery. I tried pulling on it in this position and it seemed to be stuck. Only after rotating the elbow to the 12 o'clock position did the elbow feel a bit more loose. I was then able to remove the elbow from the old battery. Installation was just the reverse, except I applied a little pressure inward while twisting the elbow until it once again is at the 3 o'clock position. On such an expensive battery you would think this elbow would already be installed on a new battery.
kubakj
Apr 19, 2019 02:32 PM
lexusrus
LX - 3rd Gen (2008-2021)
Oct 22, 2017 11:45 AM
SNiiP3R
Oct 24, 2016 08:29 PM
251Lexusux
Sep 30, 2015 08:16 PM
youngwatts
RX - 1st Gen (1999-2003)
Feb 16, 2007 02:13 PM
