View Full Version : Suspension and Brakes
- Help! Need realistic labor estimate for shocks/coils replacement.
- Lowering Question???? please help
- Corner weighed the GS yesterday
- Sportier Suspension
- Looking for a 2 GEN GS with 3 GS silver brakes
- Spring rates
- Im guna do it!
- Help with ball joint question?
- Will I see any handling improvement with just shocks?
- which Tein coilover would u recommend
- Is this dangerous?
- Hand Brake issue
- Brake Master Cylinder
- ls 400 brakes upgrade...do i need a bracket?
- L-Tuned Springs + Stock Shocks. Will it work?
- clunking noises, not from lower ball joints
- How big spacers for stock 16's to clear LS400 brakes?
- Where to find rear knuckle bushings for 2GS
- Brake lines
- Spring rate for HKS LS 65mm???
- KYB/Eibach combo vs. Megan Coilovers??
- I did it...I messed up my wheel bearings!!! I think.
- Differences between 98-00 and 01-05 brake master cylinders?
- will a 2001 is300 megan coilovers fit on a 00 gs300?
- used teins
- Symptoms of faulty brake master cylinder & booster?
- Opinion on Rotora and Ksport BBK's
- 99 GS300 Calipers locked
- Eibach Question
- Traction Control Sound
- supra TT brakes
- RCA question
- Please help me choose the coilovers
- Best Brakes/Rotors
- best coilovers
- 70k+ miles on OEM brakes?
- steel wheels for 01 GS300
- Your opinion?
- Help the exchange Daizen Bushing, I need help! ! !
- rotors' minimum thicknesses
- Best Lower Ball Joints?
- lowering gs this weekend
- Worn out Springs?
- Question about IS parts fitment on 2GS
- caster arm bushings shot again
- New Height for 2010!
- Rebuilding LS400 calipers
- what do i need to remove the rear shocks
- car wanting to jus take over? need help
- Brake / Rotor Help 911!!! Please help
- lowering springs????
- question about coilovers
- UAS burned
- Is Lexus IS300 springs interchangable with 98 Lexus GS springs???
- Looking for Lexus 1998 lowering springs......................
- best/easiest way to remove a frozen caliper pin
- So what DOES happen with air suspension failure on 22's?
- I did research on RCA's and think I am going for it.
- RCA without coilovers?
- BC Racing Coilovers ????
- Trust greddy type S coilovers, anyone?
- K2 sports coilover ?
- rear upper control arms
- front camber kit
- EBC rotors?
- Anybody have the SPC upper control arms?
- Nagisa Fender Brace question
- Caster Arm Bushings
- Cusco front lower bar? GS400
- RCA's for Zenki 2GS and the Kouki Ball Joints
- GS Shock Absorber info - BILSTEIN PPL !!!
- Supra TT 4pod brake caliper VS 95-00 LS400 4pod brake caliper, DIFFERENCE?
- Type of rotors/ brake pads?
- Brakes
- LS400 Calipers
- anybody know where to rebuild APEXI coilover
- camber kit
- My Ride Height > Yours v.epicfail
- New 2GS owner with alignment problem
- help! i feel like im on a boat
- Dashboard Lights Suddenly Came On, Brakes Died, and High Pitched Squeal Noise?
- New Brake Pads ADVICE ?
- Sway Bars
- Simple Brakes Question
- Anyone have a template for rear strut bar install?
- GS Dies when step on brake
- Megan Coilover owners and Cold Weather
- Daizen DIY
- Can't adjust my ride height with my coilovers
- ball joints
- New Coilovers settling in
- ASC ABS and ASC OFF come on after changing lower control arm n brake
- Ls400 vs supra tt calipers, less lexus feeling?
- Coilovers for 2001 GS430??
- '92 SC400 Brake Calipers
- Trick to tightening rear ball-joint
- How low can you go before needing UCA?
- Toms Advoxx coilover rebuild?
- Control Arm
- Changing out my Control Arms
- Brake Fluid Mystery
- srut mounts
- Attempted to replace rear pads...epic fail ensued..help needed
- Help with coilover adjustment
- Megan Toe control arm (IS300)
- Has anyone attempt Supra Brakes on GS400
- Newbie
- JDM Aristo Cusco Strut Bar
- Alternate way to fixing highway whobble (Caster arm/tension rod/lower control arm #2)
- OEM Lower Control Arm No.2 related thread
- Looking for a strut bar for my GS300
- Daizen control arm bushing question
- Stock strut vs tein CS for air suspension?
- Rack and Pinion
- dummy coilover question
- help please!!!
- Rear Upper Control Arms
- Question on coilovers
- My Brakes Plus Lawsuit - Pictures Included.
- Are there any good write ups on LS400 brake swap?
- Sure, why not? Air build.
- Frontend
- Comprehensive suspension diagnosis tests
- Megan LR Coilovers, Camber Adjustment
- Need advise on brake and rotors.
- Rear sway bar links?
- brake pad question
- found another crazy deal for anyone wanting BBK
- Brake lights on and more
- flex or cs? for gs430
- Rear Suspension Bushing Kit
- Painted my ls400 calipers......
- Brake Question - Recommendations?
- Rear suspension help?
- I got the new upper control arms!!!!
- my ebay coilovers
- 2005 GS430 Rear Brake tools
- Driving on snow with air suspension?
- Clunking Noise
- Front clunking noise Gs400
- Bbk
- Those of you with RCA's and slammed, did it help decrease UCA banging?
- thrust angle, alignments and the like..
- Alignment ? Inner Socket (R & L)
- Best Tires?
- Lower Ctrl Arm No2 bolt stuck wtf
- Any one using Akebono Street Performance Pads
- Tein Strut Bar Fitment...
- Bump Rubber Cut
- Installed Front & Rear RCA, did wheel alignment...here is the result
- Power Brake Failure and Warning Lights
- 2nd Gen GS rear brakes, are the 400 and 300 the same caliper?
- BC Coilovers
- Need Advice on suspension options
- AST Control Arm Bushings - Anyone tried them?
- ball joints
- Bilstein PSS confusion
- StopTech vs. Goodridge brake lines?
- BAD SHOP INFO or JUST A HUSTLE?
- Safe to run 10mm spacers with 5mm extended studs?
- Rear suspension clunking
- Is my daizen bushing set missing something?
- Help!!
- Which coilover?
- What kind of grease for daizen bushings?
- Anyone here know the member Kadburry ? Tein suspension problem
- DIY brake bleeding?
- Rear upper control arm interchageablilty?
- HELP! Stoptech BBK (or any BBK) Question!
- Shock removal with or without a compressor
- New member, Dumped on stock 16's w/ Megan Coilovers. (PICS)
- Best high performance suspension for GS
- sway bar brackets Q
- ABS Alternator and Autozone Axles - Advice Anyone?
- Does Your Local Shop / Dealer Install Daizen Bushings??
- Dimension of Camber arms?
- front suspension fixes and facts
- Alot of questions...Decided to start here.
- Adjustable toe arms?
- New Brakes!
- Check your balljoints :)
- part number
- Garage Excellent Aristo - Slammed on coilovers
- r1concepts rotors
- Which springs on 20's
- Which components should I get for suspension?
- Sway Bars
- Suspension Overhaul - What am I forgetting?
- Can't Remove Caliper Need Advice
- For those who have RCA's installed...
- Need some help.......................
- Have I got the right Daizen CA bush kit?
- Swaying? IDK
- Tuck wheels= Remove splash guards?
- FIGS MEGA Arm interest thread. All parts in, how many should I make?
- Damaged ABS wire = Decrease in Brake Fluid?
- Got my RCA kit....... whats next???
- Brake Rotors
- Metal to Metal Contact In Rear
- Advice on Lowering My GS300
- ls400 suspension fits gs400??
- Suspension questions - Tein
- How do I put these clips on??
- Camber at certain heights?
- Rattling,Klinging noie in front end
- looking for megan coilovers!
- Need help with Endless BBK replacement rotor
- GS300 Sway
- GS300 Sway
- How do i remove rear hub
- Air suspension woes.
- final decision Q...bilstein HD vs KYB with Eibach springs
- Lower ball joints and Tie Bar end
- rotora bbk pad replacement
- Tanabe sustec pro coils?
- spring difference question
- BCR Coils....
- lexus brake sticker...?
- I need new brake pads, suggestions? never changed brake pads before
- popping yet again gs 400
- tein s-tech springs (anyone have them?)
- Loud and Constant Sound when I brake
- Suspension upgrade!
- front right brake pad screeching on and off
- Daizen bushings, RCA, & new coilovers - installed!
- New Brake Master Cylinder won't work!
- SPC Camber Kit and SAGE RCA?
- Rear camber kit
- Diagnosis - Problem?
- Brake job - master / slave cylinder
- Which Coilovers Go Lower? K-Sport or Megan?
- TRD Blue Sways
- Air suspension: repair-update..UAS/ Kyb struts..
- Nex coilovers ever heard of them?
- Control Arm Link --Please help identify this part
- Rotora Brakes for Sale
- stiffness on CS
- How to remove upper ball joint?
- Brake booster question
- suspension Q's for '03 GS300
- Front suspension feels loose and makes soft clunking noise
- How to change the brake master cylinder on a 2GS?
- Quick Question on replacing wheel bearings..
- Brake pads: Project mu vs Endless
- Need help in deciding what springs to get!!!
- Help with lower ball joint's!
- Lowest Coilover?
- Shift knob makes clicking noise when pressing brake pedal
- megan springs..not coilovers
