Question on coilovers
Wasup CL member i am new to this coilover system and want to purchase the tein flex but i have a question since i never lowered my car or know anybody that does this and I'm by my self when it comes to working on my car so my question is how do i get under the car to lift it back up if its too low i know this is a stupid question but i don't know anybody that works on there cars and i have a GS300 for 6 months now and its time to Modify
also what do you guys recommend in coilovers i want the best of the best as im gettin ready for an engine swap just purchased GTE engine with the GetRag 6 speed tranni
search is your friend. typically search either of the following:
coilover
tein
tein+flex
coilover+adjust
regarding adjustments, in a nutshell, jack car up, remove wheel, use the (2) coilover wrenches to adjust accordingly. typically, lowering is much easier than raising when adjusting. GL!
coilover
tein
tein+flex
coilover+adjust
The One
Well, this is now an issue with any kind of work/maintenance on the car that needs the car lifted. If you lower it too far, most shops will not work with your car. You will need to deal with most things yourself. You will need a DIY ramp like the one GSTeg posted.
You can even build the ramp with slightly thinner wood. You mainly want to get the car high enough you you can get a jack and finally jack stands underneath the car.
