Brake lines
When putting on the Supra TT brakes which stainless steel lines do I need? Ones for the GS or Supra? From my understanding there is a hook? or something that causes fluid leaks using the factory lines.
I did try searching but, I couldn't find an answer.
Thanks
Thanks
my understanding is that the stock brake lines work.
however, when i did swap to goodridge ss lines, i notice there wasnt that little "hook" as you said it, to line up the line to the caliper.
make sure though that if u do swap the lines, get new crush washers. this will help prevent any brake line leaks.
goodridge lines come with copper crush washers....total of 8 in each set....2 for each line.
back to the OP's question...I would suggest buying ss lines for the 2GS....thats what I did for my LS400 calipers.
jmax.garage
GS - 1st Gen (1993-1997)
Oct 29, 2010 07:51 AM
