- 1994 Ls 400 Key Shell
- How do i lower the headrest? 1994 LS400
- Great Info On Wet Trunks
- blown lighting igniton and trans.shift indicator
- LS400 HID Install Problem (1st gen)
- Quick ECU question
- Courtesy of fellow member "Suneet"
- engine ping noise
- No power, glowing red cat, misfire, at my wits end
- rear seat removal
- weird problem
- Wheel fitment on a 2LS
- 91 LS Stock Alarm Help
- stereo system 91 LS400
- noise when i turn the a/c on in my 96 LS
- Tail lights LS 400 1 gen.
- Is there anyone else out there with cloth interior
- Is there a LSD for the first gen
- Swapping a 1JZGTE into a first gen LS400
- Need Advice On Seatcovers
- Transmisson shifting
- 94 LS 400 - Is Grinding Noise Water Pump or Fan Bracket?
- Location of amp in '96 LS?
- Front suspension noise... too soon for struts ?
- 94ls searched forums, Still clunking--thoughts?
- What Coilovers should I get
- fender rolling
- Pulstar Pulse Plugs
- 2001 IS 300 Stock rims on '90 LS400
- Power Steering ECU Question - Kinda Urgent :)
- DIY Coolant Temperature Sensor change (PICS)
- Power folding Mirrors for the UCF-21
- How to check an Air Ride Compressor?
- few questions
- Err 14
- New LS owner
- On Hiatus For Hurricanes
- 94 LS400 139k Rack and Pinion Question
- Zinik wheels and tires
- Yep! guess what, power window problem.
- Rims on a 91 LS400.
- new p/s hose now not working plz help
- All LS400 owners with bad gas mileage READ THIS!
- Exterior color question on 1990 LS400
- 1994 LS400 Sunroof Drain?
- Wondering if Ill ever get air susp?
- Ls400 98 Hid Headlight, Is there a Missing Ballast
- 1990 LS 400 Air Ride Compressor
- info needed
- Sold my 92LS... yes, I have a story.
- Radio displa problem.
- For those who love old reviews.
- '90 LS Shaking - possibly need new rotors.
- Installing clear sidemarkers, 99 LS
- Part #
- 92 ls400 ignition coil replacement
- Need Help Extracting Engine ECU 93 LS400
- Starting problem
- Loss Of Power
- 1994 Spare Key... sewell too expensive, need help
- Passenger Side Mirror-Electrochromic Problem?
- Wheel Fit Guide
- Where's the headlamp level module?
- UCF20/21 Inner Tire Wear on Front
- newbie with a 91 ls400
- PPS ECU (Power Steering)
- ignition switch problem?????
- Hey guys, and girls, I have a weird instrument cluster question for ya
- What is this indicator light?
- Sudden Power loss,, ned help.
- headlight compatibility for ucf10/11!!!
- Online site to buy coilovers
- Can't pull codes ????
- book values
- 1997 ls400 w/Nakamichi replacement help???
- Help! possible water in oil
- No More Fogged Headlights
- LS400 Gas Bomb 1996
- Looking at the DF210's but want to see pics
- '91 LS400 Waxed
- Good price for these?
- 2 slight issues on my 96 LS
- whoes is this
- 18's On My 92
- Need help finding Curtains for my 99 LS400
- 1st gen LS400
- 2DIN Radio
- More bumper fun-not
- New Member : AsiaHiTopic - '93 UCF11
- The orange engine Icon on the speedometer?
- blown fuse?
- Oh so that's why my Japanese Battleship was overheating...
- engine code 52, no 1 knock sensor signal
- interference engine or non-interference? 1990 LS400
- Finally making progress (new exhaust w/vid)
- 1991 LS400 Brake and ABS Help
- Needing expert advise on issues for '90 LS400 I just purchased
- Help me choose! (buying a newer LS)
- Question: Best Catalytic Converter
- LS400 timing belt
- 93 LS400 vs 99 Acura RL ?????
- 96 LS for 5 grand a good buy?
- Replacing Screen at PS solenoid?
- '90 LS400 fuel pump system problem
- oh no, another window problem
- Another LS400 LSD Question
- Installed aftermarket stereo but antenna is not activating...?
- 1991 ls400 engine lopes then cuts off.. help
- 1992 Turn Signals and hazards do not work, need help asap thanx
- Lexus LS400 cigarette lighter no working
- It's a sad day for me..had to sell my car.
- Need a Decision on a 90 LS400 Purchase
- Front Seats, Leather and padding ...
- incredible gas mileage
- Stereo
- How to remove badges on bootlid
- 19" G37 Rims on a LS400?! Teaser Pics
- New, looking at '91 LS400
- ls400 lsd do they have it?
- New LS400 95' owner
- need some help with audio!!!
- UCF2X brake pad reviews
- Looking for photo of 1995-1996 LS400 in Blackberry Pearl
- Changing spark plugs on 2000 LS 400
- Key Question ... Help, Input Needed
- Factory Navigation Questions 98-00
- UCF11 sound system horrible?
- 1998 LS400 Oil Leaks From Valve Cover (cylinder head cover?)
- second gen power steering help
- Err 13 Cd Changer Please Help '97
- AM radio reception
- Teaser thread :D
- Why does my car have trouble shifting......
- someone please help
- Speaker problem when playing CD's.. cannot find w/search
- It has been too long...an update...
- I inherited my dad's 96' ls 400, so much potential, where to start?
- Help
- A/C Compressor help please!
- 2nd Gen LS Front End Vibration/Shimmy
- Smoke from UNDERNEATH the car, drivers side..
- Went to the dealers yesterday, need some help so i could save $$$
- Newbie and ebay??????
- brake caliper bleeder screw size
- 94 LS400 Won't Start? Is it my spark plugs?
- sensor short
- 2500 Mile trip in 3 days=26.8MPG
- Running amplifier power
- New member who has a few questions about a LS400 I might be buying...
- finally! pics of my LS with 25mm rear spacers and right size tires...
- Project Update, suspension, wheels and tires
- Oil viscosity change
- What struts and shocks should I put on my '99 LS 400
- 10PA20C Compressor Clip doesn't match
- tenabe df210 springs
- UCF10 & UCF20 scuff panel comparason.
- Car start but engine does not stay running if let go gas, what is wrong?
- good place for parts?
- roof spoiler/rear windshield visor
- tyre flyes: cool or not, probably a little of both...flashing led caps
- Muffler delete review on 1st gen '91LS in Texas; legal for state inspection?
- Pics of my LS at Import Alliance this weekend
- 1UZ-FE valve adjustment and my thoughts on it.
- OEM Celsior Badges
- Heated switch bulbs
- LS400 Timing Belt
- Want to by Mass AirFlow Sensor 4 '92 LS400
- 1992 LS400 air flow meter
- I need your help ls400 guys, what's this worth?
- Ebay Control Arms...any good?
- Help: 91 LS400 vibrations from the back
- rear center head rest, what do do?
- changed starter now car leaks
- interchangeable parts, possibly a dumb question
- Spark plugs / wires
- 90-94 Ls 400 Transmission Is There A Difference
- New owner of Lexus LS 400 Car is 18yrs old
- Trunk filler
- help how to sell 1999 lexus ls 400??
- You know you are an LS owner when....
- Will 225 40 18"s fit my 99 LS 400 came off of IS 300
- Need Help: Radio and Alarm
- JUST GOT MY FIRST LEXUS!! Couple questions?
- VSC Check Engine FIX
- Anyone running a 255/35/20 on rear ls 400
- SERIOUS COOLANT problem!
- Broken Door Handle? My DIY $5 Fix inside with pics
- upgrading Shocks/springs
- what could it be?
- Differential Bushings Diagnostics
- Do Kyb strut mounts fit OEM struts?
- New 96 LS400 owner. Few questions..
- what is going on? after replace PS and altenator
- Emblems
- General Rant - More Conclusions Needed
- 93 LS400 vs 95LS400 driving impressions
- New member with a few questions
- Arrrrgg.....swiped!
- Ls 460 Cruisin'
- 96 Seats In A 92 Model
- Blew a fuse.. I think.
- '94 ls ac condenser fan motor shot?
- car stalling
- A/C issue with 94 LS working but not
- Replacement Electrical Connectors Especialy in engine bay
- 3rd brake light question
- Temp Gauge for Ls400...Plz help
- Were To Get Some Cheap Curtains
- The Controversial Tranny Flush
- I know terrible rims
- Getting some wheels tonight.
- My 95 LS400 Thread
- Car stalls when AC turns off!
- Brake clicking and slight leak help
- Inner Tie Rod
- Tires
- passanger seat problem
- Weird AC problem
- 1jz or 2jz
- new member
- Drive shaft bushing problem -- maybe?
- Solar Sensor Replacement? A/C Related
- Cool is contagious,,,
- What was it like when the LS400 dropped?
- dash is seperated
- Check engine light won't turn off
- Control Panel panels
- New Rims YEAH
- upgrading a ls 400
- Radio Locking up?
- New Member
- install cd changer
- Air Suspension Problem
- What octane have you been using?
- door lock accuator
- Oil pan torque specs
- First Gen Owners Must Read!!!!!!!!!!!!
- Have A Slight Issue With My 93 Ls400
- my friends ls400.
- ls400 brakes rotors
- Colorado Members?
- New Member
- SC400 Engine on LS400?
- Intake Air Temperature Sensor
- Air Control Valve for 2LS?
- 1jz mounts into ls400?
- New Owner!
- Gated shifter to first Gen...HELP !!
- How to tell what month of manufacture
