1998 LS400 Oil Leaks From Valve Cover (cylinder head cover?)
Old 08-10-08, 03:04 PM
lexie
lexie's Avatar
Default 1998 LS400 Oil Leaks From Valve Cover (cylinder head cover?)
hey guys, some of you may have this same problem: oil leaks from the valve cover on both side of the engine.
And the oil leaks to the exhaust and smell kind of bad; I wonder how difficult to replace the gasket; I know there is a write up at lexLS.com but that is for '90-'94 LS engine. do you know any write up for '98 LS400? Thank you in advance.
P.S. Is cylinder head cover & valve cover same thing?
Old 08-10-08, 04:21 PM
cpcc
cpcc's Avatar
They are the same. Pretty involved. I had both done with timing belt and water pump for 1800 2 years ago.
Old 08-10-08, 07:27 PM
Photoinc
Photoinc's Avatar
Did you try and tighten the bolts, they do come loose.
Strange that gaskets on both sides fail at the same time.
Old 08-11-08, 03:19 PM
lexie
lexie's Avatar
Thank you photoinc and cpcc; I'll tried that; the bolts of my '94 LS was really loose and I tightened them but never check out my '98 bolts yet. I guess they must be loose too since the leak are pretty bad.
saleenssc
16
03-19-19 02:19 PM
nowbor
RX - 1st Gen (1999-2003)
05-19-16 03:44 PM
Ctyler
03-29-16 01:53 PM
skottydznt
05-07-15 07:04 AM
ktranne
07-16-11 08:48 AM
Quick Reply: 1998 LS400 Oil Leaks From Valve Cover (cylinder head cover?)
