PDA
View Full Version : SC - 1st Gen (1992-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 [253] 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. Front Lip
  2. Help !! whine at start up.
  3. Wood Console
  4. Pearl And Mini
  5. Flowmaster Vs Magnaflow
  6. mk4 supra parts compatibility
  7. Tokico struts with stock springs
  8. SC Tshirt designs
  9. Quick question about the power steering pump
  10. MPG vs. Performance
  11. Alternator?
  12. What are Some Common Problems in the 97+??
  13. Trac lights come on after 5 minutes?
  14. amazing smog numbers
  15. apexi s-afcII on sc
  16. sheepskin seat cover anyone?
  17. no 12v being sent to brake light in spoiler
  18. wiring prices
  19. ultimate sc accessory!
  20. Question on the SOARER wheel trade??
  21. Remote key FCC#?
  22. Before POSTING, Check these FAQ's
  23. Need me some LSD. but which one?
  24. Windshield Streak Marks
  25. windshield wipers
  26. Runner Widebody Kit
  27. Rear Light Warning Light?????
  28. OD / UD pulleys worth it?
  29. gated shifter
  30. Questions about Supra Brakes
  31. Check out my new car
  32. i should not even have to ask
  33. How bad is it?
  34. Changing color of interior.
  35. Removing front lip..
  36. Who is this from SP engineering?
  37. Jic Twin Spartan or Greddy MX?
  38. headlight diagram
  39. SC400 Factory Spring Rates
  40. New Guy and old Sc400
  41. What would you pay for...
  42. Oil filter
  43. What an improvement !!!
  44. 5 speed sc400!
  45. Welding Mufflers? Price???
  46. Bolt-On Adjustable Fuel Regulator
  47. OBD I Scanner Laptop Software
  48. pic please of trim right under windshield.
  49. Cartoonistic interpretation--SC400
  50. the material of dash: leather or vinyl
  51. the ECU upgrade available for the sc4
  52. -Help- how to gain access to my floods???
  53. how can i turn my lights on
  54. Lowering My SC
  55. repair manuals
  56. what kind of mufflers are these?
  57. lotsa SC's with...
  58. Smoke?
  59. diameter of stock intake tube on sc400
  60. Useless but cool fact!
  61. Engine bay fuse box
  62. Exhaust smell
  63. sparco and recaro seats
  64. Basic upgrade advice
  65. Shocks for SC400
  66. cant clear out tailights and headlights
  67. Interior code color?
  68. Interior Db
  69. Power Steering Pressure Hose
  70. Stall Converter Speed
  71. Securing the SC
  72. How do you like your SC 300/400?
  73. Broken Into!
  74. GAB shocks
  75. Anyone know whats up with my car? (strange noise)
  76. Rear Seat Headrests
  77. Cold Weather & Loud Noise
  78. L-sport line deck emblem
  79. How is the Front Badge Affixed?
  80. I'm back...Electrical Problem...& Idle Problem.
  81. Gold vs. Silver Badges
  82. screw size for cd changer mounts?
  83. Code 27 (sub-oxygen sensor)
  84. Rear Trans mount??
  85. ABS light on!
  86. ok weird question about 94 sc300 power antenna
  87. how to remove warning light?
  88. Need an injector upgrade
  89. Great site
  90. Wise guy using my photos from CL
  91. Soarer NAV Headunit
  92. Taillights Changed 4 Times w/PICS
  93. Self-fixing problems?
  94. Heck Yeah!!!!!
  95. fuel pump upgrade for more nitrous?
  96. instructions to remove the padded material from A-pillar
  97. light colored smudge on rear view mirror. What to do?
  98. Dealing with SRT
  99. Supra TT rim center caps w/o Toyota logo
  100. stock tires
  101. (Bird Cage) Warning Light
  102. Sc400 Performance Chip Modu
  103. trying to find a new trunk strut
  104. AC Condenser
  105. Injen intake
  106. can a amg or m series equivalent be built??
  107. Problems Problems even more problems
  108. New interior or I.C.E.
  109. Nak System Speakers
  110. '94 Burgundy
  111. SC OWNERS, let's UNITE AND WIN THE PHOTO CONTEST
  112. Carwash and E-brake
  113. sc300 NA-T turbo header
  114. sc300/400 gen info please
  115. battery not holding charge
  116. window regulator
  117. Will these mufflers fit?
  118. Is there an inexpensive way to install JDM emblems
  119. Swapping Key Covers
  120. Is a '98 climate control amber colored?
  121. Side skirts and trim
  122. Shift knobs for the SC?
  123. new member wants to touch up his sc 300 suggestions needed thanks
  124. Steering wheel auto feature. To use, or not to use... that is the question.
  125. How do the seat memory functions work?
  126. Rear Speaker Covers - anyone dye them?
  127. How do you tighten the seat nets?
  128. upgrades (exhaust/rims) *Any input *
  129. Is there something wrong with this?
  130. New Member
  131. Auto couture kit in Chicago
  132. Lower control arms
  133. Thanks to All
  134. Starting problem
  135. Alignment after Espelir 1.5" drop results
  136. which dash kit to get?
  137. 92 SC400 remote entry key has failed
  138. Installed Coilover Pics
  139. I cant open gas tank.... i tried both ways....inside and trunk...help!
  140. power stearing question
  141. Looking for an SC - Thoughts - Suggestions - Selling one?
  142. Did you cut your bumpstops?
  143. SC400 Changer in Dash??
  144. SC400 Price Survey
  145. My car wont start
  146. Heater blows cold even on manual set
  147. Cd manuals .... Are they any good?
  148. Installing cup holder fixed my gear shift lights!
  149. SC400 engine oil - The Lab Results
  150. Question for anyone who has put 95-2k tails on 92-94 car
  151. JDM Emblems
  152. Where to buy a Heat Sheild
  153. For all you 400 people, a little bit on the throttle body cleaning.
  154. blinking
  155. Radiator Hoses
  156. how can i adjust the headlights and change bulbs
  157. Has Anyone Seen This Sc???
  158. Supercharger Update
  159. Heated seats buttons
  160. Need pictures of a '97+ SC with Greddy MX
  161. Cold Air Intake
  162. sc400 restoring questions
  163. diy cd changer cushioning question
  164. What does everyones car idle at?
  165. Salt
  166. Kit
  167. Engine Health
  168. Advice on how to modify, and a subwoof question
  169. Least Experienced SC owner
  170. Tranny slips only once per day when cold
  171. Supra Trd Front Strut Bar
  172. Any sc300 FMIC pics?
  173. When should the timing belt be replaced on an SC400?
  174. My SC4 was Stolen last night
  175. It's A Sad, Sad, Sad Day For My Sc4...
  176. Would this work? RE: Needles
  177. My New Toys Came!!!
  178. Keyless Entry 97 SC300 HELP CONFIRM!! PLEEASE!
  179. New Member needs new brake pads!
  180. What is my car worth?
  181. SC300 Rims
  182. Opinions 97+ Spoiler or 92-96??
  183. Yep, another supra brake question for a newbie
  184. Experience with rebuilt P/S pumps, etc.?
  185. To The Point Exhaust Opinions Only!!!
  186. Jdm 2jzgte Vs. Us 2jzgte Vs. 1jzgte
  187. Insurance for SC3 & SC4
  188. Coilover
  189. HELP with Keyless remote replacement..
  190. CL 2003 calendar?
  191. sqeaking noise
  192. How I got my Supra TT Big Brake setup for $446.93
  193. Possible to swap the 5spd auto tranny?
  194. It's that time again, new wheels for me :)
  195. Quick question and thought
  196. Supra NA Eibach and Stock shocks
  197. Shift Kit
  198. About to buy an SC300, Need Help!
  199. question on off set
  200. Why is SC3 cost more than SC4
  201. Rub Strips on an SC 400
  202. JDM 2JZ-GTE wire Diagram wanted
  203. NEED HELP....wheel well parts? All you TEIN riders...read this
  204. Trac Light On?
  205. Coolant Reservoir crack and leak
  206. Bad Vibe Pt 2
  207. PS pump seal
  208. KYB/Eibach Setup Caused Major Tire Problems??
  209. Interesting experience with Carson Toyota last week
  210. question about the 300 and 400
  211. Does your SC drift on uneven patches of road?
  212. SC in Fast and Furious 2 ???
  213. I hate winter!!!
  214. What's the best oil for my sc400?
  215. destroyed RHS front caliper on my SC4
  216. Pictures, exhaust manifolds and broken engine
  217. stock stereo
  218. automatic to automatic swap?
  219. peeps who've done tuneups on thier sc3
  220. sc300 ecu pinouts
  221. Automatic or Manual
  222. Hey, guys Is there something I can paint the interior with ?
  223. Future SC300 owner
  224. Climate control display gets dark marks on it when cold
  225. Gear shift lights burned out
  226. high speed flashers
  227. What's BEST way to REMOVE a STICK ON DASH KIT!
  228. SC400 tail light question
  229. Alternator Problem
  230. Interior Kits
  231. SC300 Head Unit Question
  232. gas mileage is nuts
  233. 1
  234. Radiator Cap & Reservoir Cap
  235. Installation or Springs and Shocks
  236. New Exhaust for SC400
  237. Driveshaft?
  238. Driveshaft?
  239. Gas Mileage is nuts
  240. poor sc
  241. sc400 question
  242. Can you replace with MK4 wires and cap
  243. Painting Caliper's
  244. 1996 SC400 specs
  245. The place 2 B 4 tips? Let's find out...
  246. Part # requests...
  247. 2JZGTE Front Clips
  248. Rims and Spoiler
  249. Differential Gear Ratios
  250. Air/Fuel Guage & O2 sensor
