- short shifter
- Automatic Transmission Swap
- ** 97-up conversion parts on Vendor forum **
- one funky custom sc400..
- Preloading Coilovers
- EGR woes.
- what do you think of these molded exhaust tips?
- Turbo Rebuilt By Turbonetics
- Fog light Issue
- screeching noise when taking off from a stop...
- intake and ecu
- Eibach lowering springs? plz hlp
- 96 5spd worth it?
- See What Came In The Mail Today!
- Momo Steering Wheel/Hub Question
- major problems, please help
- Tourmaline wheels
- 95 sc 300 8000 miles tranny problem
- pics of the Soarer FINALLY!
- Woo Hoo! Failed my inspection!
- Machine Shop work
- Smoke
- Put some 18" G35 wheels on my sc...
- Strange operation question
- Quick photoshoot pictures
- Overheated, coolant leaked a whole lot, and now wont start
- newly installed TRD strut bar
- Options for rebuild of stock 1JZ twins
- Starter location?
- Advice on purchasing 1993 SC300 Manual
- any idea on howto take this plug off?
- 1993 SC300 - When to replace timing belt
- nakamichi 12 disc CD changer question.
- Fuel Door Quick Fix?!?!
- Weird problem... Trac and idle
- Dumb Dumb me..Can u help me with timing?
- Boost and Transmissions?
- TT Sway bar bushings.
- quick question on lsd
- sc400 overheating problems, please help
- Should I trade my 97 5spd for this skyline?
- Hazard and Power ECT Bulb Part Numbers
- Side glass mirror rubber trim replacement?
- Newbie just inherited my first SC and I need help
- Cleaning the center console black plastic
- Valve cover gasket job
- Compatible engines for swap?- SC300
- What lights should I take out of the gauge board?
- guess what? got my car back.......
- Another odd coloured SC..
- biggest fuel injectors for stock fuel rail
- Year of my 2jzgte??
- Little help? My SC300 is dying...
- Rubbing tires, now w/ pics
- Photoshoot! Before & after pics
- maybe a dumb question, but...
- Putting Supra Suspension on a SC400
- FINALLY have pictures of my car
- Severe Idle Problem...Please Help
- Memory seat question
- Help!! does anybody know what rim is this? name & make?
- HELP: Check engine light just came on! what could it be? how 2 reset?
- na-t piping question
- rims vote ti5 rims any good?
- passenger door stuck
- A mechanic told me to get rid of my car.
- Question: Origin or Vertex front?
- sc400 odd running problem
- Special Service Tool - where can I get one?
- I can't find this front lip???
- Some Teaser pics.
- Please give me info on E-brake Adjustment
- Can I use 87 gas with a 1.3mm head gasket?
- Has this happened to anyone? PS pump
- What to do
- car fire
- 19" staggered wheel pics -POST EM
- Fast and Furious SC400 on Ebay
- cleaning the center console's black shiny plastic
- Ran her at the track today....
- Control Arms....
- The all too common Headlight problem
- Extreme Non Performance Mods For Sc400/300
- D1 Toyota Soarer in latest Turbo Magazine
- My big STICK !!!
- first time at track 95sc400
- How to remove auto-transmission cooler hard lines
- sc300 chips
- Time lapse build
- Just Washed and Detailed
- Cap and Rotor
- 2jz questions...
- removal of sc300 1999 fogs
- Quick Question
- NA supra tranny in my sc300 1jzgte missing a OD sensor??
- Better looking windshield wipers ...
- timing belt mantainence
- What do I need for a 97+ upgrade?
- SC300 Interior Removal/Installation Help
- Blow off valve BOV mounted pic request
- Help I'm rubbing!
- What intercooler for a 1jz?
- Just ordered my R154 1J!!
- need opinion DG-5 or JIC-TAR
- Would this SC300 be worth it?
- SC400 engine vibrates when accelerating?
- LS Big Brake Question
- Pre 95 and 95+/Supra W58
- spring/summer look
- Manual tilt override??
- sc300 aristo 2jzgte swap wiring?
- What is this on my 2jz?
- What parts are missing from my 1jz bell housing?
- Does anyone run 245/45/18 up front?
- headers for 2jztge?
- Pre-Detination Questions
- Stored my SC400 now I got problems...
- Trunk strut weird problem
- Hrmmm..Alternator Q..
- Window retainers help
- "Knocking" after starter replacement - Picture also!
- 2jzgte swap list please add if i'm missing things and make corrections.
- The Second Coming of Shern's SC...You gotta see this! Pics inside
- Here's an antique bargain for ya: 1912 Lexus SC 300 - $4,800
- Pics of headlights w/o 3yrs of cleaning
- How strong are the SC axles?
- '92 SC300 HG -- Let go! Need Advice now!
- help with maintainence SC3
- Pics of my 95 w/ 97+ facelift SC300
- hx35 on a 1jz?
- hood struts
- Newb question sc400
- 97 conversion questions
- best 1jz engine management options...
- Control arms giving out?!?!
- How to set up your suspension
- rx7 exhaust on sc300
- -GTE SWAP intercooler...searched didnt find
- airbag swap
- SC300 Looking for opinions/2JZGTE in possesion
- Resetting ECU after mods
- MAF problem?
- Alternative front plate holders
- Florida mall today - spoiler got jacked
- HKS VPC install on a 1jz-gte sc300
- IS350 calipers on the JZZ??
- Replacing parking light bulbs
- List the top three repairs or mods you want/need to make to your SC.
- Interesting info from Jarco (1JZ-GTE motorset importer)
- Tein SS too much wheel traval?
- Anyone I can send my fogged headlight to?
- -GTE swap check list
- Please Help With Decision.......
- lsd bearings.
- Running lean with resistors
- The long awaited *OFFICIAL* SC forum F.A.Q.
- What is required to install Supra (mk4) struts/springs?
- Problems.......
- turbo charging my first car
- Centerforce DF clutch on NA-T?
- terrible noise....
- W58 Tranny with Auto ECU?
- How will they look?
- Simple Question: Where's My 3rd O2 Sensor???
- What's going on? --SC300 overheating--Long post
- (MIA) What I've been up to..
- When rolling your fenders...
- Wiring HID's seperate
- Which 1uz would you pick?
- Heeeeeeeeeeeeelllllppppp! (need help on passing smog)
- Custom "Racing" seat
- Interior-Tan to Black plus Recaros (lots of pics)
- Burnt Soarer in Bahamas
- BBQ'ed Console controls.
- harmonic balacer
- everybody loves night and rolling shots
- NEW wheels!!!
- drive by video..
- clear skyies + no coppers in sight = night pics
- shot some safc2 a vids and some city whippin
- Fuel level sender signal range?
- New car 95 black on black 5-speed
- searched alredy: gte swap, 2 questions.
- heater problem NEED HELP!!!!!!!!!!!! ASAP!
- Seafoaming the Beast
- Just bought 92 SC 400
- looking for cold air
- loose wire
- Is It Recommended?
- need front camber kits for my 98 sc300
- What LSD for sc400?
- door handles?
- dyno results...
- What trans mount for r154? auto to manual
- autotrans shift faster?
- 95 SC400 gets 20 mpg
- 92 SC400 1JZGTE - Gas tank "bubbles", will not go much over 4k, severe power loss
- 92 sc400 spark plug question!
- Rear Spring And Strut Install
- Early pic
- tokico rear struts doesn't fit Tein springs....
- Vvti Curiosity
- Need some quick LS400 brake swap help, where does this part go?!?! (see pic)
- What mufflers? And custom intake
- Door in closed position, actuator broken, how do you get door open?
- Glassing my own SC kit
- 2JZGE valve lift at 100% throttle 4400 rpm??
- Question with 92 SC400. opinions?
- R154 deal...
- sc300 w/ 2jzgte Running lean
- Need Help!!!
- Wiring diagram to install gated shifter into pre-98 SC
- Achieving Moderate Gains
- timing belt/interference engine?
- car died is it cursed?
- Can anyone identify these "stock" wheels on this '00 SC400?
- Another What caliper color?! Need Opinions!
- Gated shifter
- Steering wheel removal.
- LCA's
- Soarer with Benz front
- Worst SC Spoilers
- Bodykit pics && sideskirt help??..
- Matching Steering wheel
- Wise lip with Origin sideskirts/bumper?
- engine check light
- Does anyone have Titanium Finish wheels on their SC?
- size of front and rear sway bars
- Clutch? What is wrong?
- Please confirm that I can install the Supra Torsen LSD into a 3.92 or 4.27 diff
- 1uz-fe intake
- a lil video of my car flying by....
- Serpentine belt
- Yet another Weight Reduction Topic
- How much should I pay?
- Want extra cupholders? Check my cool and easy modification.
- Another 2-tone SC400 Paint Job
- poor Sc400
- Goodies!
- Stumped, Exhaust!
- Wow. I am SCREWED! Something fell into the motor!
- Whats This Thing Called
- Wanna Power??????? From Japan???
- Loud noise coming from heater...
- Broken Ds Window, Door Wont Unlock
- Tranny swap?
- Updated pics of my sc400
- Lowered and TSX Retrofitted. Pictures!
- Supra and 2008 Lamborghini
- Head light film gone bad...
