- heat + more is out
- Check out my ride
- overheating issues
- Exhaust suggestions for boosted cars
- What Steering Wheel Options do I Have?
- This is what a "donked" sc300 looks like....
- Torque Converter for 99SC400
- Hi everyone!!
- Looking for Someone(In Regards to a Manifold)
- Running stock 15.7 quarter mile... Help me drop that into the 14s
- Electric Fan
- How to clean the rotors
- Rolling SC shots!
- High flow cats/headers for 99SC400
- need a new lsd diff broke while doing a burnout
- 99 SC400 catalyc converter
- Rear Suspension Overhaul
- Here we go... new engine and FI stuff on the way!!
- Another washed and waxed thread
- seat covers?
- Optimum take off for auto?
- just some update pictures
- steering wheel fixes
- I know I am going to regret this.."BFI"...........
- Help me find a shifter?
- 1jz-gte spark plugs / oil filter
- Black SC
- What are these chrome sc300 wheels worth?
- center console/radio screw sizes
- Little car rant
- What's the first thing for a SC400/93.........
- Lowered the car.....
- Who has the wierdest SC problem?
- New mufflers and tints
- new car pic.
- SAFETY VS. ANTI-THEFT: putting a detachable steering wheel on a SC400!! help?!?!?
- Brembo bbk question
- Yay New exhaust setup :D
- N1 Style Mufflers??!?!
- safc II settings
- What can be used for Power or Ground Distribution Box? (for gauges and such)
- butterfly in n/a intake mani???
- Clutch Line Removal???
- Engine Ground - Inside Passenger Cabin?
- Tiens or K-sport
- Engine slightly skakes car
- 9006 bulbs as 93 SC foglights anyone?
- Suggestions for quiet riding tires
- 2jz-gte swap and the gte throttle cable is short????
- what is the tork on the sc300 valve cover bolts?
- Exhaust........
- Airbags
- What upgrades could you do with $2,500?
- Body kit and exhuast question
- Does this fit into auto console?
- Bearings?
- need help diagnosing problem-fully stock setup
- Need some HELP
- Blitz or work for my SC?
- problem breeding brakes
- Need a few 1j swap confirmations
- New Lights, and Fogs...
- Power steering high pressure hose question/SC300
- E-fans in SC400's?
- Swapping Key Internals?
- 1999 2jz w/ vvti into 1992 SC 300
- LS400 vs TT calipers
- Changed my Rack Bushings .. Crazy Pictures
- Tomorrow is official SC-shopping day!
- JZX100 Apexi power FC???
- Wheel Design Contest.....
- My new 1997 5spd w/ black leather....
- R154 box in JZA80, speed sensor question
- Push Start?
- odd electrical problem
- SAFC II question PLEASE ANWSER IF U KNOW ASAP
- Show off your interior here!!!!!
- 97 Upgrade Part Number Breakdown
- Horshy or bad brake rotor company Cquence Motorsports ?
- Painting brake caliper.
- wood leather steering pics?
- Coilover Q (HKS)
- Supras Invades Las Vegas
- Black SC??
- vertex ridge available? found a site
- is yellow the tps 0.5 volt out put? n20 wiring.
- PLX User's, Simple Wiring Question
- My Old Car Was Stolen!
- Opinion on wheel color
- Changing fuel pump with full tank of gas
- Quick wheel identification
- 3D CAD of Subframe Bushings??
- MAF (LS400- SC400) compatable?
- Need Help!!!!!!!!
- Volk TE37/CE28N Time Attacks...anyone rocking them?
- So long CL (Merged Buick Rivera Youtube Comparo threads)
- Help with engine issues
- My SC300 NA-T done. Pics and vid
- special request
- radiator coolant line nipple broke need help
- 550cc Injector Upgrade
- 1JZ Cam Sensors and CPS Sensor are they compatible with 2jz
- 1j auto tranny troubles
- help problem w/ my 97 SC400
- serpentine belt replacement help
- supra tt wheels
- Red SC's post a pic.....JUST ONE!!!
- What are the name of these wheels?..........
- R154 prices???
- Speed cut?
- Will these wheels fit?
- Pic request
- Clutch pedal install
- Timing Belt Issue
- Crowler Valves
- sc300 differential questions
- Help plz Car shuts down while driving?
- Who is running an AEM?
- gs450h wheels
- what is a complete 5 spd swap worth??
- where can i get tex headers?
- CCC-TT's 2JZ-GE to 1JZ-GTE swap
- G35 19" wheels
- o2 sensor mounting question
- nobody buy this trans on e-bay
- Stainless Steal lines CHEAP
- Vid of Texas Jam 07 with 970rwhp SC300
- 2 fuel filters in the sc300?
- power steering pressure sensor Help
- Clear head light cover
- Tonight's project - interior paint
- data port on ODB1 2jz-ge cars
- Smell some gas in the ride
- 93 Sc300 pics eclipse wheels
- Front suspension noise remains after replacing most of the suspension
- need a pic of fuel pump assy 4 sc300-400
- New wheels and dropped on coilovers
- MAF Clean didnt work
- Am i missing something here?? TRAC
- Making brake system feel brand new...
- Rear Rotors SC400 Supra Fit?
- Carbon Fiber on the window trim
- Tilt Steering Problem
- new door problem cant open from inside only
- Poll Smoked 92-94 tails
- SC300 v Scooter >.<
- capabilites of the 2jz-ge
- what size serpentine belt to bypass a/c compressor?
- Steering Wheel Problem
- Coilover input
- Anteras on my SC3
- sc rear seat
- Looking for non Ross pistons
- Work VS-Kf's
- Bigs-N-Littles on the SC...
- rear end diff ratio for 5 spd
- Volk LE37K's on a black SC?
- 970rwhp on Stock GE short block
- engine leak
- To trade or not to trade?
- Question about front emblem location.
- teaser of whats to come
- Torque Converter
- Seafoam help... PCV? Where is that located at?
- Cooling Fan Problem
- Opinion
- Chrome or Gold Emblems for SC400
- help with looking for parts
- R154 soarer,mkIII differences
- I'm Coming Apart at the Seams - Help!
- My intro
- Black SC's with black rims
- SC300 stock exhaust w/ deleted resonators
- Downpipe / Exhaust question
- Gte + Bpu + Extreme Cold Weather
- $1.00 window regulator fix (not the plastic piece, don't get your hopes up)
- Griffin Soarer steering wheel....pics
- Stock 1UZ what exhaust is best?
- coilovers
- kyb agx or tokico
- Fixed my water leak behind rear seat and trunk
- 95 SC400 Alternator Remove/Install
- rivit removal
- 1.5 jz
- so i finally got the flywheel i needed so badly
- Removing Climate Control on SC400
- valve stem seal part number
- Pinout for 92 SC300? Or AEM pinout?
- glove box bulb
- bad BOV?
- soarer airbag in a wood leather wheel?
- Headlamp cleaning?
- fluidyne raditor
- sc300 mirror ecu
- i am out
- Detailed and good to go! *pics*
- JIC body kit : RSP or DWP
- hoebagged - the complete build
- Stage 3 Clutch
- Caliper Paint Removal
- caliper paint
- So what exactly was "retuned" in '95?
- how do i change my spark plugs?
- Seat Belts in SC same as any other Lexus?
- water soaked engine
- Woot ! She came in today !
- Difference 92-96 and 97+ Rear Bumper?
- Is the 99-01 RX330 Steering Wheel Same as 99-00 SC Wheels?
- My 96 lexus with new wheels
- Hissing noise when A/C is on
- Long Time Member 1st time Pic Shower
- Sly Guy Yu Is Back (Teaser, but wont be a teaser later on)
- Tie Rod Ends Inner & Outer
- car dosent idle right 93 sc300
- Pic Request: Mercedes Tint on White SC
- toyota ad
- Want the look of lowered, but not the stiff ride
- Where to find body kit pieces in US?
- switching to COLD air intake
- AFM cleaning: need help
- Attn Lex Owners... Cheapest Supra Brakes New!!!
- Something I've noticed
- So, im driving to pick up my girlfriend and..
- automatic or manual when buying ?
- Humming??
- I am having throttle position sensor and throttle motor problems
- Mini photoshoot: Gunnar & Black_SC
- Please help!! code 41 and 21+ egr?
- 1jz woes
- how do you open up 97+ foglights?
- lil help here plzzz
- Rotora Rotors
- Boostlogic Turbo Kit Install Problems NA-T Guys HELP!
- 93 sc300 odd a/c issue, searched 4 3days now...
- All-Weather Floor Mats
- Visual or Audible Signals when using Remote
- clearance question
- tire comfortness
- Please help!!! car stalling everywhere
- cant take off door panel because door cant open from the inside or outside
- 1- 1jz at Jhot i got the other =)
- I now revealed the new look :)
- Test Drove a SC400 1998
- test igniter
- Oh....the pain....
- V160 measurement.
- Belt ownage version 2.0
- Having Window Problem
- 93' SC400 vs 00' SC400: Are there substantial improvements?
