PDA
View Full Version : SC - 1st Gen (1992-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 [161] 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. Got Some New Rollers
  2. Will Supra engine mounts, fit a SC400 W/1UZ??
  3. ac not cold after 2 days of replacing compressor
  4. black lugs???
  5. White smoke?
  6. SC300 and Supra Front Shocks
  7. Another LS400 Brake thread
  8. V8 EKT headers installed!
  9. Anyone running an Emanage Ultimate? problem!
  10. SAFCII Weird throttle issue
  11. trac light on-when headlights are turned on?
  12. Ultimate SC/Soarer Picture Thread
  13. Will SC400 Tranny output flange fit on the 2JZ-GTE TT auto tranny?
  14. HELP - broke something
  15. Soarer on pinks
  16. My DIY e-Break Boot :)
  17. How Hard Is It to Do A RHD Conversion on a SC300???
  18. 97 Conversion - not worth it anymore?
  19. 94 swap for 97
  20. My SC Photoshoot with PhuShizzle
  21. my stock 1jz@track
  22. Alignment specs
  23. Performance mods with 97 Sc300
  24. Does this seem like a good deal on an SC?
  25. Will this manifold fit?
  26. Anybody using Megan Racing Coilover for more than a year?
  27. Soarer JDM Commercial
  28. State of California- legal engine options
  29. Tokico Illumina Adjustable: What setting are you using?
  30. How would my wheels look polished your opinion?
  31. My 99 Sc300
  32. Stripping/Swapping SC interior...how long does it take?
  33. New to Club Lexus/93 Black SC400
  34. quick yes or no answer I believe
  35. Pedal covers for the SC, auto tranny
  36. Question about spoiler
  37. Auto Trans swap 96 sc400
  38. Do I need to change the tensioner when doing the TB?
  39. if aftermarket wheels fit on sc300 would it fit on is250?
  40. Newbie: What is real difference between 300 & 400?
  41. Speed sensor solution to R154 swap w/ pics
  42. How do you know if you have supra or sc suspension?
  43. possibly the worst day of pearls and my life
  44. 1jz coil pack vs. 2jz coil
  45. fog lights sc300 help?
  46. Another new member
  47. Styling Suggestions!
  48. New to the club - 1994 SC300 5 Speed
  49. I need Help with blue e-manage
  50. Your opinion on new company
  51. SC300 goes 8.86 in the 1/4
  52. Toyota Soarer Vertex
  53. sc300 spring and shock combo advice
  54. New To Club Lexus
  55. New Catback Straight Pipe Exhaust Lots of PICS !
  56. What style should I go with for my SC3???
  57. Record Pass Sc300 Tony Performance
  58. Liquid in #5 and #6 Spark Plug bays
  59. Eng Codes, Throttle Response...
  60. Orange TT SC400 @ HIN, NC
  61. need parts number
  62. Re-painting graphite door trim?
  63. Automatic supra holding power?
  64. You SC owners are lucky SC>LS
  65. rear end info??? ive searched
  66. Finnaly got my car back
  67. Well here it is... my Auto Couture SC v.insertwittyquipabout56khere
  68. nrg quick release
  69. HELP PLEASE: Want to know!
  70. If you don't mind i need to vent. No more V8
  71. CR Kai's best fitment on a sc3/soarer??
  72. royal purple synchromax
  73. What's missing from this timing belt kit on ebay?
  74. Parking lights on all the time issue, *HELP*
  75. New Pics... TT rear sus installed finally.
  76. Valve after tb is'nt opening up causing reall bad idel
  77. R154 refuses to engage into first gear
  78. Vacuum Diagram
  79. Getting restless ..opinions needed
  80. Heat from the driver side
  81. Just picked up an SC3!!!!
  82. another w58 92 sc!
  83. *803* new pics
  84. Gauges fuse keeps blowing
  85. Engine just stopping, V8
  86. My Super Advans
  87. 1UZ guys running S&S Headers chime in!
  88. Check out this "deal of the century"!!
  89. SC400 electrical issue???
  90. New wheels for the Sc300!
  91. how do you find a car with blown engine?
  92. Anyone know if these will fit - Work Meister 2pc
  93. opinions needed
  94. New Look For The SC? Embarrassing Photoshop
  95. sneek peek
  96. needed new tires...ended up with something somewhat of a "streetch"
  97. Pics of my '99 SC3
  98. Fun Times - Code 24, 25 and 26
  99. help! keys locked in trunk
  100. brake problem?(long read)
  101. just bought my first lexus
  102. 1jz bellhousing
  103. using V8 maf with turbo (with 4" inlet)
  104. 2JZ-GTE Aristo/98 SC300 Swap
  105. Please help car wont start after crash
  106. help with removal rear view mirror
  107. Exedy High Grip Wear Carbon D Clutch Coming
  108. Low temp. thermostat..
  109. new to lexus...need help on setting timing.
  110. problem w/ my lowbeam harness...
  111. Soarer Gauge Cluster Problem
  112. Thinking of trading my car. What do you think?
  113. strange stall when starting
  114. T61 ar68 or ar 63 for 2jz-ge?
  115. steering wheel choice.... which one?
  116. List of Shop members recommend for Swaps
  117. Respraying 92 Wheels?
  118. Water Temperature Gague Install??
  119. 1j single swap and cruise control. what did you do?
  120. please post a pic of your eibach springs
  121. Identify this connector
  122. Removing Y pipe?
  123. to 2jz-ge people. i can use advice.
  124. My new 97 sc300...back in the game
  125. Do I wanna Buy this SC 400?
  126. Redline Auto tranny fluid...Anyone using this product in their auto SC?
  127. '95 seatbelt compatibility with a '97
  128. Boost controller install - how did you you get???
  129. Not A Good Day For The Sc 400 (help!)
  130. Not A Good Day For The Sc 400 (help!)
  131. No A/C after AEM EMS install
  132. Lights!
  133. What rims to get??
  134. Some pics of my babies....=D
  135. best place to get a window reg
  136. washed my car and took some pics...=)
  137. Too much time + stuff laying around =
  138. Noob in need of help PLEASE READ
  139. SC300 Radiator Question
  140. melted "city lights" cover... is there a fix?
  141. Catalytic converter: CA vs. non CA emissions. Any difference?
  142. !Photo shoot 56k be scared!
  143. bad oil sensor?
  144. Oil leak? Into the floorboard?!
  145. A/C pressure drop
  146. Clarification in threads
  147. RIP to my car
  148. ob1 or ob2
  149. Steering wheel motor going out?
  150. Pics of my 97 SC300 in the 813
  151. HELLLP!!! my sc400 is over heating!!!
  152. Engine Wont Crank...Just Spins Over
  153. Blown Suspension?
  154. just put on the pre 97 lip :)
  155. w58 output seal gasket
  156. What do you think of these wheels
  157. What is TT?
  158. throttle-body question
  159. Car wont start.?
  160. Door molding for 97+ side skirts needed?
  161. I SWEAR i've searched!!!!
  162. Product's Sc!
  163. Screw you, Canover!
  164. Can a high idle lead to damage?
  165. Rerouting Driver Side Harness
  166. Greddy Emanage Blue Maps
  167. oem front leather seat covers, can you switch from side to side?
  168. Help diagnose error codes '95 SC400
  169. After brake fluid change my dash brake light goes on/off
  170. Looking for Stock Ride Characteristics...
  171. USDM to Soarer R154 conversion q?
  172. Strange Temp guage problem..
  173. starting issue
  174. Price of a Turbo
  175. mvp motorsports electric fan and blitzs radiator cap
  176. Throttle body and Intake Manifold cleaning help!
  177. My headers are finally here!!!! EKT V8 lots of pics!
  178. Newby and milage
  179. Roof Spoiler
  180. The New Wheels...19" Axis Supermesh
  181. r154 transmission removal
  182. What's going on here : Injectors
  183. R our cars old?
  184. Anyone running ebay clutch on sc300
  185. R154 plugs - speedo, reverse, rear speed sensor
  186. dumb question about inside alarm
  187. Cast Iron Manifolds?
  188. VSV valve clicking
  189. Which Wheels?
  190. Pictures from another upcoming feature
  191. Where Can I Find A Roof Spoiler 4 My Sc400??
  192. Question about tach readout
  193. need opinion on idea
  194. Anyone have a pic of an SC w/ Eibach's and AGX's?
  195. Question about gauging idle RPMs
  196. Moonroof/sunroof Issue
  197. Need some help on electrical problem
  198. I need to vent: blown Megan coilover... under warranty, but still no replacement!!!
  199. HELP! need shop in the (323) to recharge my A/C.
  200. ABS or no ABS.... R154
  201. why do our spark plug wires suck?
  202. Clutch pedal diagram?
  203. crack on #1 cat. flange
  204. question: is the LS400 diff same as SC400 diff?
  205. 1jz cut wiring harness no body plugs
  206. Spring choice....
  207. Has anyone had experience with RACEONUSA's knockoff kits?
  208. Camry Throttle Cable???
  209. TT seats
  210. SC400 Engine Mount Replacement
  211. sc300 manual tranny removal?
  212. Brake Booster Location?
  213. r154 tranny install
  214. 1JZ with 2JZGTE throttle cable quest
  215. HELP: identify this part, and what does it do? 2JZGE people
  216. Photoshoot in the *303* --56k maybe...
  217. I hate it when people make teaser threads... so I'm going to go ahead and make one
  218. Recent pictures of my DD 'drift wench'
  219. New to CL!
  220. 1jz-question about vac hoses
  221. how can you tell if it's BB or journal?
  222. Pics of my new SC400 with 49K
  223. sc400 2jz conversion
  224. So I get a flat tire at about 5 this morning
  225. Speedometer Problem
  226. Another Ugly child in the SC family
  227. Headlight questions. I have searched. Can't find it.
  228. Need pics of a certain Soarer
  229. New Pictures of the blacked out SC, v. washed! *pix*
  230. Removing trac control all together
  231. Pics of my SC400
  232. Starter problems
  233. clutch and tranny issues
  234. Did the TT suspension swap today
  235. Rack & Pinion Seal Kit
  236. How do you remove window trim & pillar?
  237. few q's about NA-T(yes I searched)
  238. Sc300 Question
  239. Engine knocking noise? - Have video
  240. New To Site Please Help!!!
  241. 98-00 sc300 and SAFCII, help please..
  242. New rotors =) New problems =(
  243. I have several electrical issues, would you like to help me?
  244. bad thermostat?
  245. Hose Implode
  246. Mainfold and IC question
  247. so I went drifting the other day...
  248. Any Sc300's with SAFCII? urgent question
  249. Hello from Canada - Imported a Toyota Soarer TT
  250. july 4th car wash
