stock tires
Old Jan 22, 2003 | 01:04 PM
dpakman91's Avatar
dpakman91
Default stock tires
can anyone tell me what the stock tire diameter is for a 96 sc300? when i bougth the car it already had aftermarket rims so i do not know.
Old Jan 22, 2003 | 02:16 PM
pcmw's Avatar
pcmw
dpak,
There are several places to find this out. I think even the door sticker will tell you (not sure). Tirerack.com has the sizes in its database. lex400sc's FAQ has some listings.
Original Equipment 225/55-16
MW
Old Jan 22, 2003 | 02:49 PM
dpakman91's Avatar
dpakman91
great, thanks a lot. now one more question. how can i find out what tire size is proper for an 18x9 rim?
Old Jan 22, 2003 | 03:14 PM
pcmw's Avatar
pcmw
dpak,
You can fit several tires on a 9" rim. It all depends on your fitment. For an SC your standard tire would be a 245/40 to keep the stock tire diameter. You can go wider, but that usually means higher as well. Sometimes you can fit a 265/35 if the offset is right. Then, there are people that go even wider... However, because a stock SC300 cannot spin the tires like a v-8 muscle car, I do not see the need.
MW
Old Jan 22, 2003 | 03:55 PM
dpakman91's Avatar
dpakman91
alright, so for example, for my 18x9 rims that i will be buying which have an offset of 45, do you have a specific recommendation that would not be outrageously expensive, and would help maintain as close to an accurate speedo and odo as possible?
Old Jan 22, 2003 | 05:50 PM
pcmw's Avatar
pcmw
dpak,
You need to be more specific if you want a recommendation. Better the information you give, the better you will tend to receive. Things that come into play. Are they for front, rear, or all 4 wheels. Is the car lowered, how much, and chance of chains where you drive? Is the need you have to be cheap, or cheap/quiet, or cheap/performance, cheap up front but doesn't matter if they last 30kmiles, cheap and rock hard tires that last forever but ride and handle like crude. You get the picture.
If on all 4's I would stick with 245/40 so that the front clears.
MW
Old Jan 22, 2003 | 06:01 PM
SRQ400's Avatar
SRQ400
Stock diameter is 25.8”
Old Jan 22, 2003 | 06:26 PM
pcmw's Avatar
pcmw
dpakman91,
245/40 = 25.4"
265/35 = 25.6"
MW
Old Jan 22, 2003 | 06:58 PM
dpakman91's Avatar
dpakman91
well it would be for all 4. i am more concerned with quietness rather than performance if i were to pick one of the two. the car is at its stock height.
Old Jan 22, 2003 | 08:33 PM
pcmw's Avatar
pcmw
Then you need to get 245/40-18 in a Yokohama dB or ES100 tire
MW
Old Jan 22, 2003 | 11:37 PM
dpakman91's Avatar
dpakman91
thanks a lot, i punched those numbers into that tire utility and it say it would be .1% too fast, which is great for me. how much should i pay for these tires?
Old Jan 22, 2003 | 11:38 PM
dpakman91's Avatar
dpakman91
also, between the db and the es100, what's are the advantages or disadvantages of either?
Old Jan 22, 2003 | 11:42 PM
pcmw's Avatar
pcmw
www.yokohamatire.com
Old Jan 23, 2003 | 09:54 PM
dpakman91's Avatar
dpakman91
looking at some other forums, it seems that a 245 tire is equal to 8" wide? i am not sure about this, but if i am buying 18x9 wheels, will this fit?
mrmonster
Apr 2, 2013 10:57 PM
iwannadie
Oct 9, 2011 12:25 PM
Srd555
Suspension and Brakes
Nov 28, 2009 06:59 AM
RocketGuy3
Aug 14, 2009 02:51 PM
NCoastES3
Oct 24, 2002 01:53 PM
