- Putting the Supra and SC away for the winter
- throttle body
- just a couple new 92 pics
- 2jzge alternator
- CEL on 92 Sc300 stick
- Timing Belt Changing - What else?
- Size rims on 93 sc300
- Passenger Seat Stuck
- Mysterious noise
- Can I put a 98 and older oem trunk spoiler on a 99?
- Couldn't open the door from the inside?
- SC400 Alternator
- SC400 Vibration
- transmission swaps
- gated shifter
- New Lexus SC300 5sp, need to do 2JZ or 1JZ swap ASAP need help!
- less expensive tiny battery
- Im gonna Wh*re out my car in this thread
- auto tranny problem..
- Trouble with the law
- New member, just picked up a 1996 SC300 5-speed
- Green Tint Headlight Housing
- supercharger??
- Pictures of me car
- 250k miles club
- SC300 BFI.. project?
- HKS Speed Cut Defencer Type I or II, HELP!!
- Anybody tried the Power Steering Fluid/Sealer
- Side View Mirror not working
- **PLEASE NEED SOME HELP w/1JZ SC400***
- new sc300
- Changing weather stripping on sunroof
- hazard lights work but turn signals dont ?
- ECT/PWR reprogram
- sc spittin fuel!!!!
- Heater not working - Is this ok to do?
- Replacement for B-Pillar
- Goodbye SC fam =/ few pics.
- Power window issue
- Fitment Questions and Suggestions
- Can't do the LS400 or Supra brakes upgrade, what are my options?
- IS F front rotors
- Just bought an sc400!
- I have 2 questions.
- this is my 94 sc300!
- Power Window ground?
- new tires...245/35 on 10"...
- Any DIY's??
- cluster lights inop
- light problem
- 1JZ just got back from tuning/dyno...
- LS400 brake upgrade for sc300
- left over paint
- 1998 sc300 torque converter
- 92 sc 300 hesitation at part throttle
- Someone Make these...
- What paint to use to paint emblems black?
- South Florida representing the SC3's and 4's
- SC400 Rear Diff..... help please.
- Riding too Low, need to relocate harness
- Tailight wire diagram??
- white cloud of fuel!!!!
- removed headlights
- problem with water going inside the car...
- AC deletion???
- problem running lean???
- More tranny question
- I need HELP with my new SC
- Troublesome Electrical Gremlins!!!!
- Which One do I adjust?
- ECU Questions???
- swapping suspension?
- Automatic Transmission Cooler
- Sc300 Exhaust for T66 Turbo?
- is this a suspension problem? noise while turning
- My BFI build, SC400
- New to CL... check out my 93' SC4
- The proper way to do a Compression Test
- could a chart like this work
- Am I getting a good deal on an SC300?
- What needs to be replaced when air bags deploy on 97+ SC300
- lower strut bushing?
- Code 13??? RPM Signal...
- Enigne noise or fan noise
- Straightpiping an SC400?
- Lexus questions
- How thick is the stock tt headgasket??
- Heater control valve ???
- cranks over but no start no noise from fuel pump... replaced still nothing...
- **What wiring harrness do i need for 1jzgte going in a 97 SC300**
- control arm bushings
- bye CLUBLEXUS...
- Supra and SC radiator/thermostat interchangable?
- '94 SC400 "Operation Sleeping DD"
- JDMmuscle's Build history thread (TOONS of pictures)
- just a small photoshoot.
- Myspace link. Is the a CL member?
- sc300 headlight help
- Possible to Swap VVT-i Engine in Older SC400?
- Repacing rear main seal
- Question about a tranny swap auto to manual
- simple question for brake pad
- Help me install my SAFC piggy back.
- Some Pics of My sc400 after detail :]
- Is this limp mode?
- Got the KYBs Installed - HATE THE RIDE!
- safc and wideband o2
- Duck.
- Grey Interior pieces dye'd black?
- Need help asap!!
- Cheapest place for motor/trans mounts?
- Suggestions and Ideas
- CF Hood shocks installed.
- I need some help
- Sluggish off the line - Normal?
- WTB: 5w8 or r154
- sunroof delete ques.
- Radiator questions??? Is This Normal? Quick responses please!!!
- Weight of factory 10 spoke sc400 rims
- Lightweight and Power Question
- 2jzge to na-t ?
- SC400 head lights
- SC400 Factory Alarm disable
- Pics at the Lake
- Idle surging in park or neu. High idle in drive
- Help!!! Radiator/ Fan Removal Question
- Cam Seals vs. Valve Covers
- SC400 in accident - need help
- Sc400
- Realistic HP/TQ Gains
- First Start and ... Smoking, not blown headgasket, oil
- new shots in HD
- 1uzfe to 7mgte swap
- Please tell me this is not a blown Head Gasket
- need to replace spark plugs
- Last shot for a long time....
- car not starting and no fuel
- 92 SC400 Crossed Jumper cables - No Starter?
- driver side sun visor wont stay up
- I think my SC400's tranny took a break
- Problems Starting
- New tire + alignment, car shakes at high speed!!
- Few 1J related questions
- ??? how to remove the cup holder
- Got my Temp Exhaust done FOR FREE :woohoo:
- 96 SC4 engine into a 94 SC4..quick ???
- Getting the most out of the 2jzge without turbo..
- <><><>SC forum (F=6) Off topic chat night<><><>V2
- can SOMEONE...
- Fastest SC300 in the US...
- Injector Upgrade, last time.
- Car not starting....again
- another spoiler? keep or sell it
- Tragety!!!!!!!!!!!
- Electrical problems on my 92 SC400
- Well I thought something like this would happen
- Could someone get me a pic of ariisto oil pan?
- SC400 custom PS line specifications? (size, length etc)
- Simple tranny question for yall
- Question about Aristo 2JZ-GTE
- airbag lights on
- What type of coolant and where to add?
- Those of you with the origin kit?
- Dimensions on SC300 Auto and Manual Driveshaft?
- A list of all bushings to be replaced Please!
- Airbag light won't turn off
- r154 swap clutch problems
- 1jz/240sx's SC400 (Texas gets dumped)
- New Sc400 Owner - What Now?
- **PICS of my 1992 SC400**
- My new SC400 w/pics
- Help - Testing the oil pressure sender with a multimeter.....
- these rims 18" rims for my is300 rims
- What kinda of 5-speed tranny is this?? W58 or R154?? pic
- sc300 na-t on aem
- Can anyone tell me who makes this front lip?
- offseason/winter fixes mods
- Slotted Rotors = short brake pad life?
- OFFICIAL: Tanabe Medalion Touring Exhaust for SC300/400
- where did these tailights come from??
- Photo shoot at an event!!
- rear suspension banging
- sc400 lip
- Convert to Manual Trans?
- its been awhile since all of us seen this huh?
- Need 92' sc electrical diagram!
- Door lock messed up?
- CEL code P0500 VSS
- some update pictures
- for those who dont use ur cig lighter
- oh noes! starter woes!
- IACV Location?
- Getting another lexus, but what kind?
- Kind of new, been poking around
- Looking to do a swap.....
- SC400 heat ? (searched)
- A kick in the pants: Moonroof doesn't close
- Wash & Wax; Megan Coilovers installed.
- Location of A/C ORIFICE 96 SC400 ????
- alignment? help
- Na-t Injector upgrade info??
- I know, another heat ?, but I have piczorz!
- Noob! HelpME!!!!!
- part question
- Anyone have pics of a SC with 350Z wheels?
- Reasonable price for a 93?
- Stalling issues at a roll
- Some pics from Arizona HIN
- steering problem=( help anyone?
- how to: removal of tensioner 1uz-fe (sc4)
- Part #'s - Valve Covers & FIPG
- What is this sensor? Pics Inside
- Alright - here's to no more tickets. *pics*
- I'm powdercoating my rim's, what color looks best?
- Help removing stock Manifold
- Sc400 auto same as TT supra auto?
- Quick Question -Interior Help
- 92 SC400 radiator support removal
- i got her back
- window door lock solenoid problem
- Bought an SC 400, I'm anal
- Some new pics with my TT Brakes (56k no way)
- charging issues NEED HELP!
- what do you guys think
- Supra Control Arms?
- need help? just sold my s-class looking to buy 1992 lexus sc300 5speed
- Oxygen Sensor - 95 SC300
- 2 questions...
- How far can I go using only the battery?
- New member intro, and a coilover question!
- Replaced shift solenoids: Now worse :(
- Finally got my baby
- The end to all S-AFC2 installation SC300
- 550 Injectors __ stock fuel rail???
- sc project
- (CANCELED) Replacement clear or colored headlight Lens (CANCELED)
- new to the forum
- sc turned into a cop car???
- vehicle speed sensor help.
- Is it my clutch?
- Just Picked Up a 1JZGTE Auto Trans... NOW WHAT ?
- ..Another Friday Night Shoot..
- POLL (W/PICS): Roof Spoiler - Stay or Nay?
- 97 conversion question
- Sumebody Please Help!!!!
- Got a lip, painted... It's ON. (Pics) no on 56
- What price do you think is right?
- djb5118's 1992 Sc300 - Member Journal (56k, eh not a good idea)
- is300 fogs into 92-95 SC fogs
- Water pump?
