power stearing question
Old Jan 18, 2003 | 05:08 PM
ForNgoods's Avatar
ForNgoods
Default power stearing question
i've jus replace my power stearing pump. I purchased it from advance autoparts so i'm assuming its an aftermarket part.. my quesion is this... "is there a breaking in period b/c it's brand new?" I had the part installed and the wheel is a lot stiffer and harder to turn than normal? is this b/c it's not a OEM part?
Khang
Old Jan 18, 2003 | 05:26 PM
PERRYinLA's Avatar
PERRYinLA
When I replaced mine, it was not a "lot stiffer and harder" than before- it felt fine from Mile 1. Not sure of the brand, though, but it was not OEM.
Was everything put back together correctly? There are other posts mentioning a clogged fluid feeder hose from the reservoir. Maybe that's it.
Old Jan 18, 2003 | 07:58 PM
philauldridge's Avatar
philauldridge
Default power steering
I'd suggest checking the electrical connections to the PS unit. The Lexus PS is speed-sensitive variable assist. Without speed input to the unit, you'll definitely have minimum assist, and that "stiff" feeling
Old Jan 19, 2003 | 01:00 PM
Nobb's Avatar
Nobb
Something definitely wrong. When mine went out I had my dealership rebuild it with a kit. Smooth sailing ever since.
Old Jan 19, 2003 | 04:51 PM
ForNgoods's Avatar
ForNgoods
well i'm not sure what the new develpment is but i did absolutely nothing. Jus gave it a day to settle and now it's fine..... Oh well i'm not complaining.. works as good as it ever has. thanks guys for the help.
Khang
redfloyd
Sep 25, 2011 07:48 PM
SuperCoupe400
Jun 6, 2010 11:16 PM
machomateo
Sep 23, 2009 08:55 AM
Lex*Toy
Mar 7, 2007 07:56 PM
ChrisSC300
Feb 4, 2003 06:06 PM
