PDA
View Full Version : SC - 1st Gen (1992-2000)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 [162] 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278
  1. Rear lights
  2. Need throwout - maybe clutch?
  3. Safe Or Maximum Coolant Temperature?
  4. Lextreme stall converter
  5. compartment won't open...
  6. I thought id seen it all, till i came across this, Check it out!
  7. help Need SC400 drive shaft
  8. My First Soarer/SC400
  9. Show Off Your Wheels! 18's, 19's, 20's Only Please..
  10. wiper problem
  11. Need Help With Performance Parts
  12. 30 Days Thanks Club Lexus
  13. why an SC
  14. vent air problem
  15. Drive shaft bushings: Can I swap with LS400's?
  16. Does this turbo look alright??????
  17. BFI stuff on ebay?
  18. New paint job!
  19. Yet another "opinion" thread! **56k? It's nap time for you!**
  20. 1j/2j na-t swap
  21. sc300/400 clear headlight assy
  22. Braking system Supra Turbo 93-98 at Lexus SС 300
  23. sc300 automatic transmition tune up
  24. W58 weak points
  25. -727- Photoshoot of the SC400 *56k warning*
  26. Best price on TT Eibachs...
  27. swap question
  28. this is how not to fix a window lol
  29. steering rack boots
  30. Does anyone know anything about this SC300?
  31. Should've could've would've.... regreting your turbo route??
  32. Alternative to hood pins?
  33. Fuel Injector Cleaner - 400mi per tank?!
  34. taking out the chrome trim
  35. Update: SC restoration
  36. Flyest 97 SC4 EVER!
  37. She ain't perfect, but she's mine!!
  38. Got my chrome is350 mounted on my car.
  39. Sc300 Debate! What To Do
  40. neutral safety switch
  41. new pics of the SC
  42. My Mishimoto Radiator Experience
  43. I need to change my timing belt. Guidance please..
  44. exhaust from 99 sc3 and 92 sc3 the same?
  45. New Pixs of my 97 Blk/Blk Sc300 6spd.
  46. buying parts
  47. Haven't posted pics of my car...here they are
  48. Electrical Problem
  49. where to get a 1jz?
  50. Castrol Syntec 0w30 European Formula Opinions?
  51. Smelly A/C 95 SC400
  52. Some strange electrical problems
  53. How do you like these wheels on a SC?
  54. A/c Light Blinking?
  55. SC400 Wont crank over by key, I need a expert!
  56. Stuck seat....temporary fix.
  57. sc400 auto into sc400
  58. name that part a/c part? valve on low side, right below abs unit?
  59. Chopping the top off a Sc400? Has it been done.
  60. Quick question on wheel spacers..
  61. SS line option for high pres steering hose
  62. Indepth exhaust question
  63. New euro Headlight assembly with LED's
  64. Help!!!
  65. something ive been working on.. swarovski crystals
  66. Automatic 1jz and 2jz guys!!!
  67. How Accurate is our MPG"real-time" gauge vs Scangauge?
  68. Are SC's vanishing in your area?
  69. SC400 fails inspection
  70. Im buying a turbo....
  71. Supercharged SC400 - video
  72. Need some SC400 AC help
  73. AC not blowing cold air suggestions?
  74. loose braided hose in engine compartment
  75. which brand cf hood vis or seibon
  76. quick question!
  77. sc300 boil over but not overheating [long]
  78. 98 SC300 and SAFC II, Please verify, and help please.....
  79. question about tires w/ 17" wheel
  80. Labor question on solenoid replacement.
  81. Transmission fluid change SC400?
  82. I need opinions !!!
  83. 4 Chimes when Exiting Car? Headlights not on, key out of ignition, etc....
  84. Pics of my driveway yesterday....
  85. Question about foglights
  86. Contemplating Selling ... Price Request
  87. Transmission solenoid placement
  88. Sway bar bolt broke.... what now?
  89. some bad pics of my new ride
  90. Pix of new rims/tires...^-^
  91. PLEASE help identify this sound.
  92. Black on Black Spray and Wheels that is!
  93. Soooo i went and took a look at the 1jz....
  94. What did I just break?
  95. Ok This Is What I Want From An Sc!!
  96. Just installed new shocks and springs, have specific questions.
  97. black sc400
  98. Magazine Photoshoot
  99. Noob Question about Shocks and Struts
  100. Ignition switch wont release key!!!!!!!!!!!!
  101. Seibon CF oem hood???
  102. air intake help!
  103. is300 wheels w/ 215/40/17 ???
  104. My turn: a few pics of my clear headlamp + halo mod
  105. Cam timing (Searched)
  106. 1JZGTE VVTI Swap info needed... Searched everything
  107. OK guys Yay or NAY?
  108. Sc300 future buyer
  109. Power steering pump replaced 3x (searched)
  110. sc300 towing question.
  111. Tein CST damper settings
  112. New to this forum..
  113. 1JZ 2JZ oil pan
  114. What would you do if you were an SC buyer?
  115. light hesitation on 400
  116. Quick help! Where is the second HORN?
  117. clips of my 1jz sc
  118. 2jz-ge performance
  119. Magnaflow 14814 exhaust fitment
  120. Need Help With Gauges
  121. Help me decide on some 18's
  122. Fitment question?
  123. please help! im going to the track tom. 1jz no boost at WOT!
  124. widebody sc from overseas?
  125. need help with code 25!!
  126. Another Swapped Project
  127. O2 Sensor, Code 27?
  128. tt springs
  129. 1997 Check Engine Light - Trouble Codes - Help??
  130. Airbag light on, searched to no avail
  131. Gas prices makes people go CRAZY!!!!
  132. Apexi SAFC settings on 1j 1jz motor
  133. Suggestion on OEM Front Lip
  134. Supra MKIV sway bars in a SC
  135. Weird noise coming from rear when gas pedal is pushed....
  136. Any one see this SC before
  137. Tips for buying jdm engines
  138. Do S2000 seats really bolt into SC?
  139. Will Supra BBK clear these rims?
  140. Custom Drag 4WD SC300 (Soarer)
  141. Does anyone know what SC means?
  142. New SC300 owner...2 questions ^-^
  143. wheel pic
  144. got my clutch today!
  145. Are thes SC wheels>
  146. Fuel pump hanger, forr SCs
  147. is this hose suposed to be like this?
  148. Body
  149. 1JZ Swap Problems Need HELP!
  150. 5spd. NA SC300!!! let me know what you think:) Merged
  151. My first SC. The intro, FINALLY!
  152. would appreciate some info and help:) on my new sc300
  153. auto to 5-speed help???
  154. I Need Opinions!!!
  155. exhaust
  156. a little new
  157. Weds Kranze Borphes or Work Rezax II
  158. Mystery plug A/C = no power
  159. i love ghetto SC paint jobs
  160. You be the Judge.. (healight cleaning product)
  161. Well Hello! (56k a.o.k.)
  162. About to kill my car!! - WILL NOT START AGAIN! ECU Issue!
  163. Just messed up my front OEM lip..
  164. intake help
  165. Thank you SC forum
  166. CEL Code 13
  167. Belement's SC300 NA-T Build
  168. what happened to my car?
  169. Is This a Fair Price?
  170. Newbie Here
  171. Quick question on gauge cluster
  172. sc300 shift solenoids.
  173. Dead temp guage
  174. Cylinder numbers for SC300
  175. The uglist SC4 I have ever seen
  176. New Lexus owner.
  177. 1j Fuel regulator replacement What size threads? afpr
  178. chaser engine in a sc300???
  179. Very intense interior cleaning
  180. HAY GUYZ! Should I shave my high beams?? Pics included for ultimate reference!
  181. headlight moisture is killing me!!!
  182. is NA 5SPD SWAP SAME AS 6 SPEED
  183. Bad Cluch?
  184. New paint: Imola red tons-o-pics
  185. Took a trip and got back with a burnt clutch
  186. Pics of my latest SC - Renaissance Red SC400
  187. Head light removal
  188. Is300 headers for sc300
  189. took some pics!!
  190. oil pressure on a sc300?
  191. and I was told it couldnt be fixed...door mechanism arm
  192. Fixed my sputtering and stalling at idle!
  193. valve cover gasket
  194. clutch help
  195. hello and question
  196. Another Brake Noise Thread...
  197. Let me know what you think I'm thinking of changing my rims
  198. sc430 rims on sc300??
  199. ebay link deleted (ignore)
  200. BIG wiring issue - gauge cluster not lighting up.
  201. HHO Generation
  202. door panel material?
  203. power steering bearing noise? (not typical PS noise)
  204. gauges stopped working [Long]
  205. Any easy way to make cigarette lighter always on?
  206. 1jz fuel cut. How do I get rid of it?
  207. Drift Accident Need HELP Removing The Quarter Panel
  208. 97 Front Bumper ?
  209. Power Steering Seal issue
  210. Only! Reply If You Have Done A 1/2jzgte Swap
  211. I don't feel like driving in the Summer.
  212. Hit and Run ...but..
  213. will a is300 ac compressor work with my 1992 sc300?
  214. SC4Coupe's ride 1st time pics
  215. motors from driftmotion
  216. Spark Plug Gap Question
  217. Another SC300 gone!
  218. Road Racing Anyone?
  219. Check out a review of the Nitto Invo [video]
  220. Couple of questions regarding a motor swap
  221. new to cl here some pics
  222. Susp. Gurus, an alignment mystery
  223. Any ideas about this 7mgte clutch pedal?
  224. Got some new drift wheels (pics are on the bigger side)
  225. 95 SC300 Automatic: Engine miss, a little help please.
  226. My SC400 Tranny is leaking so I bought a new one. NOW THS
  227. Another Gixxer-Drew Bilstein Hypercoil Review
  228. spark plug wiress tovota vs lexus
  229. newbie LOL
  230. Crazy story.
  231. Ignition issue!! Need help with part name
  232. Bird vandals
  233. help with 97+ conversion
  234. GTE swapped dudes, what resistor for coolant temp?
  235. Toyota or Lexus Diagnostics
  236. check engine light on...
  237. Power Steering pulley
  238. Cleaned up the SC300
  239. a/c not wroking blakcout on a.c control
  240. misc clutch install parts
  241. That Sunken Picture?!? Anyone have it?
  242. Removing Door Piece
  243. I guess all good things must come to an end... 1 last pic before she goes
  244. Oil Lines?
  245. Want to see my car? 56k safe
  246. 1st time pic whoring 56k go away
  247. got a carfax and have questions...
  248. What's my car worth?
  249. Older - Newer SC400 Suspension and Brakes?
  250. Slave cylinder issues
