Quick question about the power steering pump
Old Jan 31, 2003 | 08:37 PM
ChrisSC300's Avatar
ChrisSC300
Default Quick question about the power steering pump
Ok, i think its about that time to replace the power steering pump. After about 10min of driving the steering gets pretty rough and makes a whining sound when i turn. My question is what parts do i need to corect the problem, do i just need the pump? I went to partsdirect.com and they sell a pump. I was just wondering if this was all i need. Thanks
Old Jan 31, 2003 | 09:50 PM
strongsail's Avatar
strongsail
is the outside of the pump wet and grimy? The major problem with the pump is leaks - if it has been leaking & is low on fluid, it can ingest air and will act wierd, groans, rough spots, blah blah. Check your fluid level, top it up if it's low, run the wheel stop-to-stop a few times, check level again, it may improve how it feels, but if it's leaking you gotta fix it or bye bye alternator when it gets soaked with atf - - you can get an oem kit to rebuild the pump, but the rebuild can fail (I know) so make sure the rebuilder knows his *** from a hot rock - - or bite the bullet & buy a new one, $455 oem list from the dealer...
Old Feb 1, 2003 | 02:04 PM
RacingLexusBoi's Avatar
RacingLexusBoi
i had the same problem a while back and it made werid noises every tym i completly turn in 1 direction. I found out that it leaked a lot every tym i turned fully. After i replaced it, it stop, but you should try to buy the stop leak power steering formula 1st to make sure.
Old Feb 2, 2003 | 12:16 PM
ChrisSC300's Avatar
ChrisSC300
What is the stop leak power steering formula??? I have never heard of it. What does it do and where can i pick some up. Thanks. I have to wait untill my tax return gets here before i can fix anything so i am will to try what ever it takes untill then.
Old Feb 2, 2003 | 03:54 PM
strongsail's Avatar
strongsail
you can't buy a good mechanic that comes in a can - -
Old Feb 3, 2003 | 08:30 PM
RacingLexusBoi
True strongsail, but it doesnt hurt to try.
The stop leak item should come in lots of auto store like pepboys and autozone.
Old Feb 3, 2003 | 09:17 PM
ChrisSC300's Avatar
ChrisSC300
RacingLexusBoi, was your problem just the pump. I am trying to get all the parts i need before i take it to my mechanic. Just Curious, thanks.
Old Feb 4, 2003 | 01:24 PM
RacingLexusBoi
yea, once i replaced it, it stopped leaking but there is still a whining noise when i turn but not as loud now.
Old Feb 4, 2003 | 06:06 PM
FLex's Avatar
FLex
I am in the process of replacing the PS pump. I found 3 of the 4 bolts/nut but cannot find the last one. Do I need to remove the alternator to reach it?
Tmhender82
Feb 3, 2026 12:37 AM
rick1987
Sep 6, 2015 07:05 PM
worldforgo
Feb 4, 2012 09:47 PM
dubstar
IS - 1st Gen (2001-2005)
Jun 17, 2011 04:29 PM
