Painting Caliper's
Old Jan 10, 2003 | 06:09 PM
sc4cmf's Avatar
sc4cmf
Default Painting Caliper's
Does anyone have any advice on painting my calipers. They have the traditional rusty look, and i'm not likein it one bit. How would I go about painting them? Is it O.K. to?, what color would look the best? ect. The car is blk w/ gld pkg Thanks -
Old Jan 10, 2003 | 09:07 PM
pcmw's Avatar
pcmw
Tape it off, clean with a can of brakleen, and then shoot them with any high temp paint. No need for that expensive folia-tec stuff.
MW
Old Jan 10, 2003 | 10:40 PM
PERRYinLA's Avatar
PERRYinLA
Since you say they are rusty, be sure to wire-brush them before painting, too. More details at https://www.clublexus.com/forums/sho...threadid=45272
MW's right- Pep Boy's "Hot Paint", at less than $5 a can, works fine. Observeth:
Old Jan 11, 2003 | 02:14 AM
lex400sc's Avatar
lex400sc
Watch your *** with aresol overspray. You know that cloud of vapors that drifts around after you shoot the paint? That's flying paint vapors! If you're not careful you'll find your SC's body with a nice coat of coarse black/silver/red engine paint. You can remove the overspray with claybar and elbow grease of course, but claybarring every last inch of an entire car is a long and tedious process. I notice a lot of people paint the calipers with the brakes and shims still installed. I'd shoot the paint with all of that removed from the caliper. Then put them back in after the paint dries. Make sure you shoot a few coats of paint on your calipers so the color stays rich and deep and won't fade out. I paint the brake drums too because those are pretty ugly looking as well.
Old Jan 11, 2003 | 02:33 AM
wmulli's Avatar
wmulli
The one advantage of the Folio-Tec paint is that you get a nice smooth surface when you're finished. With the spray paint, you can still see the bumps in the casting.
Just my $0.02...
Old Jan 11, 2003 | 03:18 AM
pcmw's Avatar
pcmw
Guys,
If you want to avoid overspray, one old hot rod trick is use a thick coat or carnuba paste wax on the car before painting. Then after the paint drys, you put the car back together, you remove the wax. Now you have killed two birds with one stone.
MW
Old Jan 11, 2003 | 03:05 PM
sc4cmf's Avatar
sc4cmf
Default Painting Calipers
Thanks guys for all your advice!!!!!! I would paint the calipers after removing the brake pads but im not sure how and it seems it bit complicated. We will see though, thanks again-
Old Jan 11, 2003 | 03:18 PM
pcmw's Avatar
pcmw
sc4cmf,
To pull the pads, it takes 5 secs. There is a bolt on the top side of the caliper, 14mm. Remove the one, and then swing open the center caliper piece like a door. Release the pads that are held in with just tension.. mark them so that you know where they go back, and you are set.
MW
Old Jan 29, 2003 | 10:03 PM
Lex Luthor's Avatar
Lex Luthor
smoooth, not a casting bump in sight...
Attached Thumbnails Painting Caliper's-compressed-front-brakes-red-calipers-just-painted.jpg
Old Jan 30, 2003 | 12:24 AM
lex400sc's Avatar
lex400sc
Hey Lex, how'd you do that? Slick!
Old Jan 30, 2003 | 01:06 AM
wmulli's Avatar
wmulli
Default smooth calipers
It's the Folio Tec paint. The stuff is awesome!
Old Jan 30, 2003 | 03:38 AM
wmulli's Avatar
wmulli
Default Caliper stickers
The logo on the caliper came from (edit) some banned place (edit) I found them through eBay, but now they sell direct. I think it's a real nice touch If you put the sticker on *just* before the paint hardens, it looks like it was part of the casting.
Old Jan 30, 2003 | 04:19 AM
hiyabrad's Avatar
hiyabrad
LEX - How did you do the logo?
IceIridium
IS F (2008-2014)
21
May 18, 2012 05:45 PM
2JZSteven
IS - 1st Gen (2001-2005)
18
Oct 27, 2010 01:40 PM
deejay
Feb 8, 2010 10:05 AM
sc30015
Sep 26, 2007 08:42 PM
spinteews
RX - 1st Gen (1999-2003)
May 9, 2002 06:59 PM
