SC400 tail light question
Old Jan 12, 2003 | 02:15 AM
Bentley1's Avatar
Bentley1
Question SC400 tail light question
I have a 93 SC400.
Should the entire red strip on the tail light be lit up when the lights are on? The whole strip lights up when the brakes are applied, but otherwise just the outside edge is lit up.
(see pics below)
Thanks
Old Jan 12, 2003 | 03:47 AM
Grimpy's Avatar
Grimpy
I think thats regular. Mine were like that also.. Unless both sides were blown when I bought the car... LoL
Old Jan 12, 2003 | 04:09 AM
Bentley1's Avatar
Bentley1
Looks like you upgraded to the newer style tail lights. Do they light up all the way across?
Old Jan 12, 2003 | 10:20 AM
legendary's Avatar
legendary
Like ethe Bimmers, Benzes etc., the SC'sall have a characteristic like this on all models [92-00]
The outer lights stay on when the parking lights are on, when brakes are depressed, they all light up. What you have is normal.
On the 95-00 models, the top strip is lit, and the lower middle lights come on when the brake is depressed [parking lights on]
Old Jan 12, 2003 | 11:26 AM
sxylxy's Avatar
sxylxy
Hey sc400, when you did the conversion, did your lights blink real fast too? I know this is because there is one less bulb, but how do we go about fixing it. I was thinking of putting a resistor in to either raise the power flow or lower it, in order to trick it into thinking there's one more bulb then there actually is. Let me know what you did to overcome this prob, as of right now, it looks real rice with the siezure-like blinking, thanks
Old Jan 12, 2003 | 05:11 PM
gadgetSC's Avatar
gadgetSC
You might want to try using swapping the Turn Signal Flasher Relay from the year of the lights your using. There is a resistor inside of it that should be different for each application.
gadgetSC
Old Jan 12, 2003 | 07:19 PM
Grimpy's Avatar
Grimpy
Yeah, my signals blink like they are on crack. I don't really mind so I haven't done anything about it.
oh, and the entire top portion lights up for my tail light.
Old Jan 12, 2003 | 09:01 PM
Taka's Avatar
Taka
Default Re: SC400 tail light question
Originally posted by Bentley1
I have a 93 SC400.
Thanks for this question with picture, I have wanted to ask same question. Is it possible to modify on those inner bulbs to be on all the time?
mzxqgx
GX - 1st Gen (2003-2009)
Feb 20, 2020 07:09 PM
ZantZ
Oct 10, 2018 10:48 AM
geoprz
25
Sep 22, 2013 07:53 AM
Saiji
Sep 18, 2008 12:48 PM
brooklynES
Jul 9, 2008 09:21 AM
