- The Drop
- How much can I get for my SC?
- exhuast help
- Side markers
- Straight exhaust
- 19 inch enkeis
- Poll - what should I do?
- wood trim problem
- FInally on the road. Some pics to look at..
- TT transmission is dead
- Removing Door Lock Mechanism
- Trunk release stopped working..
- What 1st Suspension Mod did you notice biggest difference?
- My mini soarer (choro q) collection
- Pics of new my 97 SC, 5spd...
- A/C Only coming out of one Vent
- trunk release has a mind of it's own!
- What do i need to do next???
- Started fiberglassing today for my sub!!!
- tein s techs
- Who has shop manual for 93 SC400?
- lower controll arm bushing
- gs motor in sc4???
- anyone going to the SILV meet?
- 19" Rims, Brakes, Tires suggestions
- Got Bored, New Pics of the Lex!
- Where can i find these??
- wow, is this some kind of record
- Which griffen to use
- tail light problem!
- Close up of the hinge of a lambo door SC (plus other pics)
- Built 2JZ-Ge?
- Electronic Steering wheel problem
- A/C Problem...
- New 2 the board and pulling a swap
- What do I need to change my timing belt?
- 10.18 ET with an SP71 Q-trim!!!
- orders of mod
- Engine Mounts in SC 300 - What all do I need?
- Anyone got tein ss coilovers?
- transmisiion vibration?
- big problem need advice quick- alternator and battery is dead
- hesitation
- finally got my jdm 2jzgtte in!!!!!
- MLS Eye Candy
- going Carbon Fiber crazy!!
- new paint job next week for 400$!!!
- CalChrome used my Supra TT wheels on their website!
- Hks Vpc
- The GHOSTS are baaaaack.....
- Headlight ?? Need quick reply if possible
- clear tail lights?
- I got my SC
- Picked up my "New to me" SC 300 5spd
- Engine CEL Code 28
- Pics n Vids 11 SC's racing, V8's and turbos
- Need Advice on buying 97 Sc300 5spd..
- Disassembling Sideview Mirrors
- Lextech needles replacement
- Location of the power steering ECU in SC400
- Replacement Clutches
- V8 manual & V8 turbo!
- Gm Dis
- my 2 tone seats from Groupbuy
- clear bumper side markers
- Questions about Daizen Sway Bars?
- Turbo Kit Installed...
- Is the 2jz-ge an interference engine?
- cat gasket?~!~!?
- ? about injectors
- squeak squeak when turning steering wheel
- Climate control LCD
- SC300 Weight Reduction Worksheet
- 802rwhp!!!!!!!
- PHR Alternator for sale
- tune up
- Yakuza Photos
- 97 Conversion Q's
- RX330 rims on SC
- Problems with traction control light and emergency brake light
- anybody know where to get soarer shift linkage??
- SC Veilside Executive spoiler pics: GOT ANY??
- The end of the road for me
- magnaflow 14829
- SC400 Tranny!!
- car hesitates when accelerating hard.
- Look what came in the mail.:D
- Trailer Hitch on Sc400 Need Help!
- Removing map light/sunroof control panel
- sc300 radiator fit in sc400?
- Some pics from EOS3
- Latest "Project SC" cluster in the works
- whoo hoo my stock sc300
- Just bought an SC
- I actually have some info to contribute. RE: power windows and door lock problems
- SC400 vs. SC300 5spd
- Whats the best turbo for street and Drag?
- A short story, a thanks, and a question
- 92 SC300 5-spd...Vibration
- My turn for some teaser pics...
- auto tilt wheel failure
- got myself a pair of the jdm side makers
- replace front speakers today...
- Power Plan... The Best Path?
- I got rocked
- how many cranks or turns does it take before your engine starts in teh cold?
- I hate CALI, they won't do my exhaust
- problem with magnaflows
- Belt pulley came OFF while I was driving?
- Anyone want pictures of their car on my company's new website?
- Need a quick response: removing door panel.
- Finally some pics!
- JIC bodykit question
- SC300 Cats - Pre & Main?
- Misfire
- Carbon fiber hood/trunk
- I got 1st place at NOPI for sc300 conservative
- Trac off light came on.
- electric fans low budget setup???
- when does your gas light come on?
- Since everbody else is showing off their kit and new paint, here's mine!
- When does it end...
- Hit and Run!!
- Newbie questions on 97+ conversion
- SC300 auto to Stick swap
- AT what throttle setting does the 97 sc 300 change from open loop to closed loop?
- Illuminas With Tein H Springs?
- i'm stomped
- SC3 Parts interchangealbe with Supra
- Overheating Problem
- Replaced my trunk shocks today, & started sub enclosure fabbing
- Carbon fiber door trim, What do you think ?
- Supra Shocks & Struts
- Finally got my new Iforged Rims
- The Ghosts are gone!!!
- Finally my bodykit is on!
- overheating (but recent flush/fill)
- Friction Plate
- Differences in body kits
- LLS releases FULL CATHODE CLUSTERS for the SC
- Damn you guys!
- Lextech releases *illuminated interior panel* for the SC
- auto to getrag 6 speed
- What are your mods for your SC in the fall/winter?
- Engine Management Options, and fuel setup ?
- Need help with misfire!!!
- Removing Speedo Cluster
- Question to O.L.T
- Opinions on Suspension upgrades please
- Anyone here with a 96 or newer done the ECU upgrade?
- I got 3rd place at NOPI for sc300 conservative
- my car's power was revived!!
- what else to change???
- Updated pic of my 97 SC400
- sc differences; 92-00
- I won 2nd Place at NOPI with the sc3!!!!!
- Tein CS setup...
- automatic shift knob
- SAFC Fried?
- Back from the body shop.
- SC vs Supra Parts
- Stiffer rate.... Stock Height??????
- Need Suggestion on Timing Belt Types
- is300 on supra or ls calipers
- Armrests
- Soarer sites?
- One of Japans fastest "shop" soarers is for sale-
- Car won't start in the morning
- Speedo correction
- Car died while driving. Please advise.
- sc300 exhaust
- Finally found a SC. Now have questions.
- Need some opinions or rims.
- Show Car ????
- Punching Cat
- Post exhaust install 600 mile trip
- Hello... New member here!
- Back-up camera on an SC
- Compression in motor -> Vibration = rebuild?
- going next step with daizen camber kit issue...
- Magnaflow exhaust
- No more generic ground wire upgrades.
- gas leak
- Leatherseats.com install - missing lifting wires. What do did you do?
- In search of a Cusco strut bar part #.
- 2004 SC entries for the Summer photography contest!
- NA-T: which one is more reliable?
- Water Leak into spare tire well
- Help with bodyshop problems
- Air Bag Light Stays On!!!
- Sad Day Yesterday !!
- Does the SC4 have slots for clutch cyl like the SC3? 5 spd
- Lighted Guages
- (iat) Intake Air Temperature
- 97-00 Wald body kit on...
- need help! tell me what u think
- Post pics of the nicest SC400 you know.
- LSD Swap Questions
- climate contol not working
- Acquired 94 Auto Supra TT diff, now I have some q's
- 4 days later - another problem!!
- Wheel play?
- any one have tein flex?
- Need info on 1jz swap
- front fender removal
- front supra sway bar end links fit sc?
- Who's driven the most>?
- easiest way to get acc power in the glovebox?
- Replaced seat trim garnish?
- something is draining my battery...
- Weird loud FAN noise at idle..what the heck?
- And so it begins....(Carputer)
- both doors get wet inside by the carpet piece
- Pics of Monet with new shoes
- those with swaps... do you still have AC?
- For those with 1jz's
- kei office coilovers?
- anyone with pillowball mounts
- I want one of these
- GTE Swap Progress
- (another) Pretty Pretty Pink SC
- knocking noise
- No Love for the SC?
- car starting weak
- Install new leather seats
- Keep blowing fuses - DAMN!!!!
- toyomoto ?
- New bushings or new arms
- Driver Side Window Control
- anyone try the espelir active gt spring?
- Contact! Tire and inner fender liner
- Optima Yellow Batteries
- Vote Soarer!
- Ignition mods
- HELP! Sunroof left open overnight
- What is my sc worth?
- why is my car so loud?
- 19 inch rims
- got my tire slashed.
- Fuel Economy : Summer 04
- Teaser pic 3....the final chapter
- Another Head Question
- Silvania Silverstar 9005 conversion
- Newbie with tail light and rear bumper question
- rev limit? speed limiter in our cars?
- oh man... more noise...
- front pipe
- JDM question????????
- SC 92-95 fog lights DIY or are there OEM versions
- Door Sill Wanted~
