Welding Mufflers? Price???
Old Jan 27, 2003 | 10:31 PM
johnsc400's Avatar
johnsc400
Default Welding Mufflers? Price???
I just got two universal mufflers and need to get them welded on. Whats about the average price to get this done from a welding shop so I don't get ripped off?
Also anyone know any good shops in San Diego California? thanks
Old Jan 27, 2003 | 11:04 PM
ChronoJ1's Avatar
ChronoJ1
Around 100 bucks for new 2.5" pipes beyond the two cats and welding them to the mufflers.
Old Jan 28, 2003 | 01:09 AM
SC4Hundred's Avatar
SC4Hundred
It should be about $20-30 without the new pipes.
I just done that for my other car and the shop charged me $20, I thought it was a bit much.
Old Jan 28, 2003 | 02:30 AM
hiyabrad's Avatar
hiyabrad
$20 sounds really cheap. I just had two magnaflows installed - just replaced the factory mufflers, for $60.
Shops (at least in CA) will not do anything in front of the one center CAT in the middle of the exhaust system. They will repipe from behind that CAT if you want.
I installed the two Magnaflows on Friday. I have to tell you that it made almost NO sound difference whatsoever. So today I had the two resonators removed and it sounds pretty nice now!!!!
Old Jan 28, 2003 | 05:07 AM
carnal_c30's Avatar
carnal_c30
look for American Muffler
its near Pann Auto around Miramar rd or something
I've heard good reviews of the place but personally I cant heap them with praise
they told me they couldnt take out my 02 sensor so I'd have to buy a new one
so I did... but I also took the car to another shop and they did it with no problem (other shop was Exhaust Works in Belmont CA)
Old Jan 28, 2003 | 09:10 AM
Keith13b's Avatar
Keith13b
25 Year Member
In Orlando, Magnaflos installed are 100$ ea. and that includes the muffler. Installing a customer muffler is 20-30$ each. Replacing more pipe will be a little extra, but not much.
Old Jan 28, 2003 | 12:32 PM
pcmw's Avatar
pcmw
hiyabrad,
That isn't true. lex400sc has no rear sections, as well as several other california members. I think your one experience with one shop has led you to make a gross generalization.
MW
Old Jan 28, 2003 | 12:48 PM
Lvangundy
Guest
Posts: n/a
hiyabrad -
The center piece is not a catalytic converter. It is a resonator. there are only 2 cats on the SC400/LS400 cars. I think all other Lexus fall under the same idea.
In fact - I have all the mufflers still in my trunk (not saving any weight am i? hah) and I'll take some pics to compare.
I had all 3 of my resonators removed on my LS and kept the stock cats and rear mufflers. Here's a pic. The mid pipe is 3" and the rest is 2 3/4" ( or 2 1/2" forgot..)
Old Jan 28, 2003 | 02:35 PM
hiyabrad's Avatar
hiyabrad
Wow, is that true about the middle resonator? It sure looks exactly like a CAT and the muffler shop told me it was a CAT.
So if that is true, than I can run an x-pipe behind the two cats and then run straight pipe back to my Magnaflows.
Does anyone know of a good shop in the San Fernando Valley, West LA or LA area that knows what they are talking about?
Old Feb 6, 2003 | 10:39 AM
hiyabrad's Avatar
hiyabrad
Sorry to burst your bubble guys, but the SC400 (and I am sure the LS400) has three Cats. Two mains off the headers and one secondary behind the Y. I just got the repair manuals for my '96 and that what is says.
The posted pic has the secondary removed behind the Y.
The question is, will that car pass CA smog check?
Old Feb 6, 2003 | 06:58 PM
808state's Avatar
808state
from pete's homepage:
http://planetsoarer.com/cats/cats.htm
they call our exhaust system TWC(at least for the 97)... if i'm not mistaken, it stands for, three way cat...
Old Feb 7, 2003 | 05:18 AM
Keith13b's Avatar
Keith13b
25 Year Member
I can't speak for later models or Ca models, but on a 92, it has 2 cats and 3 resonators. I also have the workshop manual to confirm.
This is obvious by the location of the O2 sensors. If its a cat, it will have an O2 sensor after it.
Upon opening mine up, it was a straight through design, just like a front muffler/resonator. Again, this is for a Non CA 92 model.
Keith
Old Feb 7, 2003 | 09:57 AM
hiyabrad's Avatar
hiyabrad
Does anyone know a good muffler shop in the Los Angeles area?
Old Feb 7, 2003 | 12:45 PM
V8RWDHP's Avatar
V8RWDHP
The owners manual for my 96' also calls it a three way cat system and points to the two obvious cats and the so-called resonator.
Old Feb 7, 2003 | 01:13 PM
Bean's Avatar
Bean
CL Folding 1,000,000
that middle resonator IS a cat
the cats coming off the headers are precats; made for startup emissions testing
as for adding 2.5" dual pipe to the main cat, here you're looking at ~$120...
don't waste your damn money and just have them weld the mufflers up; replace all of the pipe with bigger pipe... else its pointless; you won't make any power increases; just sound changes
