- Oil light keeps turning on but my oil dipstick shows full
- "Tink Tink" noise coming from exhaust?
- map sensor ?
- cusco test fit for front strut bar sc400
- SC400 Crank Shaft Position Sensor. WHERE?????
- A. C. delete
- Can Someone Tell Me What this Is Called?
- Starts dies, starts dies...
- Request: 1jz turbo removal diy
- HELP - Boost Controller / Boost Gauge Vacuum Routing
- Valve Cover Gaskets & EGR Cleaning Tips
- SC300 - Air/Water IC - has it been done yet?
- 500whp and stock drive shaft?
- 1996 SC300 2JZGTE vvt-i auto swap completed...Kind of
- Need a suggestion for a clutch
- SC issues.
- 92 SC400 cuts off when you out it in gear
- Am I running to lean on the 1jz?
- 5k limiter issue single 1j fic
- Timing Issue?
- Balancing 1UZ Rotating Assembly
- SC400 bro's with the 5 speed or Getrag swap...
- I have a bad oil leak on front of my engine
- Transmission
- need help Slow coolant leak
- What does the TRAC light mean?
- SC300/400 center console 2nd 12V DC power & remote aux jack DIY
- looking for a 92sc300 fanshroud for sale... ANYone??
- Dallas jdm motors?
- Low idle. Not vaccum leak, not IACV.
- 99 sc300 auto to 5spd with w58 ???? help !!!
- Flywheel suggestions??
- w58 question before i get my 1j
- Whats needed to do a Na-t setup
- Question for Boosted 1uzfe peeps
- SC300 engine wiring diagram!
- ecu pin out help!
- How much did you pay for your custom exhaust?
- SC300 auto to manual swap Q&A
- New to the car.
- Na-T
- SC400 intermittent starting issues...
- Replaceing Gear box bushing in 5 speed?
- Head Gasket Question
- sc400 exhaust hks
- So my sc400 is turd slow
- SC400 hesitation problem i found (wanted to share )
- what do i need to achieve 600whp 2jz vvti? please help
- Doing some work on my 2JZ-GTE SC400
- Horrible gas mileage 1jz
- ITB vs Turbo
- 1jzgte vvti MAF?
- Any 1jz big single 1/4 times
- have any of you guys made a bfi?
- is300 supercharger on an sc300?
- SC300 Manny Tran Build Thread
- Plz need help with 2jzgte swap
- Highest Injector on stock 2j
- can I use this Metal head gasket
- rad options
- Can you add stock Supra Twins to a 2J2-GE?
- Please help!!! (Really means) Crank pulley bolt missing
- Walbro on a SC400
- GReddy E-Manage Ulitimate PnP Harness?
- Part ID request
- gte swapped car, stock idle?
- Anyone done a high flow single ex. on sc4 lately?
- 1jz/2jzgte and V6 Truck flywheel/The same?
- My New Exhaust for the SC400
- Engine Swap: transmission connector issue
- Intermittent Misfire
- Test only smog -- thanks Cali
- Were did you mount your gauges? Pictures?
- Car shuts off. When A/C is running.
- smoke from passengerside firewall
- Is this mechanic lying to me?
- anyone have A.C. eliminator pulley advice
- Radio Fuse Keeps Blowing
- New member /air conditioning problem
- Tweak'd Performance 2JZ-GTE SC300 Engine swap
- 1.5jz auto transmission?
- buurning too much fuel!!!
- 92 SC300 Speedometer/Odometer/Window Issue, PLEASE HELP!!!
- Removing Engine and Trans
- IACV, TPS, Vacuum Leak....or other?
- Car choking some days, others fine..TPS?
- 1jz/2jz alternator mounting
- getting welded!
- Top speed exhaust SC300 only videos/soundclips
- intake port spacing and bolt pattern
- Please help me - SC400 runs very poorly
- Clutch on floor
- diesel turbo on a 1jz
- 98+ SC400 intake on older models?
- rough idle and almost stalling
- Electrical help
- GM LSx Engine Mounts for Lexus SC300 / SC400. Check It Out!
- Power Steering Goes Out
- Climate Control lighting and cigarette lighter
- pt6265 1jz sc3 on AEM FIC
- Nakamichi stock system power output
- SC400 Exhaust Opinions
- Megasquirt for 1UZ
- Does anyone have or know where I can purchase
- SC300 - no start?? Need help
- JDM 2JZGTE to USDM twin turbo conversion....
- Speedo & RPM not working sc400
- trans. fluid advice
- SC3 Valve Cover flaking inside
- DIY raditor removal
- SC300 Vibrant Exhaust
- My 1jz has AC!
- SC rear jacking points?
- looking for a used 94 2jz
- trac light flashing, cel on code P0116
- 2jz-ge Loss of power under 4kRPM
- mk3 supra clutch/brake-sc400???
- Which alternator for jdm gte swap?
- help ID-ing some camshafts
- injector size ok..?
- Transmission will not move in reverse
- horse power
- SC400 Temperature Gauge pegged at H - Help!
- i need help deciding
- speed cut defender and Turbo timer
- 1UZFE problem
- Prepaid maintenance good value?
- any help would be much app...
- SC300 not getting power?!
- Weepy
- R154 SINGLE disc clutch
- Fuel inlet hose gaskets?
- Cv axles???
- Is 2jz crank forged or cast
- Planning on goin single..
- 1994 SC300 with random stalling; fuel pump ECU?
- have a question
- 671 blown methanol Soarer
- Trans test port thread diameter? (trans guage install)
- Oil Feed line question
- sc400 Tuning question
- sc400 oil change info
- Just installed new trans mount sc400
- auto tt diff questions
- Head Gasket
- W58 Tripod Shifter Extension
- What clutch for NA-T W58?
- Supporting mods for turbo upgrade
- confusion about my sc400
- performance parts sites
- Which intercooler and piping for JDM 2jzgte swap?
- Engine stand bolts for a 2jz?
- JDM 2JZGTE guys... what downpipe are you using?
- Compressor installed Brrr
- Which should I go?? Na-t vs 2jzgte swap
- Header Bolts
- single turbo questions.
- NA-T guys? step inside. oil line related
- CA Smog Assisntance CAP, VRRRM programs
- Finally going single turbo on my 1Jz!!!
- 1JZ A340E Wiring
- Definitive SC400 Header Question
- AC Compressor suction/discharge plate removal
- 1.5JZ Power loss-Bad Clutch or Bad Turbo?
- Question with EGR delete
- Help with jdm 2jzge swap
- Rebuilt r154 or buy another r154?
- Who's SC is this?
- 94 SC300 idle issues
- No power steering:-(
- Continuous beeping
- gte swap
- Is tranny fluid change necessary? If so which?
- Transmission questions
- Ecu questions.
- cooling sytem problem
- 92 sc300 electrical problem
- 1997 SC300 2JZ-GTE current swap step by step
- gte swap and camry throttle cable ??
- Sc300 fan blower stopped working!!
- CEL help needed
- 1uzfeswapkit.com
- 1JZ injector firing issue via Bigsticks....help!, out of ideas!!
- sc300 leaking oil
- 2jzge sensor next to the oil dipstick use ??anyone? pictures inside
- custom y
- Is this a good turbo set for a 2jz-ge?
- kll clutch noise
- V160 owners what clutch are you running?
- Is IMF still around?
- SC400 Reso Removal
- auto to v160questions
- SC300 aftermarket exaust? and light?
- Help, No power after trying to start
- 1995 Sc400 Radiator Questions
- SC400 A/C control panel problems
- Auto to manual tranny swap
- More starter problems
- Porsche Tips on Sc400??
- What kind of oil?
- Driftmotion Underdrive pulley kit....Reviews?Opinions?
- HELP, messed up electrical experiment
- Mixed Dex II with T-IV
- 1997 sc300
- T-iv atf
- car wont start after wiring harness relocation. Please Help!!!
- SC300 W58 swap VSS question
- Stumbling idle
- BW Matchbot
- Coolant dash light on, but level is normal. Any ideas?
- Pivot Voltage really work?
- 1992 Lexus SC300 AC
- Question on relocating catalytics on a 1uz
- How to make the tach work?
- Engine ECU
- My 1jz R154 problems
- mk3 supra pumpkin into a SC
- Anyone shim their automatic transmission actuators?
- ignition coil #1
- 1jz auto transmission won't go in to OD
- 1JZGTE SC300 Dr.Tweek wiring into SC400
- quantum auto spacer on w58, measurement for shims?
- Tranny question
- Evap Canister routing?
- new cams dont require new springs?
- 96+ OBDII CEL Fixes after Trans Swap
- Another O. L. T. DIY - In depth with the heater core control valve
- timging belt and water pump replacement price for sc400
- Removing a tight nut on a battery terminal?
- Megan axle backs
- trany fluid.
- starter slow to disengage when cold
- Driftmotion AEM harness
- soarer FSM!!!
- Starter single click when "cold"... contacts?
- aristo tranny into sc300
- SC400 A.C. delete
- Power Steering Hose replacement.....$64.99 from Autozone!!!
- 1jz auto ecu manual harness
- driftmotion.com power steering hose
- Engine is finally starting give up?
- Throttle Body ideas and flipping upside down
- Can't get my SC400 to run right? Help!
- Hydrogen injection?
- MAF dead? how do i know?
- Knock gauge (knocklite) installation
- DIY manual pedal swap thread/s?
- Starter Woe
- disdtributer help
