Climate Control lighting and cigarette lighter
Old 09-14-11, 01:55 PM
DONT SLEEP
DONT SLEEP's Avatar
Default Climate Control lighting and cigarette lighter
So I've done some searching on here, but I couldn't find anyone with the exact problem I'm having. After installing my head unit, I noticed that my climate control backlighting doesn't work. The lights for the buttons themselves work, but the lights for the LCD screen don't come on. Thank goodness the heater and A/C work, I just have to turn on the interior light to be able to see the LCD at night.
With this, I've also noticed my cigarette lighter doesn't work. Are these two related? Could the cigarette lighter fuse be related to the backlighting of this climate control panel? The other problems I've seen were similar to mine, except their entire A/C and heater system didn't work. My car is a 98 SC 300.
Old 09-17-11, 08:09 AM
DONT SLEEP
DONT SLEEP's Avatar
Any ideas? I just checked the CIG fuse in the kickpanel and it didn't look blown.
Old 09-17-11, 08:40 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Now replace the fuse that is blown.
Old 09-17-11, 11:43 AM
DONT SLEEP
DONT SLEEP's Avatar
What other fuse could it be? All those other ones looked like they had nothing to do with anything cigarette lighter / climate control related.
Old 09-18-11, 12:31 AM
CrazySC300
CrazySC300's Avatar
It's a blue 15 amp fuse right by the driver's side kick panel.
Old 09-18-11, 06:30 AM
DONT SLEEP
DONT SLEEP's Avatar
Yeah, the one that says CIG on the back of the fuse panel. I pulled and looked at it, and it wasn't blown. Any other fuses it could be?
It may be that I didn't plug the cigarette lighter back in after installing my head unit, but what could be the cause of the climate control backlighting not working. All the bulbs worked perfectly before, but now none of them light up.
Old 10-22-11, 09:50 AM
Ejsides36
Ejsides36's Avatar
hey i have the same problem with mine only mine wasnt caused by replacing the head unit it was not working since i bought it. checked the fuse and everything, possibly bad wiring?
Old 10-23-11, 03:12 PM
DONT SLEEP
DONT SLEEP's Avatar
Yeah, it's really weird. If you find out the cause, PM me.
Old 10-23-11, 08:19 PM
sc300Super
sc300Super's Avatar
I'm having same issue. My back light doesn't work on a/c and radio. Any ideas?
Old 10-24-11, 11:27 AM
ncSC300
ncSC300's Avatar
check all the fuses with a checker, I had the same issue it was a blown fuse.
Old 10-24-11, 12:32 PM
DONT SLEEP
DONT SLEEP's Avatar
Which fuse was it for you? And what did you use to test it?
Old 10-24-11, 05:47 PM
sc300Super
sc300Super's Avatar
you are awesome dude, it was fuse issue.
Old 10-24-11, 10:36 PM
durtysc300
durtysc300's Avatar
Had the same issue but i shorted the fuse. just change it or check the ground off the cig lighter
Old 10-25-11, 11:04 PM
myke441990
myke441990's Avatar
Alright guys, I'm having the same problem but another problem arises. I change the 15 amp fuse but it blows every time... What's causing this? Can I go to a 20 amp safely?
Old 10-26-11, 09:05 AM
2jznosht
2jznosht's Avatar
No the fuses blow as a fail safe to prevent you frying things. if the 15 is the correct amp then do not go to 20. Instead fix the problem causing the fuse to blow. its likely metal on metal contact because of the tabs in the lighter socket being bent...could be bare wires touching too
Quick Reply: Climate Control lighting and cigarette lighter
