- Intermittent Issue/Best Order to Perform Maintenance
- 97 sc300 minor repairs exhaust,steerwheel shakes, speedometer etc..
- harness splice is this normal
- sc300 OBD1 ECU question
- FI CNC Files
- 97 sc300 iacv wire colors
- Another cleaning maf thread
- Very long story short
- 1jz swap ecu options
- Greddy 3bar map sensor without EMU?
- W58 Driveshaft Question (R154 shaft possible? )
- Winter Transformation
- Oh Crap - Won't start after oil change
- Power Steering Line Question
- Car issue 1jz?
- Different OEM Throttle Bodies
- 97 Cluster disassembly/assemby help
- another weird issue please Help my daily
- Dual intank pump setup in SC300 tank
- To ARP rod studs or not to ARP?
- sc300 engine wiring diagram
- 1994 SC300 rough idle while cold
- AEM v2...question about IAt and Map sensor...
- relocating fuse box to the trunk
- MEGAN RACING axle-back exhaust for SC400?
- Loose cruise control or what?
- another 1.5jz question
- W58 Transmission rebuild Kits from ebay.com
- Dirty intake manifold?
- 97-SC300: My V160 6spd swap thread (TONS of pics)
- Fried sc300 ECU X3, Cause?
- 2jz-ge na-t 101
- Heater Problems AGAIN!!!
- SC400 Headers Group Buy - Last Day
- sc300 fuel injector replacement
- New Ecu But totally Different Problems than old one.
- CATS delete
- nitrous fuel tap question.
- Exhaust Sound
- which fuel management karman MAF na-t
- New exhaust setup question
- Another SC400 with A340e shift issues
- SC400 EGR Delete from Lextreme???
- Best HP add for 1998 SC400
- denso 1020 fuel pump ?????????????
- Need help - Engine change
- DIY with Pics: Cleaning the IACV-SC400
- Oil light.
- TT ecu on Na-t wont start!
- 1jz auto swap questions
- 1jz-gte vvti from MAF to MAP (mass air flow to manifold pressure) ??? conversion?
- coolant over flow bottle types and location recommendations for FMIC
- Mass airflow delete? Possible?
- Hard Start, Speedometer & Tachometer Doesn't work
- Sc400 auto swap
- intercooler pipeing.... need opinions
- sc300 exhaust question
- Gas Gauge
- Nitrous and Fuel Line
- SC430 3.26 Diff??
- Anyplace sell 1jz gasket sets anymore?
- sc400 95year diagnostic
- Alternator question
- 2jz-ge q45 toyota tps adapter?
- Rear Bulb Out Indicator ON...
- HELP, I have high NOX and cant pass CA smog
- Sound Proofing?
- Bad Cats overheat 96 sc400 (168000 mi)?
- buckwheats sc 300
- 93 SC 400 running bad
- Hose off heater control valve
- 99 sc won't start.
- Engine Bay Harness
- Wastegate options on 2jzge turbo manifold?!
- JDM ECU Piggyback Setups - post them up
- car suddenly running bad
- has anyone used seafoam to lower NOX levels
- Powder coated the rear diff today!
- SC 400 '95 Transmission Front flange
- 92 sc300 hard start help
- Clutch, ebay vs. jcwhitney any good?? help
- O2 sensor question
- SC400 probs
- 1JZGTE IACV Bypass?
- A/c delete serpentine belt part number?
- Unusually High Idle After Driving
- Precision 6365H or Precision 7068
- Automatic Transmission Fluid
- 1993 Sc300 Build
- '00' SC400 code P0121 $1750 for repair?
- OBX Headers for SC400. Who's going to be the Guinea Pig?
- maintance: breaks and rotors... gas tank pressure?
- Can I use evo 8 560cc injectors?
- ENGINE BLOCK Bolt Ears (holes) for Trans broken off
- help me identify injectors
- PCV Valve Replacement
- Fuel pump problem
- 1995 sc400 crossed battery terminals no power
- O/D Flashing DTC89: Need help removing code
- help! rpm goes really high when i start my SC400
- 1jz aeromotive fpr install help!!!
- Na-T Crank Seal Issues
- 92 sc300 tons of white smoke and now motor wont turn over WTF!?!?
- 1992 sc400 lack of power
- FFIM on auto sc300
- 1UZ Vs 06 BMW M Roadster
- Help SC400 overheating and boiling coolant!!!
- 2jzge spark cutting off at high rpm
- Just started my 2jzgte swap!
- Trans and motor mounts question
- Need help with my na-t sc300!!
- Seized spark plug
- 1jz aluminium piping leak
- Short and Simple.
- 1jz hydro fan options
- sc400 spectre 10.5inch intake
- Intake resonance chamber
- Power steering completely dead
- Car wont start, thinking its the starter.
- Throw out bearing spacer.
- Removed resonators. i am dissapoint.
- any 1jz vvti running tomei arms m8280 turbo?
- 1jz and emissions!
- 2jzgte power fc guys!
- is it safe to buy a 1jzgte ??????? need advice
- 2JZGTE head and intake manifold
- 1999 sc300 CEL code P0155
- 1992 SC400 failed smog in CA
- Starter gone bad, can i get to it without lifting the car?
- Coolant bleeder valve 92 sc 400
- Hx35 Holset Help
- Turbo UZ guys simple question.
- Few questions I have about future mods
- sc300 project help please!!
- what tranny would you go with and why?
- Wants to turn off when I complete stop.
- Plugs / wires / oil weight
- rear diff...
- Coolant Tank Sensor / reserve tank assy
- Howe Throwout Failure?
- swap help - ECU???
- What would cause my Fuel Pump to stay ON after I turn off the car?
- Won't start
- complete NA
- 2jzgte vvti swap issues with speed sensor.
- Rear subframe 1993 sc300
- Sc300 turns off randomly
- engine oil leak-iuz-fe
- which tranny cooler?
- should i add a tranny cooler on single turbo 2jzgte
- 1997 sc300 ecu help
- car jerks forward and backward when driving
- Fuel Pump stays running (No 12V mod)
- Weard power steering problem
- injectors question
- Heat valve
- Tranny won't shift out of Park
- Fuel economy specifically with 1JZ VVT-i stock/BPU and R154 5-speed and LSD 4.083:1
- A/C Diagnostics
- Dash light problem
- is dark gunk/oil normal under valve covers of jdm aristo motorset?
- help with my exhaust leak
- Battery light on but alternator and Battery are ok...HELP???
- Need to get things cleared up! Help!
- 93 SC300 Aristo Swap No Temp Or Tach After Fix
- SC400 not starting, help plz
- Hesitation misfire during steady acceleration and when stopped with load on motor
- fuel symptoms
- 1jzgte downpipe options?
- need help please sc300 issue
- car problems
- fuel tank vent line in engine bay question.
- white smoke, power steering issue (acv)
- Problems with electrical and now ignition. Need help.
- DIY: Install Metal Interior Door Handles
- my exhaust
- Branch Resonator on SC300?
- Tail lights
- Ignition timing
- 1992 lexus SC300 2jzgte jzs147 (HELP ???)
- 93 SC400 using coolant in overflow tank
- Installing Engine with transmission attached
- Hesitation and idle issues after Head Gasket install
- Gte guys what is this for?
- Help! How to install harmonic balancer?? Special tool?
- Where to get the rear crossmember/diff bushing?
- MAF adaptation for 98+ vvti sc300
- High pressure powersteering hose Where to buy?
- 1jz-gte vs. Turboed 2jz-ge
- Other Small Issues.
- Headlight Relay Issue + Wont Crank
- Clutch Return Spring Problem?
- sc400 pcm in a sc300
- 99 sc300 starter removal
- 1jzgte White smoke
- 95 SC 400 Blower moter going high then low Showing codes 21 and 43.
- Interference Engine
- Engine Trouble 92 SC400
- Starting problem please help!! Vids inside
- Turboing my sc300
- Need help with valve cover gasket!
- Who has done the vvti to non conversion???
- Map sensor wire diagram or colors heeeellllllpppp!!!!!!!
- Code 22 Engine Coolant Temp Circuit
- Looking for Bart???
- Supra Fuel Pump in Sc300
- trans code 42 and engine code 29 not revving past 4k in 1st
- Diagnosis Assistance Needed 92 SC400
- sc300 wont start ... some input/suggestions please
- Take off sucks!
- 1997 sc300 p0401 HELP
- Where does this intake vacuum line go??
- Anyone ever use the Transgo 340-HD2 shift kit? Just bought one going to install.
- pcm / ecu part number interchange
- speedometer subassembly gear
- Fluid leak. At a loss...
- 93 sc400 smog please help !!!!
- Bought the SupraStick; Need paddle shifters?
- car finaly gave up maybe?
- sc300 w58 vs mk3 w58 tail housing length.
- Chaser Auto tranny in SC300?
- 1997 sc300 P0171
- Better than BFI
- Want to know if 2001 m5 motor can fit
- precat worries
- Sc400 Warm Issues, and no spark (Sometimes)
- 1998 sc300 turbo help
- Need some Help, Engine Dies
- r154 slip yoke
- sc400 oil light on
- pros vs cons remote oil pan/pump for 1uz turbo
- When do we change our water pump?
- Tuning a 1jzgte single turbo with E-Manage...?
- Does anyone know what this exhaust is?
- Help on MSD 8920 Install *searched*
- Single turbo guys
- Need an estimate
- How can I verify That a Transmission is an R154?
- Burning up MAFs
- check engine & trac off lights on after mild tune up
- Exhaust leak help.
- Engine randomly shutting off while driving
- Brian Crower 1jz 264 camshaft results.
- High HC on smog SC300 - changed everything
- A new FFIM offering for the 2JZGE?
- have somebody experience with this upgrage ct15b
- injector and what?
- Heart Transplant
- some advice please? one of my turbos has an issue
